Reply 160 of 173, by Trashbytes
SupraGSX wrote on 2026-11-15, 08:18:Dimos wrote on 2026-11-15, 07:56:It is mentioned a few posts above that Heaven 4.0 needs an installer from 2013 to run on Xp. Also in supragsx' s case the 3dm06 benchmark produces again some perplexing results. The win 7 score is much higher than the Xp one, although the cpu score is higher on Xp. This again seems pretty strange. Another thing i noticed is the mention of the 1569 mhz boost clock. I really hope that this in fact is the base clock, not the boost one, cause every 1080 ti boosts at least up to the mid 1800s - low 1900s.
No they don't I don't know where you're getting that information? Base clock of 1080ti is 1480mhz. Boost is about 100mhz higher on most cards. I can boost my evga ftw3 card up to about 1950mhz but founders cards are no where near that.
Yeah, the blower cards quite frankly suck at boost clocks, its the 3rd party 1080Ti's with huge beefy coolers that are able to boost higher.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
