The king of operating systems and compatibility
First post, by DarthSun
There has been a similar post before, but I decided to start a new thread instead of just replying. In my humble opinion, my new rig is so impressive that it deserves its own topic.
Configuration:
Machinist MR9S
Xeon E5-2699v3
LC Power LCC120 cooler --- Deepcool ez, kevertem a sok gép miatt, de kb hasonló, 180W TDP- re van tervezve...
4x16GB Samsung ECC DDR4 2400T
5 SSDs (a mix of 256GB and 128GB units) +1 x 4TB external NVMe SSD for DOS and storage
Quadro FX4500 (7800GTX)
Asus GTX 1650 GDDR6 OC
Chinese PCIe to PCI converter
Audigy2ZS PlatinumPro sound card
LG external BDRW (Blu-ray writer) drive
VeinX GL29AL-BK case (ATX, with dual vertical PCI slots)
Chieftec 850W PSU
Operating systems and supporting drivers:
DOS 6.22
DOS 7.1
Win98 SE
XP – modernized (I am not permitted to specify the exact version here, but those familiar with "modernized" XP will know)
Win11 22H2 – considering an update to 25H2/26H2
Intermediate operating systems would certainly run as well, but they are no longer practical for my needs, so I have omitted them for logical reasons.
CPUSpd – ensures everything runs correctly, even starting from the XT performance level (though a 2C/2T CPU configuration with Hyper-Threading disabled is recommended).
Loew: memory drivers, TBPlus, NV512MB fix, AHCI SATA, and NVMe drivers.
SBEMU, VSBHDA, and VSBHDASF drivers – while these are emulated solutions, they function via a front-end, meaning the DOS environment itself runs natively.
Turbo Pascal fix – accessible via the menu; required for certain games (e.g., Tyrian).
DOS screenshot utility/utilities.
SDI driverpack, for XP and Win11
The board has arrived. I’ve tested it. It turns out it’s compatible with absolutely everything—from DOS all the way to Windows 11. It has a Q87 chipset and detects both Nvidia cards. Furthermore, the Chinese UEFI allows you to enable or disable any individual PCIe slot—ideal...
It also recognizes the Chinese PCIe-to-PCI converter, along with the "semi-retro" sound card installed in it (for Win98).
The Q87 chipset offers full compatibility with all components. The C612 (on the Huanazhi X99-TF) offers only partial compatibility; while the latter is a better choice for those using exclusively modern operating systems, the simpler Q87 is superior for its broader range of compatibility.
In the meantime, an RTX 3060 and an RTX 5060 have also arrived, but for now, I’ve kept the little 1650 in the build.
Let's start... with the assembled photos...:
The attachment 2699_assy_edgefront.jpg is no longer available
The attachment 2699_assy_edgerear.jpg is no longer available
The attachment 2699_assy_rear.jpg is no longer available
The attachment 2699_assy_full.jpg is no longer available
The attachment 2699_assy_cse.jpg is no longer available
To be continued...
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 1 of 21, by Condor.07
Honestly, I don’t see anything impressive here 😀
You’ve installed 3 or 4 operating systems...
SBEMU, VSBHDA, and VSBHDASF are garbage; if you’re lucky, maybe one out of every ten games will actually work.
I suspect that PCIe-to-PCI sound card only works on Windows 98, not on MS-DOS.
Claiming that "everything works perfectly" is quite relative...
How did you install Windows 98—does it shut down automatically when you select "Shut down" from the menu?
How are you handling the dual-graphics setup on Windows 11? Does the Asus GTX 1650 kick in automatically, or do you have to manually switch the input source on your monitor?
I’ve read all sorts of things in here... but as for systems that actually work properly—there isn’t a single one!!!
Reply 2 of 21, by DarthSun
DOS: everything works... it seems you aren't familiar with the capabilities of the professional MR9S motherboard.
Audigy2ZS PPro: it runs perfectly under DOS, too. I take it you aren't aware of the capabilities of SBEmu, VSBHDA, or VSBHDASF? Please look them up in the relevant threads—they are covered in the most detail here on Vogons... I suppose you're still quite a beginner when it comes to this kind of knowledge.
Win98 installation and configuration are coming up—I did mention there would be a follow-up! Everything will be uploaded, and everything works!!!
Monitor and graphics cards: this will be documented as well. It seems you didn't grasp that on this professional Chinese board, every PCIe slot can be enabled or disabled individually. This means I can boot directly into the specific graphics card required for the operating system I'm using... then again, if someone doesn't know this, that's understandable—not everyone has the world's best X99 motherboard in their build...
Reply 3 of 21, by DarthSun
DarthSun wrote on 2026-11-17, 20:59:
There has been a similar post before, but I decided to start a new thread instead of just replying. In my humble opinion, my new […]
Configuration:
Machinist MR9S
Xeon E5-2699v3
Chieftec 850W PSU
DOS 6.22
DOS 7.1
Win98 SE
To be continued...
Szóval akkor folytassuk (régen készen van már, de itt csak 5 kép közölhető egy postban)
The attachment Set_img_Q_visions.jpg is no longer available
The attachment 2699_w98_first.jpg is no longer available
The attachment w98_vxd_audigy.jpg is no longer available
The attachment SBEmu.jpg is no longer available
The attachment VSBHDASF.jpg is no longer available
Reply 4 of 21, by mihai
very nice build, i love these all in one computers.
i had a machinist board many years ago and was not impressed, but it seems they made good progress on the quality side.
Reply 5 of 21, by DarthSun
DarthSun wrote on 2026-11-17, 22:48:
Szóval akkor folytassuk (régen készen van már, de itt csak 5 kép közölhető egy postban) […]
Configuration:
Machinist MR9S
Xeon E5-2699v3
Chieftec 850W PSU
DOS 6.22
DOS 7.1
Win98 SE
To be continued...
+1 in black and white, since the professional Acer monitor can also be set to grayscale:
The attachment 20260912_145652.jpg is no longer available
Reply 6 of 21, by DarthSun
mihai wrote on 2026-11-17, 22:54:
There was even a positive post; I had actually thought that the "Madness" retro style wasn't known anywhere in the world.
Reply 7 of 21, by Dothan Burger
Dang I just private messaged you about this very thing. I’ll await your future posts as I’m interested in how the audigy works with these new software developments like SBEMU.
Reply 8 of 21, by Condor.07
Perhaps I didn't explain myself well...
I didn't say they don't work; I said they have poor compatibility compared to a PCI sound card like an Aureal or a Yamaha (speaking from personal experience).
As it happens, I have decades of experience.
I have a multiboot system with the following operating systems:
MS-DOS + W311, W95, W98, WME, W2K, WXP, Batocera, Vista, W7, W8.1, W10, W11, OpenIndiana Hipster (MATE), FreeBSD (XFCE), Mint (Cinnamon), EndeavourOS (KDE Plasma), and macOS Monterey 12.
They all boot from a menu without requiring any BIOS parameter changes or monitor signal switching; there are no freezes during startup or shutdown, and everything is installed natively.
That is what I mean by "impressive levels" 😀
I noticed that you installed Windows 98 using "QuickInstall"—so it’s not a clean installation, but rather a pre-packaged bundle.
Furthermore, you have to change your BIOS settings every time you want to boot a different operating system, so it’s not an entirely automated process.
In any case, try running games like *Monkey Island*, *Ultima VII*, or *Falcon* on MS-DOS, and you’ll understand what I mean—the issue isn't the games themselves, but the software being used.
To conclude, I’m not saying your system is "garbage," but it’s simply nothing extraordinary—that’s all.
Reply 9 of 21, by Warlord
Perhaps where the confusion is that when he says "I’ve tested it. It turns out it’s compatible with absolutely everything" What would have been better to say is its compatible with what I play and want to do with it.
Just to chime in, OP only claims the king of OS compatibility. Not the king of games compatibility. He is only stating hey I can run 4 different OS on this build. There can be some improvement here, this thing can run windows 7 and thats not listed. So I would recommend installing windows 7. And ditching windows 11 in favour of windows 10.
The thing about his build though its so powerful pretty much anything can just be emulated anyways and he can run all the wrappers to make anything run under dosbox or some other emulator anyways.
Which brings us full circle here.
Reply 10 of 21, by pete8475
What and why?
aka pete4237.5
Reply 11 of 21, by Condor.07
I couldn't agree more.
I’m the first to support the idea that games shouldn't necessarily be tied to a single operating system.
If they don't run in MS-DOS, I can use DOSBox, Windows XP, and so on...
But when someone tells me, "SBEMU works perfectly, you’re just the one who can’t get it to work"—only to then show me half a game—it just makes me laugh 😀
Not to mention all the other limitations, like the lack of a floppy disk controller, IDE support, and so on...
It’s essentially just a PC running a stripped-down version of Windows 11, containing modded versions of Windows XP and Windows 98—what’s so extraordinary about that?!
In my humble opinion, the sound card is far too modern for retro-gaming.
And don't even get me started on the "professional" motherboard—I assume that’s a joke, right? 😀
I suppose I’m just used to a different standard... that’s my own fault, I guess.
Reply 12 of 21, by DarthSun
Dothan Burger wrote on Yesterday, 00:15:
I’ll check the private message, too, in a moment.
Reply 13 of 21, by DarthSun
Condor.07 wrote on Yesterday, 00:28:
Perhaps I didn't explain myself well... […]
Nice lineup of operating systems you’ve got there!
Things that no longer run on XP will run on Win11, and vice versa—I’ve skipped the ones in between.
Actually, I did try out Master Oerg’s version here; though I can also install the period-correct versions—for instance, that’s how I set it up on a Ryzen system:
The attachment hwiandsandra_Zen2.jpg is no longer available
*Monkey Island*, *Ultima VII*, or *Falcon*—these aren’t really my cup of tea, but I’ll give them a try.
Reply 14 of 21, by DarthSun
Warlord wrote on Yesterday, 04:11:
Perhaps where the confusion is that when he says "I’ve tested it. It turns out it’s compatible with absolutely everything" What […]
That’s true to some extent. Although the systems really do run natively. And yes—it’s one thing that, for instance, *Space Commander* (from '84) runs, but I never claimed it was the king of gaming titles; I did say that *everything* runs, though. I’ll be curious to see how the ones mentioned above perform—I don’t actually play them, I’ll just give them a try.
Reply 15 of 21, by DarthSun
Condor.07 wrote on Yesterday, 04:38:
I couldn't agree more. I’m the first to support the idea that games shouldn't necessarily be tied to a single operating system. […]
No problem; our worldviews just happen to differ a bit. I’m used to the fact that a unique approach always has its critics.
Reply 16 of 21, by DarthSun
pete8475 wrote on Yesterday, 04:33:
What and why?
I posted a link to it here once, but the local moderator deleted it. It contains a serial number, so I assume that’s why. Although, in my opinion, anyone who has the original installation disc or a license should be able to install it...
I can send it to you via private message, if you’d like.
Reply 17 of 21, by DarthSun
I left Linux out of my first post – Garuda/KDE/Wayland ended up being the winner:
The attachment Linux_Desk_screenshot-2026-11-10-02_43_16.jpg is no longer available
The attachment Linux_Control_screenshot-2026-11-10-17_24_29.jpg is no longer available
The attachment Linux_CB15_screenshot-2026-11-09-23_48_23.jpg is no longer available
The attachment MR9S_screenshot-2026-11-15-04_06_20.jpg is no longer available
Reply 18 of 21, by DarthSun
And a bit of Win11:
The attachment Win11_Desk_new_x99_mr9s.jpg is no longer available
The attachment Win11_mr9s_cb20.jpg is no longer available
Reply 19 of 21, by dr_st
No internal optical drive = trash, send it to the landfill 😆
DOS 6.22
DOS 7.1
Win98 SE
You installed 3 DOS versions when you only need one (Win98 SE which includes DOS 7.1). I wonder - why does everyone keep doing that?
Wait, so you are running the modern version of Windows, but an outdated and unpatched build of it? Why? Win10 22H2 I can understand, but Win11 22H2 is out of support and doesn't even get security patches anymore.
On that we agree.
Just kidding. 😉 Do what you want, and don't let people talk you down. Every build is fun. 👍
