Reply 1120 of 1120, by vanfanel
vanfanel
Offline
- Member
djsbriscoe wrote on 2026-11-01, 15:55:Can someone point me to the SOC module data sheet? I'm thinking off building the WeeCee_Redux version and adding a serial port and parallel port. I need to find out which pins on the module to wire to the ports. I will of course need to modify the PCB. Can anyone point me in the right direction? Thanks.
Where are the schematics for the Redux version?
They seem to have been pulled off github by it's author.
Also, note the CMOS battery contact is not correct.
