Reply 80 of 87, by robertmo3
i uploaded it again as previous was not from a cold boot
Reply 81 of 87, by ubertrout
robertmo3 wrote on 2026-11-15, 01:13:
Fantastic. It's still very early, but it's working. Screenshots below. I have one on order myself.
I didn't realize there was this much interest in this but it should be much simpler than PowerVR to finish.
Reply 82 of 87, by robertmo3
sento and creep clash work too.
you can move the sword with tab.
check the .ini file in game if game has access to all the folders
Reply 83 of 87, by robertmo3
and check my pm
Reply 84 of 87, by ubertrout
Thanks, got it. I'm going to want to get a physical card to continue the project, even though it seems to be working fairly good already. Hopefully arriving this week.
Code is here for now, it's very rough but will hopefully work better soon. The VLB card works better in emulation so far, and it needs a BIOS to work in the video/matrox folder of roms: https://github.com/z2k-retro/86Box/tree/mga-impression-plus
Reply 85 of 87, by starlord
@ubertrout
Incredibly cool. Thank you very much.
Great to see Icehawk working again.
Reply 86 of 87, by matze79
Here are the files from PowerVR PCX1 Card.
I used Slackware 14.2 running on my Pentium 180Mhz MMX, Apocalypse 3D PCX1 and Diamond Viper TNT1 PCI.
The third test, hangs the machine.
Reply 87 of 87, by ubertrout
matze79 wrote on Yesterday, 20:57:
Thanks, the dumps were really useful. They’re written up in Appendix I of the tools repo, including that the fog and divider tables are RAM on the PCX1 and that IEEEFP, BILINEAR and FASTFOG don’t exist.
If you’re willing to try one more run: the texture test now does the driver’s full start-up sequence first, which is the likely difference from what hung last time. Please update and rebuild, then run only the texture test:
cd powervr-pcx2-tools && git pull && make
sudo bin/pcx2dump --texmem
Type yes at the prompt. It may still hang the machine. It can’t harm the card, and everything up to that point is saved to disk first. Either way, please send the new pcx2dump-… folder. Even after a hang, its report.txt will show whether the tables loaded correctly.
