Reply 32120 of 32123, by Ozzuneoj
- l33t
I am diving into a big lot of cards that need recapped and I'm running into a dilemma...
To recap all of the cards I need around 130 (or more) through-hole electrolytic capacitors of the same size and value... 1200uf 6.3v, 10mm diameter, 12mm height with 4.5-5mm lead spacing. Seems like the originals were almost entirely from the Sacon FZ series. They are "ultra low ESR", so modern low ESR\Impedance caps have higher impedance but might still be okay. What is killing me is the height.
Availability of 1200uf caps that size seems to be decreasing, and the ones that are available are fairly expensive considering how many I need.
I also need a bunch that are 470uf and 1000uf with an 8mm diameter and 12mm height.
What is annoying is that I have a bunch of good 8mm and 10mm diameter caps that are close enough in spec to work but are 15mm in height. 3mm doesn't seem like much, but on an old card with not a lot else on it, they look awkwardly tall, especially the 8mm ones.
It isn't a huge huge deal... but... ehhh... if I'm going to go through the work, I hate to make them look weird.
Spending a bunch on the caps isn't ideal because the cards also have a fair amount of SMD damage and other things that need repaired, so I have no idea how many will be functional. Replacing leaky through-hole electrolytics is definitely the easy part... it's just the parts that can be somewhat expensive. I don't really want to spend $80 on caps for these cards only to have a small fraction of the cards work.
These Rubycon ZLJ caps would probably work for around 32 cents each (which is... okay I guess), but they impedance isn't as low as the originals, and I don't know if they'd be good enough.
https://www.mouser.com/datasheet/3/3655/1/ZLJ.pdf
ZLH have a little lower impedance for 34 cents each (but have low stock, so wouldn't be available for months):
https://www.mouser.com/datasheet/3/3655/1/ZLH.pdf
Panasonic FS are between the two but are 45 cents each... which is getting up there in price for the quantity I intend to buy.
https://industrial.panasonic.com/cdbs/www-dat … BA0000C1255.pdf
And then, there's the other option... dirt cheap polymer caps, like these Honor Elec ones for 15 cents each...
https://www.lcsc.com/product-detail/C48970363.html
... but then I'll have to pay tariffs on them, and tariff processing fees, etc. Not to mention having to wait a while. And I haven't personally switched anything to polymer caps before. I have heard that the leads are thicker, but as far as I can tell the thickness (0.6mm) and lead spacing (5mm) should be comparable to other caps I've been looking at. But I also don't know if they're reliable or not.
Bleh.
Mostly just venting, but if anyone has any suggestions for affordable (and available) caps that fit the bill, let me know.
