WM 0.10 - a window manager for DOS XT/286
Reply 40 of 66, by theelf
keropi wrote on 2026-11-13, 20:10:
this is getting better and better!
Hope so! todaay i sucess in port video mode to my lovely toshiba 3100!
The attachment 20261113_215656.jpg is no longer available
The attachment 20261113_221611.jpg is no longer available
Reply 41 of 66, by theelf
reflexve wrote on 2026-11-13, 21:38:
Hey, just wanted to say this is really awesome and I can't wait to test it out on my 486 when I have a chance. I appreciate all human developed projects, and this one has had a lot of thought put into it. Great job!
thanks a lot, start this for myself long time ago, but this year i had a lot of FREE TIME, because decide to just work for one customer, and now i have 305 free days year... jeje only work 60 days every year from now (but they are really tough)
Love to sit in home and smash keyboard!
Reply 42 of 66, by DoZator
I tried it, and it’s actually not bad! Thank you.
In addition to itself (WML), two more COMMANDs are created when launching DOS from the shell itself (I don’t know if this is how it’s supposed to be or if it’s a bug):
The attachment WML.PNG is no longer available
The context menu is missing the "edit" item for quickly editing BAT files. You can do without it, of course.
Reply 43 of 66, by theelf
DoZator wrote on 2026-11-14, 08:27:
I tried it, and it’s actually not bad! Thank you. […]
thanks man! yes you are right, is a bug i did not realize, because i use 4dos! totally forget to test just with plain command.com jeje too many years using 4dos forget was there
About right button options, YES, is a "need to do next" thing i have in mind but never do, this week end i will have free time since my wife is working, i will do, is good fo me too. Is just boring coding thats why i dont do, is not adding a new video mode or new sound card.. you know sommething fun... 😀 for now i add just edit to BAT, 4CD, INI, TXT, CFG, SYS, LOG, DOC, NFO, ME, 1ST, DIZ, ASC, LST, MD, C, H, PAS, BAS and ASM...
The attachment wm_000.png is no longer available
Please check this fast fix, i just add command.com to same route i use for 4dos. I check and no dupplicated command.com
The attachment command-fix.zip is no longer available
Wm need 3kb convenctional memory when is using as shell, i dont think is bad
before
Modules using memory below 1Mb: […]
Name Total = Conventional + Upper Memory
SYSTEM 12,688 (12K) 12,640 (12K) 48 (0K)
G2MMC 13,312 (13K) 13,312 (13K) 0 (0K)
HIMEM 816 (1K) 816 (1K) 0 (0K)
COMMAND 2,704 (3K) 2,704 (3K) 0 (0K)
CTMOUSE 3,328 (3K) 3,328 (3K) 0 (0K)
CDMKE 11,376 (11K) 0 (0K) 11,376 (11K)
MTMCDS 10,304 (10K) 0 (0K) 10,304 (10K)
MSCDEX 8,816 (9K) 0 (0K) 8,816 (9K)
FREE 688,752 (673K) 622,544 (608K) 66,208 (65K)
Memory summary:
Type of Memory Total = Used + Free
Conventional 655,360 32,816 622,544
Upper 96,752 30,544 66,208
Reserved 362,000 362,000 0
Extended (XMS) 3,080,192 65,536 3,014,656
Total memory 4,194,304 490,896 3,703,408
Total under 1Mb 752,112 63,360 688,752
Total Extended (XMS) 3,080,192 (3,008K)
Free Extended (XMS) 3,014,656 (2,944K)
Largest executable program size 622,208 (608K)
Largest free upper memory block 65,968 (64K)
Available space in High Memory Area 352 (0K)
PC DOS is resident in the high memory area.
after
Name Total = Conventional + Upper Memory -------- ---------------- ---------------- --------------- […]
WML 2,848 (3K) 2,848 (3K) 0 (0K)
FREE 685,904 (670K) 619,696 (605K) 66,208 (65K)
Memory summary:
Conventional 655,360 35,664 619,696
Total memory 4,194,304 493,744 3,700,560
Total under 1Mb 752,112 66,208 685,904
Largest executable program size 619,600 (605K)
Reply 44 of 66, by DoZator
Thank you for the quick improvement. In the new version, the context menu now already includes "edit" and everything works correctly. Instead of three "COMMAND" options, now there are only two left (+WML), which is already better! I’m currently testing all of this on the original MS-DOS 7.10 configuration, without any third-party software (except for the mouse driver). I’m not sure - maybe that’s how it’s supposed to be?
The attachment WML2.PNG is no longer available
Reply 45 of 66, by analog_programmer
In short - that is how it supposed to be (two DOS command line interpreters loaded - one from the DOS itself and the second from WM) with the current WM "architecture". Perhaps there's a way to avoid the second COMMAND.COM, 4DOS.COM or whatever command line interpreter loading like with Doszip Commander, but I'm not the one to mess with WM's code.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 46 of 66, by theelf
DoZator wrote on 2026-11-14, 11:02:
yes, like analog_programmer say, is correct. If you for example, launch a game, directly from WM, you will only have one command instance, but if you open a prompt, or ejecute a bat, etc you will have 2, since first one is for WM
Reply 47 of 66, by LordMMX
Looks amazing. I wanted to do this with Calmira Nextgen, but in the end it was easier to go Windows 3.1 shell route
Reply 48 of 66, by mtest001
This looks impressive. Can it run under MS-DOS 7.0?
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 49 of 66, by theelf
mtest001 wrote on 2026-11-14, 16:13:
Never tested but i dont see why not, work fine on FAT32, in my 286 i run PCDOS 7.1 with a 16gb fat32 partition
Reply 50 of 66, by DoZator
I can offer you one more (not very important, but quite desirable) improvement — to add support for auto-scrolling. Here it is:
The attachment MButton.PNG is no longer available
as the fifth possible option for the middle mouse button. This would make it easier to view very long documents. Currently, you have to move the slider manually or use the keyboard buttons (up-down\pageup-pagedown) to scroll through a large document in any way. With auto-scrolling on the middle button (as it was done in Windows), it would be much more convenient.
PS: I just noticed now that WM even has its own browser built in!
It will be necessary to somehow configure the Internet in DOS (Like for my Intel network card there was an ODI driver somewhere) and try this browser in action (You see, you will be able to access VOGONS via the usual HTTP protocol, directly from DOS) xD
Reply 51 of 66, by DoZator
theelf wrote on 2026-11-14, 14:21:
Yes, you’re right, I checked, and if you run the DOS program directly from the shell, the second copy of COMMAND is missing. So now everything is fine.
Reply 52 of 66, by pavunoDev
this is a beautiful project
to support XT properly, it would really need to cover MDA, CGA, EGA... but I realise this would be hard work and involve completely separate modes that don't make much use of colour, and that the author is not really running these machines which detracts from the motivation needed
but I'm really loving it and looking forward to see the code eventually
Reply 53 of 66, by mtest001
theelf wrote on 2026-11-14, 17:11:
Tested it and it works beautifully.
That's amazing work frankly, congrats and thank you.
I could not switch to 256 colors though.
Reply 54 of 66, by Cyberdyne
Save/Save as dialog is still in italian.
All save option do not say what format is saved.
Paint does not have any save options whatsoever.
Do you plan to release SDK. That others could make apps to your OS/2 looking mini windows manager.
Like to have Calmira/9x user interface to it for example.
Reply 55 of 66, by theelf
mtest001 wrote on 2026-11-15, 14:53:
Tested it and it works beautifully. […]
Hi, thanks, please can explain what you say about switch? like change to vesa 256 color for WM, or switch to 256 colors in app like Paint or mmplayer?
DoZator wrote on 2026-11-15, 10:15:
I can offer you one more (not very important, but quite desirable) improvement — to add support for auto-scrolling. Here it is: […]
How auto scrorlling will work? always down? how you change UP/DOWN scroll? never see this option in windows to understand how it work OK waas very easy, i did just emulate keys, left click change up/down, next version
About NET, i did not test much, i add this option because i did a FTP software years ago, but finally never use and abandon the idea, but in NET folder is a cfg you need to edit to have internet, you will ned a working mtcp and a packet driver
really, i NEED TO do a fucking README, but write in english is A PAIN to me, i know about this problem of lack of info
pavunoDev wrote on 2026-11-15, 14:44:
Thanks! yes, the idea is 640x480x16 colors, because is THE ONLY rersolution i use in my computer, please remember WM is for my personal use, i share because maybe someone like it, but at the end of day is just personal
BUT some people askme for EGA and i did, and i have a thosiba 3100 with 640x400 CGA, and i did too. Because Hercules is similar to toshiba just different register i add too in latest build, but even if tested, i doont care AT ALL about this modes. This is true, then if something dont work, i will not fix. Is like 256 color mode, i dont use, and not care at all neither jeje
Thats why my idea is when i have time to clean the code and share to github! then if someone found usefull WM can change wetever and fix to their needs
Reply 56 of 66, by theelf
Cyberdyne wrote on 2026-11-15, 15:30:
Save/Save as dialog is still in italian. All save option do not say what format is saved. Paint does not have any save options w […]
Im spanish, and you need to tellme what dialog is in spanish or i cant guess
I dont understand what you want to say
Paint have a save and save as
The attachment paint.png is no longer available
Yes i will release source to github as soon i have time
Reply 57 of 66, by Cyberdyne
If you exit program with a document without saving the dialog has yes=si and so on.
No new save file have no default extention.
For this screenshot I now know that paint only saves BMP.
Wordpad RTF? DOC? What version?
Reply 58 of 66, by theelf
Cyberdyne wrote on 2026-11-15, 20:51:
If you exit program with a document without saving the dialog has yes=si and so on. No new save file have no default extention. […]
Sorry i cannot reproduce, i did a grep for SI and NO and did not found anithing in my source in english directory. When you exit with a document not saved, what software?¿
paint always save BMP, do you think another format will be useful? pcx and others is better in a conversor, but is possible, gif maybe
Wordpad opens and saves two formats: .WPD (my own format, it keeps the formatting) and .TXT . It does not open RTF or DOC.. i will add rtf later is very simple, for sure i can add that opens and saves rtf for basic text. It will keeps bold, italic, underline, colors and alignment. It will does not keep fonts, tables or images since i dont have this
Reply 59 of 66, by mtest001
theelf wrote on 2026-11-15, 15:52:
After changing to VESA 256 colors in the setting, WML would no longer work and the whole system would freeze right after displaying the background (no mouse pointer).
Changing it back to 16 colors solved the problem.
I have a Voodoo Banshee.
