How about a MR-BIOS ROM file repository?
Reply 540 of 561, by megatog615
Babasha wrote on 2026-06-30, 06:17:
megatog615 wrote on 2026-05-31, 03:07:
Anyone know if there's a MR BIOS rom building program like cbrom or amibcp to create a rom file with option roms? Or does MR BIOS not care and just let you concatenate files into one big binary rom?
You can concate it but in right order and size of BIOS extensions
Right, yeah. I have done this but for some reason the VGA BIOS never initializes. There are POST codes but it stops at a point. I maintained the exact layout of the original Award ROM file, putting the VGA BIOS at the beginning, then another custom ROM added by the board manufacturer, inserted a correct length of empty space(all FFs) and put the MR BIOS ROM at the end.
Your AI slop bores me.
Reply 541 of 561, by Babasha
megatog615 wrote on 2026-06-30, 09:19:
What is your motherboard? What MR.BIOS and BIOS extensions you use?
Upload it here I will look)))
Need help? Begin with photo and model of your hardware 😉
Reply 542 of 561, by megatog615
https://theretroweb.com/motherboards/s/mis-yamashita-as-3210
Note that the BIOS ROM is for a 27C020 but most of the extra space afforded by one is wasted. The EEPROMs I'm experimenting with are 27C010 compatibles and I'm adjusting the empty space accordingly. I also erased and reflashed the original '020 with the correct spacing and had absolutely no difference so I don't think the positioning of the ROM images matters for this one.
I am using the VIA Pluto MR BIOS dump (located in VIA/VIAtest/).
Reply 543 of 561, by Babasha
megatog615 wrote on 2026-06-30, 18:21:
located in VIA/VIAtest/ - sorry where is it located? What archive or place with MR. BIOSes?
Reply 544 of 561, by megatog615
Babasha wrote on 2026-06-30, 20:32:
From the archive downloadable from here.
Reply 545 of 561, by Babasha
megatog615 wrote on 2026-06-30, 20:46:
I check this BIOS with real VIA 496 mother board (FIC VIP-IO-2) and with virtual FIC and Gigabyte boards in 86BOX - it always gives only 10 44 error on postcard and nothing more
Reply 546 of 561, by megatog615
Babasha wrote on 2026-07-01, 10:33:
Yes this is the same result for me.
Reply 547 of 561, by megatog615
Now I'm wondering why the build for VIA Pluto doesn't work. It's supposed to be for an OrangePC x86 card for Mac. Maybe it's getting stuck waiting for some signal from the software that runs on the Mac? I imagine the thing doesn't start fully until the software tells it to continue. If this is the case maybe it just needs an adjustment in the rom to ignore the wait and continue?
Reply 548 of 561, by MrCrocodile
Has there ever been any signs of Mr Bios for SiS 85C496/497? I have Zida 4DPS motherboard and thought it would be awesome to have Mr Bios installed.
Reply 550 of 561, by Imperious
This is the supported chipset list as of 2001. https://web.archive.org/web/20010204041000/ht … com/chipset.htm
There may be more but later websites require You to enter an online request form and obviously that is not going to do anything now.
Reply 551 of 561, by douglar
Imperious wrote on 2026-09-14, 12:54:
There's lots of hints on the internet about "what once was" for MrBios. Things are tantalizingly close, but still unobtainable.
Check out this archived page:
https://web.archive.org/web/19991008055645/ht … m/ftp/_vti_cnf/
Wouldn't it be great to have all those files?
edit, my bad, I guess we got all those: https://ftp.zx.net.nz/pub/archive/files.mpoli … are/ROM/MRBIOS/
and they are added here: https://www.vogonsdrivers.com/getfile.php?fileid=1971
It's the ones before that which are harder to find
Reply 552 of 561, by jheronimus
douglar wrote on 2026-09-14, 13:43:
Yeah, the shareware ones are no problem, Intel ones in general are all found too. It's the stuff that predates Internet/shareware distribution of MR BIOS that are still not all there.
Like man would I love to get a 3.x image for one of these:
Opti 82C546
Opti 82C596
MR BIOS catalog
Unicore catalog
Reply 553 of 561, by douglar
jheronimus wrote on 2026-09-14, 14:06:
Yeah, the shareware ones are no problem, Intel ones in general are all found too. It's the stuff that predates Internet/sharewar […]
Opti 82C546
Opti 82C596
And I'm always on the lookout for the Ali M1209 & Ali M1217
Reply 557 of 561, by Am386DX-40
Anonymous Coward wrote on 2026-09-26, 11:49:
Isn't M1219 designed for 386SX type boards? I take it that you meant the M1429.
You are absolutely correct!! My mistake. It's the 1429.
Reply 558 of 561, by philandrieu
Hello everybody,
Just in case, I'm looking for the very latest Mr-BIOS for the Symphony Labs HAYDN II chipset :
V071B411 / SYML411
V071B412 / SYML412
V071B413 / SYML413
Have a nice day,
Best regards.
Reply 559 of 561, by douglar
I discovered that if you put a VLB controller with the Opti611 IDE chipset in a motherboard with the OPTI4BH BIOS for 495XLC, an additional page opens up in the setup screen for the VLB IDE controller.
Edit -- mistakenly wrote sys instead of opti
