First post, by Maraakate
Per subject. Just looking for good pictures of the cleaning kit. I have not seen one listed on eBay. Curious what they look like. The pictures on the old superdisk.com site are so tiny and grainy you'll never be able to make out what it is. Figured there's another SuperDisk nut with crazy hair on vogons that has one NIB sitting on a shelf and can snap a few photos.
Reply 1 of 16, by Ozzuneoj
Around 10 years ago I picked up a whole bunch of brand new cleaning kits (disk + bottle of fluid) that said they were for LS-120 drives, but I just used them to clean normal floppies.
One day a year or two ago, I was trying to read a disk in my original LS-120 drive (came with my Gateway G6-400 in 1999) and it wasn't working well. So, I broke out one of the LS-120 cleaning disks, popped it in, anddd... it instantly destroyed the drive. It seems that LS-120 drives have too much going on in them to just drop in a fuzzy\abrasive cleaning disk. It seems like it snagged on one of the heads and just totally mangled it. I was really bummed because this was always my most reliable LS-120 drive and that system is otherwise still basically original (same hard drive, PSU, motherboard, etc.) after almost 28 years.
In other words... if any cleaning disks advertise LS-120\LS-240 usage, I would not believe them. If there is a way to reliably clean an LS-120 head, an old-school head-cleaning floppy is not it.
I still have some of them around, though the plastic packages that contained each disk+fluid kit disintegrated in storage for some reason. I will see if I can dig up a picture of the kits themselves because the loose disks don't really look like much and don't even have a brand on them. It's just a blue floppy with a fabric disk inside it, no metal dust shield, and a generic looking white label that says "For LS-120" and "SuperDisk Cleaner", plus some basic instructions about replacing it when it gets worn.
Reply 2 of 16, by Maraakate
If I was to use one it would only be the official one from Imation. Even so, I would likely just take the unit apart to clean the head carefully by hand with a cotton ball or similar before resorting to any cleaning disks. With the age of them it's likely they could disintegrate and dislodge on the heads and make it worse. More for collecting.
Reply 3 of 16, by Trashbytes
Maraakate wrote on Yesterday, 23:02:
There is a good reason why you wont find one in the wild, the cleaning disks can and did damage the drive heads by fouling them up with fibers from the disk due to how the LS120 drive heads are designed.
Even if you found one I would not recommend to ever use it on a working LS120, its easy enough to clean the heads yourself manually and safer for the still working drives. Even the official Imitation ones by this point would be unsafe to use, these disks do degrade overtime.
DSC_0036.jpg <--You can see the fibers in the heads here.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 4 of 16, by Maraakate
I understand. I just want to know what it looked like and if I found it would be for collecting. I have some old cartridge cleaners for NES, etc. for fun on display. I would not use any of that stuff seriously. It's just going to dislodge and cause more problems than it solves with it being 30-40+ years old.
Reply 5 of 16, by Trashbytes
Maraakate wrote on Today, 01:00:
Oh if that's the case then go for it !
Cant say I've ever seen anyone want to put a cleaning disk on display but with how rare the official ones are it would be a cool talking point.
Reply 6 of 16, by Maraakate
Used to be easy to find this kind of junk years ago at Goodwill, etc. but I just said what it is... junk. Kinda quirky and funny to have on the shelf with the rest of it. I also just find it kind of funny that there's no pictures of the Imation cleaner itself anywhere. Not even old Amazon listings. You can find practically everything else via UPC from them with this stuff.
Reply 7 of 16, by Maraakate
Ozzuneoj wrote on Today, 00:54:
I still have some of them around, thought the plastic packages that contained each disk+fluid kit disintegrated in storage for some reason. I will see if I can dig up a picture of the kits in themselves because the loose disks don't really look like much and don't even have a brand on them. It's just a blue floppy with a fabric disk inside it, no metal dust shield, and a generic looking white label that says "For LS-120" and "SuperDisk Cleaner", plus some basic instructions about replacing it when it gets worn.
I see you edited your post. If you still have any of it with the pictures I'm curious. Especially UPC codes. The Superdisk site had something listed curious if it matches up.
Reply 8 of 16, by Ozzuneoj
Maraakate wrote on Today, 01:07:
If you're looking for official Imation ones as a display piece, then this is probably not what you're looking for, but I was able to find this picture I took years ago when I was selling a few (since I had more than I'd ever use). They are Lindy brand, not official Imation. In this picture the disk itself is covered up, but it basically just has a simple label with the words I mentioned previously.
I'm guessing they repackaged these to just say "Floppy" on the outside since they were destroying LS-120 drives.
Reply 9 of 16, by Maraakate
Ah yeah. I've seen those before. Thanks for taking the time to dig up the pics anyways.
Reply 10 of 16, by Ozzuneoj
Maraakate wrote on Today, 02:24:
Actually, thank you for asking!
While searching for this I realized I had a 5-month hole in my locally stored photos from 2019 because I upgraded phones in July of that year and later on I must have deleted a folder that I thought was redundant. If I hadn't been looking for a picture of this kit, I likely wouldn't have caught this for much longer.
Thankfully, it looks like most or all of them are stored in the cloud, so I can make a proper local backup of them now.
Whew. Glad I caught it when I did. 😀
Reply 11 of 16, by Maraakate
Hah. Glad it worked out!
Reply 12 of 16, by DaveDDS
Been years since I had an LS-120 , but IIRC it could read standard 3.5" disks - so presumable a 3.5" cleaning disk would "fit", but I've seen several reports that they can get caught on the head doing damage.
As cleaning disks have gotten harder to find, I've had to resort to making them a couple of times, basically empty a disk case a cut a piece of paper in the exact shape/circle of the media and insert it.
Much easier with 5.25" disks, but depending on how the drive "grips" the center I have gotten them to work on 3.5"
If you want to try this, I'd use as thin and smooth paper as possible that hopefully "catch" - it wouldn't clean as well as the soft/lumpy material normally in cleaning disks, but would possible have much less chance of damaging heads.
But... for something as easily damaged/less replaceable as an LS-120, I'd probably disassemble the drive and clean the heads manually (no idea how touch this would be - not seen an LS-120 in many years)
If you really want to use a cleaning disk, I'd do it unpowered and rotate the spindle slowly/carefully by hand (if even possible on LS-120)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 13 of 16, by Trashbytes
DaveDDS wrote on Today, 03:20:
Been years since I had an LS-120 , but IIRC it could read standard 3.5" disks - so presumable a 3.5" cleaning disk would "fit", […]
You cant use a normal 1.44 head cleaning disk in the LS120, that will actually do damage to the drive heads, the LS120 cleaning disks use a different cleaning fabric to the normal 1.44 ones.
Doing it manually is the safest option these days.
Reply 14 of 16, by Maraakate
I don't. It's to know what the official one looked like and for collectability. I would not rely on it to clean the drive. Especially now considering how old and hard to find this stuff is getting.
Reply 16 of 16, by Trashbytes
Looks pretty damn close, you can see the different material they used on the cleaning disks and the official ones never had doors on them.
I feel Japan is likely the only place that will have one of these kits.
