UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.82a
Reply 860 of 876, by analog_programmer
Hi, vintagefugg,
I think, I tried everything you requested and here are the results:
vintagefugg wrote on 2026-10-27, 19:08:
Could you tell me: - what UNISOUND v0.82a printed (does it say "No card detected", or does it find the ES1688 and print settings […]
Could you tell me:
- what UNISOUND v0.82a printed (does it say "No card detected", or does it find the ES1688 and print settings?),
- your BLASTER line,
- what exactly doesn't work afterwards (no sound at all, only music, game setup can't find the card...)?
With "UNISOUND /NOPNP" in AUTOEXEC.BAT or from command prompt:
- "No PnP card detected." message:
Universal ISA PnP Sound Card Driver for DOS v0.82a. (c) JazeFox 2019-2025
- I don't use a BLASTER variable set, since UNISOUND sets its own default values when manage to initialize any SB-compatible soundcard.
- no sound FX, no FM music, no MIDI, etc., the soundcard is undetected and uninitialized.
If you have a moment, this test would show which one it is. From a cold boot *without* ESSCFG in AUTOEXEC.BAT: 1. Run ESSCFG and […]
1. Run ESSCFG and look at the current settings (option 7). If it can't find the card or says no IRQ/DMA is selected, note that.
2. Run UNISOUND /NOPNP and note what it prints.
3. Run ESSCFG again and look at the settings. If the IRQ is 9 or the DMA didn't change, it's problem 2.
ESSCFG rewrites BLASTER from the card, so SET it again before running games afterwards.
ESSCFG for ES1688, that I use, is an alder version 2.1, so it is option 6. No BLASTER variable is set. These are the results after "cold" reboot with Reset button:
1. First I run "ESSCFG" from command prompt only and option 6 (for report):
ESSCFG ( Version 2.1 ) found ES1688_PnP at address 220.
Current IRQ channel setting is 5.
Current DMA channel setting is 1.
MPU401 is enabled with no IRQ.
Current MPU401 base address setting is 300.
Joystick is disabled.
2. Next - "UNISOUND /NOPNP" from command prompt:
3. Finaly - "ESSCFG" from command prompt and option 6 (for report):
The assigned IRQ is not 9, but 5, and as you can see, no initialization was done from UNISOUND and no Port, IRQ and DMA values were changed after.
I don't really have a great way to share files but I built a little test program ESSINIT that extracts out the bits of ESSCFG that I think are relevant. It's here https://limewire.com/d/g4XTB#7PTdbrSd5K (expires in 3 days). It sets up an ES688/ES1688 the way ESSCFG does: it wakes the chip if needed, writes the IRQ and DMA from BLASTER through 2xCh, reads them back and tests that the IRQ actually fires, printing each step. Run it instead of ESSCFG after a cold boot (ESSINIT > ESSINIT.TXT) and post the output; ESSINIT /OLD writes the values the 0.82a way, for comparison. If ESSINIT works where UNISOUND doesn't then that gives JazeFox something to work with.
As expected your ESSINIT.EXE works just fine with ES1688 card even with no BLASTER variable set after "cold" reboot:
1. When I run "ESSCFG" without any command line switches from command prompt only:
BLASTER not set
Base 220h, IRQ 5, DMA 1
Before: 2xEh = 18, 2xAh = AA
Reset: 2xAh = AA after 1 ms, 0 more byte(s) flushed
E7h: 68 8B
Chip: ES1688 or later
Mixer 40h = 03
Before: B1h = 15, B2h = 1A
Write B1h = 55: both bytes to 22Ch, busy wait 0 and 0 ms
Write B2h = 5A: both bytes to 22Ch, busy wait 0 and 0 ms
After: B1h = 55, B2h = 5A
F2h try 1: IRQ3=0 IRQ5=1 IRQ7=0 IRQ9=0 IRQ10=0
Interrupt on IRQ 5: OK
RESULT: OK
2. When I run "ESSCFG /OLD" from command prompt only:
BLASTER not set
Base 220h, IRQ 5, DMA 1, old write
E7h: 68 8B
Mixer 40h = 03
Write B1h = 16: B1 to 22Ch, 16 to 22Dh (old way)
Write B2h = 1A: B2 to 22Ch, 1A to 22Dh (old way)
After: B1h = 15, B2h = 1A
RESULT: OK
In both cases ES1688 card is initialized and works perfectly fine.
Please tell me, if I didn't manage to do something the way you wanted.
On fixing unisound: I still can't use PMs on vogons (too new?) and I don't have another way to contact JazeFox but I think we could patch this into unisound without too much drama if they're willing to accept binary diffs or patches.
If I'm not mistaken, you'll get the permission for sending PMs, when you hit 20 posts. But even now you can attach executable (and other type) files in your posts if they are in some archive format like zip, 7z, rar... or if you change their .exe/.com extensions to any acceptable .jpeg, .gif, .txt, .doc, .pdf... extensions, but the latter method is not recommended. There is a limit of five attachments per post.
I also think, that your ESSINIT (for ES1688) program should be permanently attached here or in some other dedicated thread for download, since it works perfectly fine just like ESSCFG does.
I have no idea what happened with JazeFox. It seems like he/she just "disappeared without a trace". I don't have any hope for now UNISOUND version, since it is closed source freeware.
I'm looking forward for your conclusions after the quick tests I made. Thank you very much for your support!
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 861 of 876, by vintagefugg
Ok, I am *super* wary of stepping on JazeFox's toes here but as they haven't been active here for about a year I figured I might step in and keep things moving until they return. I have a build with a few fixes that I've been running on some real hardware and on 86box. I will happily delete this file, my comments, my account, or whatever it takes to keep JazeFox happy when they return. All credit for this fantastic tool goes to them. I'll pass all the fixes to JazeFox when they return.
I've linked UNISOUND v0.82a-unofficial-fix-3.zip below. It is not attached to this comment because (a) none of the licenses I can select on vogons apply here and (b) I need to be able to delete this file if JazeFox asks me to and I'm not sure I can delete whole comments / attachments here. It's named fix-3 because I've been through a few rounds of real hardware testing. I'm concerned that the binary is reaching a size where the COM 64Kb segment limit but I've run 86box-mcp regression testing on a pile of simulated hardware + a few physical systems and it's been fine so far. This is an unofficial build. Don't yell at JazeFox if this burns down your house. Check CHANGES.TXT inside the zip for the full list of modifications.
https://mega.nz/file/fCZiHQwI#fAMNKQkWwIUa262 … 3t-GjeQ5O49kQQA
Bug fixes — General
  • Options must be spelled in full; unknown ones print "Unknown option" and exit with ERRORLEVEL 2 (/DUMMY used to disable the card). /XOS0 now works. (yeokm1, AndalusianRG, Cryptus, analog_programmer)
  • Volumes take one digit as well as two (/VL0 used to be ignored); a bad value prints "Invalid value". It turns out my own autoexec.bat I was using on many real systems was failing to set line in volume because I was passing /VL0 instead of /VL00!
  • Unknown PnP cards (NICs, modems, game ports) are skipped instead of stopping with "Aborting"; /Cn with no card n exits with ERRORLEVEL 1. (ajacocks, Retromachines, NightSprinter, AncapDude)
  • ULTRASND and BLASTER with fewer fields are read correctly.
  • Long card names no longer hang /CL.
ESS
  • /NOPNP finds an ES688/ES1688 after other UNISOUND commands. (GigAHerZ, analog_programmer)
  • /NOPNP finds chips that start disabled; ES1788 and ES1887/ES1888 are recognised. (analog_programmer, 0xDEADBEEF)
  • /NOPNP writes the ES688/ES1688 IRQ and DMA the way ESSCFG does; a real ES1688 ignored v0.82a's writes. (vico, analog_programmer)
  • /NOPNP no longer takes another card for an OPTi 82C924/925 and skips the ESS check ("No PnP card detected."). (analog_programmer)
  • ES1868/ES1869: H4 and D = H mean no second DMA. (Kahenraz)
  • ES1868/ES1869: U sets the MPU-401 IRQ. (crvs)
  • ES688 and OPTi 82C930 names corrected. (Pr1ha)
Creative
  • Non-PnP SB16/AWE32: /R only reads and /D leaves the card alone.
  • An F not a multiple of 4 is rounded down (F389 becomes 388). (Mr.Hunt)
  • AWE /VR50 to /VR99 no longer corrupt FM passthrough.
  • 28 MB of AWE RAM is shown correctly.
Crystal
  • CS4237B, Orpheus, Turtle Beach: codec left in standard WSS mode, so Tyrian accepts it. (vanfanel)
Yamaha OPL3-SAx
  • K sets the WSS DMA, and it is shown. (TgamesFR)
  • SB Pro master set like aitotat's FIXYMF: SB Pro stereo panning (Wolf3D) works and /VW lowers the effects volume. (badmojo, --Freeman--)
  • D = H keeps D and moves only the second DMA.
Others
  • OAK OTI601 / OPTi 82C928 with a CS4231/CS4248: codec bits set.
  • AZT2320: D = H keeps D, an invalid H is corrected; Aztech and Rockwell leave the SB Pro mixer in mono.
  • InterWave ROM names, Ensoniq VIVO and Maxi Sound /R, SAM9407 firmware upload: small fixes.
Known issue, not changed: on the OPTi 82C931 the FM address is written to a register that expects a multiple of 16; real cards seem to answer at 388 anyway.
New features
  • BLASTER check: if BLASTER is missing or doesn't match the card UNISOUND just set up, it prints a SET BLASTER line for AUTOEXEC.BAT. Other fields are kept, and a BLASTER that points to another card is left alone. (analog_programmer)
  • /LOG prints diagnostic lines for problem reports.
  • /XSLAM sets up Crystal CS423x chips that the BIOS has hidden from PnP; a Crystal chip with no resource data (Gateway E-1000) gets the standard layout. (Pickle, MartinausWien, AliceImagina)
  • /XESSB finds on-board ES1868/ES1869 chips that the PnP scan misses, through the ESS bypass key. (vsharun, Oetker)
  • When no card is found, UNISOUND points to /XSLAM, /XESSB and /LOG.
  • The banner shows this version.
Everything was tested in 86Box except the Ensoniq, Maxi Sound, SAM9407 and 82C928 changes. /XSLAM, /XESSB, the OPTi checks and the Yamaha changes haven't been tried on real hardware yet, so reports are welcome. Thanks to everyone in this thread who reported these problems. If something breaks, first check whether the official v0.82a does the same, then post the output of this (with the options you normally use, such as /NOPNP):
UNISOUND /LOG > LOG.TXT
Reply 862 of 876, by Pickle
vintagefugg wrote on 2026-10-28, 20:58:
So is this based on original code or reverse engineered/AI decompilation?
Reply 863 of 876, by vintagefugg
No, it's not the original code because only the original author has that. NSA Ghidra is basically required here because the tool is closed source.
I mentioned "86box-mcp regression testing" in the comment. MCP = Model Context Protocol. To me, and I expect to most developers these days, mentioning or using MCP implies AI. I had AI build a test harness to configure, boot, and run unisound fixes, and test sound (FM, midi, digital) for every sound card 86box supports on a few hardware platforms I mentioned in a pervious comment. Doing that manually would have taken *days*. My real hardware testing is not AI driven but I understand it can be done these days if you have fancy gear.
I also used ghidra-MCP to drive disassembly. I don't have super readable code with all the comments from the original author so it's pretty tough to read and understand but it's possible to work on. Still, almost all of the original COM file is still present because most of these are tiny changes. You just have to allow for bytes to be shifted where code was inserted or deleted. For example: the new LOG output insertion shifted a bunch of code. I started by trying to apply a couple of small binary patches but it was an not possible to complete even just the initial ESS issues given the time I have available.
If that somehow still doesn't meet vogons rules I'm fine to delete the file + comments and just hand JazeFox the list of potential fixes when / if they come back.
Reply 864 of 876, by analog_programmer
vintagefugg, your fixed version finally works with ES1688F chip. Thanks a lot! Later today I will test it with ES1869F.
If some users complains about your Ghidra reverse-engineered code and patches in this thread, then just open a new thread about your patched UNISOUND version. I don't know what happened to JazeFox and how many JazeFoxes ("them"?) were out there, but it is obvious, that there will be no more "official" support for the original UNISOUND tool.
EDIT: It turned out, that the original UNISOUND version 0.82a just needed /F or /FS switch for my soundcard with ES1869F chip to be properly initialized. I was misled by the /XEA "compatibility" switch intended for ESS based sooundcards.
Reply 865 of 876, by jh80
Thanks for putting the work into doing this and for being level-headed about respecting JazeFox's wishes when they return.
Reply 866 of 876, by keropi
thread cleaned, please stay on topic
it is one thing to discuss a "hack" of unisound and another to start political discussions and attacks
let's get back at being a community , thank you
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 867 of 876, by Boohyaka
Followed the recent shitshow from afar, thank you for stepping in keropi.
Still I'd like to say something - JazeFox seems to be MIA, right. But he's also been pretty vocal about not wanting to go open-source, nor wanting to be publicly coerced into making it open-source and having to constantly justify it, something we also discussed together in private. And pure speculation on my part, but I wouldn't be surprised this played a role in his current absence.
He may or may never come back, he may or may never update UNISOUND. The current AI reverse-engineering craze being what it is, I don't think there's much he could do about it anyway - I for one think that at the end of the day, having bugs fixed in UNISOUND as well as new improvements, is a positive.
What I would ask for though, and that's of course my own personal sensitivity and perception of "doing things as right as possible" that people may not care about like I do, or simply don't agree with: split the thread on vintagefugg's first post including further replies to his post, and make it clear in the OP that this is an unofficial AI-helped reverse-engineered "fork" of UNISOUND by JazeFox with a link to this thread.
Give JazeFox a chance to come back here and find "his" thread somewhat clean for him to pick up and maybe work on it again, if he feels like it. If he comes back here and see these pages and pages of comments and reverse-engineered builds, I can only put myself in his shoes, I would probably just silently drop it and leave for good.
Again, that's what I think would be the "right" thing to do. Even if the new work from vintagefugg's is linked in here for reference. Maybe he'll find it interesting and would like to collaborate, who knows. But I'm pretty sure that would never happen if he stumbles on anything that looks like how it's been going in here for the past few days, and I wouldn't blame him.
Reply 868 of 876, by Kahenraz
JazeFox does not have a monopoly on universal sound utilities. He has contributed a wonderful piece of software and is welcome to continue to improve it and to also keep the source closed; that's his perogative. However, it has been long enough that new bugs and issues have piled up. People like his software but no one likes bugs. The only path forward is either to continue development of the original project or, if he is unwilling, to either patch it or create a new project with the same goals from scratch.
JadeFox is more than welcome to return and continue his work but I don't feel that there is anything wrong with patching his utility. People have been patching software to fix bugs for years. I think that this work should be celebrated and not vilified. You can feel bad about it and sympathetize all you like, but I am appreciative to see work on this project continue in any form. It is good for the retro community.
I think that it's a completely separate discussion on whether the use of AI to modify software is ethical. Imo, it's just another tool. A very sophisticated tool, but one that still requires significant input and auditing to function. It's not a magic box. It is a force multiplier, like any other tool.
Reply 869 of 876, by Pickle
I think the good approach is documenting how each card initialized so it’s available for all. In a way following the methods for a clean room design. So then it makes a future open source tool independent of any previous tools.
Reply 870 of 876, by Kahenraz
Pickle wrote on 2026-10-30, 18:51:
I agree. This would be fabulous. ✌️
Lots of these early cards have a lot of nuance to their initialization routines. It would be amazing to have this documented somewhere. No matter how well we think we know it, there's bound to be new edge cases that will be discovered in the future (just like we're doing now), and writing all of it down will help with future tool development.
Reply 871 of 876, by eliot_new
No, I don't agree with you!
You shouldn't delete your account nor your great work only cause an user is angry about you (as far I understand the topic here?)
My proposal:
You continue your great work here
If someone doesn't like you, he or she can make a "motion" and propose democratic vote whether you stay or not. In case 51% of the users here vote in favor, then you stay and the person against you must leave vogons forever. This is my humble opinion as swiss citizen. Here in Switzerland we usually vote whenever a dispute occurs. I m convinced that > 51% like you and your work!
DOS:P233MMX,64MB,ECS,SpeaMirageV7,3dfxV1,AWE64,ESS1868,PicoGUS,32GB
W98SE:K63/400,256MB,P5A,Verite2200AGP,3dfxV2,M3D,AWE64,ESS1938,PicoGUS,64GB
XP:P3-1G,512MB,CUSL2C,FX5600AGP,Audigy1,80GB
Reply 872 of 876, by Kahenraz
eliot_new wrote on 2026-11-05, 17:21:
My proposal:
+1
I disagree with any kind of vote. If JadeFox does come back and wants you to take it down, then take it down and repost it as a diff patch and carry on. He is more than welcome to update his closed source project but he has no control over anyone modifying it and sharing those changes when it's not a full binary. He owns his code not your patches.
Competition is useful when development stagnates. He can either reclaim his mantle or pass it on. Ultimately, there is a vacuum for a Unisound equivalent with more bug fixes and features. This will most certainly exist as a new project at some point anyways, and I see no reason to discourage any improvements.
Reply 873 of 876, by badmojo
Thanks for your efforts vintagefugg, I'll try your version shortly. The issue with the master volume was the only reason I haven't used unisound with my YMF card to date.
Reply 874 of 876, by Darmok
@vintagefugg
Could you please add the option to initialize the IDE port on the OPTI930? Currently, I have to use an additional multi-I/O card to connect a CD-ROM drive, as my 386 system already has two hard drives. This prevents me from adding another sound card to the computer, given the limited number of ISA slots.
Reply 875 of 876, by vintagefugg
I've broken out "unisound_continued" into a separate post as suggested: UNISOUND_CONTINUED - Universal ISA PnP Sound Card Driver for DOS
@Darmok I added 930 IDE and tested it on one of my cards here. It works for me!
@Kahenraz and others discussing openness: the code is on github and linked in the post.
Reply 876 of 876, by empi
Great tool! It works properly with my AZ2320 (the yellow version of the card). I tested it with Prince of Persia as a Sound Blaster Pro. I couldn’t install the DOS drivers because the setup was only for Windows. Unisound saved the day. The older Aztech drivers were much less problematic.
Thanks to the creator!
