Exploring the performance of the Matrox G550
Reply 120 of 123, by vvbee
All kinds of things you can find out. For example the drivers have a short whitelist for games that paletted texture support is exposed to (it's not real paletted texture support), there's hidden registry options for texture filtering, antialiasing, vsync, anisotropic filtering, and others, and there's a bug with 3DMark2000's multitextured fillrate test that causes the test to do extra work unless you set another hidden Matrox registry option. The driver apparently has a relatively complete framework for hw T&L support in OpenGL, so T&L here is presumably not something Matrox threw together for HeadCasting only. Maybe it's G800 code, not just G800 related.
Reply 121 of 123, by vvbee
The G550 overclocking utility is now consolidated into g550tool, which comes with some other functionality as well. Only works with the G550 and only the 6.83 driver.
The attachment g550tool.png is no longer available
Among the functionality is the ability to toggle forced antialiasing and anisotropic filtering.
The attachment g5503dml2kaf640.jpg is no longer available
The attachment g550cmr2aa640.jpg is no longer available
The AA works in some games and has issues in some others. I think 3DMark2000's game 2 uses some kind of portal room rendering system, based on the glitch that forced AA produces in it. Big hit to performance though so I guess most useful with slow CPUs. AF works ok and maybe not ok in some games, but again a big hit to performance.
The tool also includes the option to force hardware T&L, and some fixes to rendering bugs there. Claude did a good job optimizing it so not much performance is lost to the fixes. But some games will still have issues, DX8 in particular. Haven't bothered looking into them yet. There looks to be about 10% of extra hw T&L performance to be had from overclocking; not clear whether it's the core or the Warp clock that affects the T&L unit.
Reply 122 of 123, by dr.zeissler
vvbee wrote on 2026-11-18, 16:12:
Run one of the Quake games instead. If it works then you did it correctly and you have the answer. Don't say it doesn't work without testing it though. I used driver 6.83.
you are talking 6.83 which is Win9x. I was talking Win2k/XP. I'll recheck this because the cracktro-remakes mostly require Win2k/XP.
Reply 123 of 123, by vvbee
I've been talking Windows 9x the whole thread, apart from XP for the PCIe version which this tooling doesn't support. You need to figure out which key the vsync values go under on NT. It's something something, but I haven't checked with an NT-supporting driver.
