First post, by Timecop1983
I've published NitroQuake v0.999 Build 888, an independent GPL-licensed performance-engineering fork of original MS-DOS Quake. Target: i486-compatible CPU with working x87, using the original software renderer at 320x200. The build passes host, ISA and release hash guards; real-hardware runtime qualification remains outstanding.
I'm particularly looking for DX2-66, DX4-100, AMD Am486 and Cyrix DX-class systems. Startup compatibility is as important as FPS: DPMI provider/version, VGA/VBE discovery, installed RAM/cache and sound/TSR configuration.
Download: https://github.com/adrian-andrzjewski/NitroQu … 0.999-build-888
Put NitroQuake.exe in the Quake directory beside your own id1/pak0.pak (registered installs often also have pak1.pak). Run it under DOS with a DPMI host: NitroQuake.exe -nosound -nocdaudio. If video fails, please retry with -stdvid. No Quake PAK assets are shipped.
For timing, please compare the same stock DOS Quake build and Nitro on one physical 486 at 320x200, same viewsize and settings, with audio disabled. Three runs each of timedemo demo1 and demo3 are ideal. Record every FPS result, CPU/clock, motherboard/BIOS, L2 cache, RAM, video adapter/bus, DOS + DPMI version, and any crashes or output differences.
Detailed acceptance procedure: https://github.com/adrian-andrzjewski/NitroQu … 6-ACCEPTANCE.md
Submit results or problems: https://github.com/adrian-andrzjewski/NitroQuake/issues/2
I am the NitroQuake maintainer. If you spot a flawed benchmark assumption, I would also welcome corrections.
Reply 1 of 5, by pyrogx
Quick test run on a AMD 5x86 system:
System: AMD 5x86@160MHz (L1 in WB cache mode), 16MB FPM RAM, 256kB L2 Cache, QDI V4P895P3/SMT (OPTi 895), 40MHz VLB clock, Diamond Stealth 64 DRAM 2MB (S3 864)
OS: DOS 7.1, HIMEM, no EMM386, CWSDPMI 0.90+, UNIVBE 5.1 loaded
Quake: v1.06 shareware
NitroQuake: v0.999, Build 888
Results NitroQuake: demo1: 19.4 / demo3: 17.9
Results Quake: demo1: 16.6 / demo3: 15.6
So a nice uplift in fps over stock Quake on a 486.
Nice work!
Reply 2 of 5, by Timecop1983
pyrogx wrote on Yesterday, 19:30:
Quick test run on a AMD 5x86 system: […]
Nice work!
Thanks!
Reply 3 of 5, by Babasha
Nice work!
Can you try 486quake as third competitor?
Need help? Begin with photo and model of your hardware 😉
Reply 5 of 5, by kingcake
I can try next week. Posting as a reminder.
