Exploring the performance of the Matrox G550
Reply 100 of 100, by vvbee
The question of hardware T&L is resurrected. The answer is, the G550 does appear to have functional hardware T&L for DX7 and DX8 (not OpenGL), starting sometime around driver 6.7x. It can be exposed in 6.83 by changing g550dd32.dll's bytes 0xeac1 (DX7) and 0x59f11 (DX8) from 74 to eb.
The attachment g550hwtnl.gif is no longer available
Based on brief testing, it appears to work generally speaking, but some types of polygons have issues. Game 1 in 3DMark2000 for example has glitched terrain while game 2 renders with few to no glitches. On a P4 2.4 GHz test machine hardware T&L loses a bunch of performance, around 50% in 3DMark2000. In Evolva hardware T&L gets around 27 FPS while software T&L hits the vsync limit at 60. I don't know whether this T&L would be of use on a slower CPU, maybe.
Even though hardware T&L isn't exposed by default, apparently fog is always computed by the on-board T&L engine, unlike on the G400 which doesn't appear to have any. Says Claude's analysis.
