Reply 120 of 135, by kolderman
dosmax wrote on 2026-11-10, 11:53:DOnt't worry, I just miss my custom resolutions and cycles settings. 😀
Not at all, and custom values for some fields in a different way might be a worthy addition, I'll add that to the backlog 😀
Interesting about the staging/glide issue - which version of staging are you using? DFendX makes a distinction between older versions and newer versions, as DOSBox staging had a large rewrite around the 0.82 release. Maybe try the latest version and see if it still occurs?
