First post, by Yoghoo
Not seen a release announcement on Vogons for this yet. Some copy/paste from his site (https://yeold.press/extra-life-2026-wolf3d-re … lt-for-charity/):
It’s Wolfenstein 3-D and Spear of Destiny rebuilt as a 32-bit DOS game, with things the 1992 original never had: four-player co-op and deathmatch over the internet, twice the resolution, distance shading, and sound effects that don’t cut each other off. It comes ready to play on Mac, Windows and Linux: download, double-click, done.
And the rest:
  • Sound mixing: up to 8 sound effects at once.
  • Bigger levels: 600 enemies, 1024 objects, 128 doors.
  • Optional textured floors and ceilings if you like that look: press F on the Change View screen.
  • Ready-made packages with the DOSBox Staging emulator built in, and a floppy installer for real retro PCs.
It's free but a donation is appreciated. The donation goes to Nationwide Children’s Hospital.
Tried the multiplayer (and textures) in DOSBox-X and works great. On my 386SX laptop (with Adlib sound) it hang on the sound card detection screen though.
Reply 1 of 7, by NeoG_
I like this, it's kind of like if there was a re-release of Wolfenstein 3D in 1995
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 2 of 7, by zyzzle
Tried to find a way to contact SirRandel directly, but to no avail.
Unfortunately the 32-bit DOS extender of the game is a packed DOS32/A binary, which makes compatibility very poor on pure DOS systems. It would be much, much better and faster if he just left the binaries uncompressed and didn't stub with the lousy DOS/32a extender and its extremely poor compression compared to UPX.
If anyone can decompress and / or recompile the DOS binaries to uncompressed compiles, it'd be much better. Then, they could be recompressed with UPX and at least 200 kb per binary would be saved verses the horrible built-in DOS32/A unextractable .exe compressor.
Reply 3 of 7, by zyzzle
Follow-up: I can't get this to work in bare metal DOS. It freezes at the start screen, before memory and / or Sound Blaster is detected. I think it's due to the horrible DOS32/A extender. I also can't decompress it and / or use another extender.
Have tried everything: booting clean, with only an XMS drive, with LIMITMEM limiting memory system RAM to 32 or 64mb. Have tried on 5 pure DOS systems with same result.
I of course have both the Wolf v. 1.4 and the Spear of Destiny data files. Still, hard freeze, no way to exit. A shame - due to a lousy buggy DOS extender.
Reply 4 of 7, by NeoG_
It's working on my DOS7/98SE machine with all my usual configs loaded, but unfortunately that doesn't help your situation
Reply 5 of 7, by zapbuzz
waiting for someone to say it works on a pentium 4 😀
Reply 6 of 7, by zyzzle
NeoG_ wrote on Today, 04:04:
Thanks for your report. At least someone has gotten it to work on bare metal DOS. I'll keep trying as many systems as I can and report if I can get it working with the borked DOS extender / compression. For the author seems unwilling or unable to recompile it without the executable compression or a different DOS extender.
Reply 7 of 7, by analog_programmer
zyzzle, I converted these LC-compressed executables to LC-uncompressed format and added the full DOS/32A stub (by using "SB.EXE /B <exec_filename>"), but these new LC-uncompressed format executables can not be compressed with UPX or aPACK at all. I only tested LC-uncompressed WOLF3DR.EXE, since I only have the full version of Wolfenstein 3D installed, and it works fine. I'm attaching them here, if you want to try further conversion from LC-uncompressed to LE/LX format.
P.S. Acutally, I'm surprised how good LC-compression ratio is. I expected something much worse.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
