First post, by nukeykt
Hi
Released test version of my low-level Roland MT-32 emulator.
It uses LA32 and Reverb chip emulations based on silicon RE, as well as CPU emulator from MAME/Olivier Galibert.
Probably it still has some bugs, but overall sounds pretty good.
Currently only MT-32 rev 2.0 is supported. Other models will be emulated later.
Like Nuked SC-55 it is standalone app that listens to MIDI input port.
You'll need MIDI loopback app (i.e loopmidi or loopbe1) to use it with DOSBox or ScummVM.
Download (Windows):
https://github.com/nukeykt/Nuked-MT32/releases
Source code:
Reply 1 of 3, by MadLynx
Great work! Do your plans to add other models include the CM-32L or just older versions of MT-32?
Reply 3 of 3, by badmojo
Thanks nukeykt!
