Mechwarrior 2 Decomp/Recomp
Reply 100 of 103, by Mikeyy00
myne wrote on Yesterday, 14:58:
Didn't get into the game yet. Mercs +Titanium files. Something seems screwy with mech customisation. Pretty sure even the shit […]
Something seems screwy with mech customisation. Pretty sure even the shit box commando can go to 9 armor on the head.
Mouse is a bit floaty
F keys mostly don't work as usual. F5 I think it was, did. The rest didn't.
cannot read bwd id 1490
Sorry, is this Mercs acting busted?
Reply 101 of 103, by KHORG
I've just fired up the MW2 recomp, some things I've noticed when comparing it to the DOS 1.1 version which I have running through dosbox:
  • The grey MW2 menu cursor seems to have been replaced with a default windows cursor?
  • If you click on the Archive Holoprojector, it cuts to a zoomed-in view of the "projection" animation, then cuts back again to the normal view. Usually it just runs this animation in the distance of the hall, then cuts to the display.
  • There's some kind of slim vertical red line on enemy target brackets when selecting enemies.
  • Using Z to zoom in immediately causes the 3D cockpit outline to be culled by the renderer. It only re-appears when you shift-zoom all the way back to default.
  • Funnily CTRL-Z has carried over the buggy behaviour from the original game. It was meant to reset your zoom, but in original MW2 had a bad tendency to bounce the camera around.
  • The Satellite View doesn't show a top-down view of your own mech, it also incorrectly carries over enemy targetting brackets from first-person view and puts them in random places.
  • The floatiness of the original targetting reticle seems to be gone. Now if you let go of a key it immediately stops.
  • There's a big frame-rate drop when turning on or off light amplification. Image enhancement is fine.
  • The turrets on wolf level 2 don't seem to be able to turn. They just start blazing away in whatever direction they were originally pointing at.
  • There are various 3D hill objects missing from wolf mission 2. They should be visible as soon as you drop in.
  • When you arrive at a Nav point, two things should happen; 1) the unselected nav icon on your radar for that location should dim slightly (this works) 2) the text for "Nav Alpha" in the bottom left of the screen should also dim (and stay dimmed even if you change to a different waypoint then back) to indicate you've already been there, this doesn't occur.
  • Satellite View doesn't show enemy buildings in red outline (particularly on Wolf 3), it just shows them as black outline.
  • Satellite View also doesn't show the enemy fire in yellow. Usually you can see incoming PPCs, lasers and missiles.
  • On your targetting MFD, (bottom left display) the helicopter on wolf mission 3 should show as a blue fuselage and a red circle for the blade above it, but only the fuselage appears in the MFD view.
  • The NPC vehicle (automobile) driving around on wolf 3 isn't there.
  • On wolf mission 3, the red or green roof-lights on the taller building aren't there. Usually they should fade in and out, being either green or red.
  • In Satellite View, 2D sprites like fires should appear as little fire images, but currently they only show as a black line.
  • In original or recomp MW2, when you're shooting the ground, there is a black puff of dust. However in the original game there is a semi-bug when shooting buildings, static vehicles etc. In this case it should show a weapon splash effect, but it didn't always, sometimes the angle on the building/object would be wrong and you would instead see a black puff of dust and wonder if you were hitting it. However, in the recomp it only shows the black puff of dush when shooting buildings/objects, not the weapon splashes.
  • F5-F6-F7-F8 should act as alternates for the right MFD, e.g. if you press F8, you can press F5 to cycle back to the default mode. This doesn't work in the recomp, instead.... F5 and F6 are linked to each other, F7 and F8 are also linked, you need to press F8 again before you can get back to F5 and all sorts of UXUI that makes my head hurt.
  • If you look down (CTRL up/down) in the Mad Dog cockpit, you can see the backs of the Mad Dog legs, which you shouldn't be able to. I haven't checked all the other mechs for this.
  • Wolf Trial 1, the first two mechs don't move until you're looking down on them from a hill, they should be moving towards you at about the 10 second mark (which is a couple of seconds after you're fully online).
  • Wolf Trial 1 again, the second two mechs should start moving towards you as soon as you destroy the Engagement Sphere. Instead the first only moves towards you when attacked, and his starmate follows him around like an AI with no attack orders.
  • Some of the original 'flight sim' controls seem to have changed? In the original game, UP aimed down and CTRL-UP looked down. In the recomp, UP aims down and CTRL-DOWN (not CTRL-UP) looks down.
  • Sable Flame is all kinds of busted. The Sensor Array Dome is opaque when it should be transparent and you should be able to see into it and through it.
  • Also on Sable Flame, the 2nd Mech group should power up after you destroy the 1st, and the 3rd should power up after you destroy the 2nd. But the the 2nd and 3rd come online at the same time after the 1st is destroyed. Also weirdly the 1st group doesn't appear on radar after betty announces Enemy Powerup Detected.
  • Still on Sable Flame, the third group of mechs get distracted by a Wolf dropship which is flying around above them and instead run around shooting at that.
  • Still on Sable Flame, the Falcon dropships have a Wolf logo on the side (I checked in the original, it's definitely the Falcon logo there).
  • Dropships seem not to be able to turn/aim their turret on top, so like the current problem with static turrets, they just shoot straight forwards when they see something.
  • Still on Sable Flame, there is some weird switcheroo going on with which mechs are in which group, it should be 3-2-3. But instead it's 2-2-4? One of the Mad Dog's from the first star ends up in the last and I feel like the Stormcrow changed group also.
That said, various niche functionality does work, e.g. Ammo dumping is fine, as is Autopilot. The dusk effect that kicks in at the start of Wolf 3 is identical to the original game.
I'll have a further look. It would be nice to be able to get it to optionally use cd audio, rather than ripped tracks.
Reply 102 of 103, by myne
Mikeyy00 wrote on Yesterday, 19:23:
Yes.
First mission : training patrol failed to load with cannot read bwd is 1490
I built:
Reply 103 of 103, by Deffnator
i found another visual bug with the navcam when using satellite link, it is the same i reported earlier
The attachment 16730847756444237824_20261113130226_1.png is no longer available
