AWE64 Legacy
Reply 800 of 801, by Eep386
Oi! This discussion devolved into a mess of audiophile vs. anti-audiophile "debating".
My two cents: in a PC sound card whose rails are typically +5V single supply and GND, assuming its compatible with your signal source, the exact particulars of the DAC you intend to use are largely irrelevant (assuming the device isn't defective by design). In this kind of environment, you already have so many things working against you that fussing over a DAC's THD+N particulars is completely futile. (In addition to not having nearly enough power to gain any manner of signal very high without introducing heavy distortion, there's a nice big noisy motherboard injecting all manner of evil sounds into the device, plus its power supply is typically anything but quiet...)
Besides, even the "lousy" DACs of yesteryear have SNRs southwards of -80dB which, for the average consumer NOT abusing their ears by listening to everything through headphones, is a completely inaudible noise figure when listening through ordinary desktop speakers. (The hiss from the speaker amplifier will easily engulf everything below -50 dB; in some cases everything below -20 dB.)
Reply 801 of 801, by RayeR
AFAIK many soundcards use 12v (and -12v) with additional filtering and LDOs for opamps. Well designed dedicated soundcards like SB Audigy has very little noise and THD in output. In the past I measured some audigy and live PCI and it had SNR over 90dB and very low distortion. I have noise problems from computer circuits usually with cheap onboard souncards where you can hear noise e.g. on every mouse movement or hdd action. But never with PCI SB audigy/xfi/live...
