Reply 2000 of 2009, by dr.zeissler
Ok, made some further testing. I haven't looked up the whole thread so there might be some issues already addressed or they are simply due to my machine with the "untested" chipset. I only have checked for the picogus yet. There might be a complete shift if further progress on the machine config ads problems to the picpgus already working on some games/demos.
I have changed the jumper to IRQ7 (which is the LPT port). Irq and DMA are still set to "1". I am not able to change the IRQ for the LPT in the Bios, I can only switch from 378 to 278 or 3BC. Perhaps that will help when I put the LPT to SCSI Adapter on that lpt1 port in order to get the external CDROM working. For the actual testing this device is not plugged in, neither configured or setup (drivers).
Changing IRQ to 7:
1. PicoGus has much less crackling to my ears.
2. BrainSlayer SB-Demos still don't work. Unreal1.0 does not work in SB (crackling) 1.1 is not tested in GUS-Mode.
3. The pinballGames (PDreams2/Fantasies/Illisions) only work in SB Mode, GUS does not work*
4. Other Pinball Games do work (Silverball, Extreme Pinball, EpicPinball)
5. Ultimate BodyBlows does work in SB und GUS but SB sounds much better (game-related, not a fault of the picogus)
6. No demo (NOON) does not work, either DOPE also does not.
*The issue seems to be that the game tells me to rely on the SET Ultrassnd but the values are perhaps wrong. There is no way to tell the sound engine where the GUS really is. Perhaps the game expects "ultra init" from the GUS 4.11 package to be loaded?
The other PinballGames have a different sound engine, they tell my that they found the variable, but I have to say no and change the values for myself. Interestingly they show IRQ11 and DMA7 as standard, perhaps that is what PDreams2/Fantasies/Illusions also get and therefore not work.
My autoexec.bat has three settings
SET BLASTER
SET ULTRASND
SET ULTRADIR
I have two batch files that change the Picogus either in GUS-Mode or SB-Mode. They are called via "call gus / call sb" before starting a game.
GUS.BAT
pgusinit /GUS
pgusinit /gusenv
SB.BAT
pgusinit /SB
pgusinit /sbenv
Example:
start.bat:
CALL GUS.BAT
SILVER
Reply 2001 of 2009, by NeoG_
dr.zeissler wrote on 2026-11-12, 21:55:
What is your ULTRASND variable?
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 2002 of 2009, by dr.zeissler
NeoG_ wrote on 2026-11-12, 22:07:
...the values the game engine thinks are wrong...the values itself are right.
The correct one: 240,7,1,1,1
The gus.bat shows me that everything is OK.
Reply 2003 of 2009, by dr.zeissler
I think I better make a YT this weekend on it and link it here.
Reply 2004 of 2009, by NeoG_
dr.zeissler wrote on 2026-11-12, 22:09:
AFAIK it should be 240,1,1,7,7
Base address (240), playback DMA (1), recording DMA (1), Ultrasound IRQ (7), SB/MIDI IRQ (7)
Reply 2005 of 2009, by dr.zeissler
That explains a lot, thank you. It seems that I have overlooked the different sequence... I'll test this out. Thx!
(On the real cards I always use either 260,7,7,7,7 or 260,3,3,3,3)
Reply 2006 of 2009, by dr.zeissler
Sound-Emulation is working fine now. Thank you, pretty stupid that I messed up the variables.
Next thing will be trying out win95a with SB mode and checking for a USB-Joystick.
Is there a compatibility-listing where I can post games/demos that currently do not work or partial work?
Thx!
Reply 2007 of 2009, by NeoG_
dr.zeissler wrote on 2026-11-14, 17:11:
Sound-Emulation is working fine now. Thank you, pretty stupid that I messed up the variables. Next thing will be trying out win […]
Thx!
See below post for getting 16-bit audio in windows 95 using SB16 mode
Re: PicoGUS: ISA sound card emulator with Raspberry Pi Pico (Gravis Ultrasound, AdLib, MPU-401, Tandy, CMS)
The github project does have an issue tracker that you an post to, but it requires a github account
https://github.com/polpo/picogus/issues
Reply 2008 of 2009, by TheMysteriousGray
This may seem like a silly question, but I'm really only asking out of desperation.
I know the PicoGUS has CD-ROM emulation built into it, but can it work alongside an actual CD-ROM? I know I can't connect a CD-ROM directly to it for audio or anything, there's no headers and such, but could I have both the emulated CD-ROM (for audio) and a regular CD-ROM (for data) configured under a DOS environment, or does it need to be strictly one or the other?
Reply 2009 of 2009, by NeoG_
TheMysteriousGray wrote on Yesterday, 21:44:
It appears to the system as a physical CD-ROM so just like you can have two physical CD-ROMs, you can have the PicoGUS and a physical CD-ROM. I have it running that way in my system.
It can't occupy the same drive letter, they have to be for example D: and E:
Also it emulates a Matsuhita interface, rather than IDE so you also need to get the correct files for that from the picogus site and add it to config.sys, it won't be picked up by your existing DOS IDE driver.
