First post, by Mondodimotori
Apparently I can't catch a break with hardware problems.
I got myself two floppy drives (one came with the cable too) and, while one is 100% DOA (a SONY unit from 2008 it won't read/format any disk I threw at it on any machine), the other unit is acting in a pretty weird manner.
To test it, I copied some files on a couple of discs using the floppy drive on one of my old PCs.
I just put the virgin disk in it, and it just copy the files on it no problems. It doesn't ask me to format them before or anything else. And I can even format disks on it no problem.
I then go to the other drive I just bought, a TEAC FD-235HF hoocked up to another one of my machines, and I put in the floppy. At first everything seems OK, I can see the files just fine, and I can even copy very small files off of it (up to 100 or something kilobytes). But if I try copy bigger files, or smaller files I copy when I'm in the last sectors of the disc, it will fail, throwing me several blue screen errors.
But here's the catch: If I put a virgin disk in it, or I format an used disk with it, it will happily copy all the files to fill up the entire disk, and I can copy them back on the same PC no problem.
But here's the even bigger catch: If I then take those disks, the former virgin one and the one formatted with the TEAC, and I put them back into my old PC, then itself will start going nuts and failing to copy bigger files or files that are stored in the last sectors of the disk.
It's like there's some sort of misallignment between the two drives when reading/writing and even formatting the discs, especially in the last sectors of the disk.
I've alredy opened the TEAC unit to take a look at it, but nothing seems out of the ordinary.
Is it possible that something is out of allignment between the two units? Because they appear to be working on their own. But, as soon as I try to swap files between them, things fail.
I have to point out that I have never opened the floppy drive I alredy have in my old PC. And the TEAC unit was threwig me temper tantrums even before I opened it the first time.
The seller has offered me to send in another unit, but I've told him to wait just a little until I sord out this situation. Because I can't reliably use this TEAC floppy drive to install the OS on my Slot 1 system or, god forbid, update the BIOS, if I can't reliably copy files between it and another floppy drive.
At this point I can't even exclude issues with the floppy drive I alredy have in this old PC of mine, since I don't have a third working unit to use as a fail safe to see if it would accept the formatted disks from either one of the units I alredy have.
Have you ever experienced similar issues regarding floppy drives?
Reply 1 of 12, by Tiido
It definitely appears that one of the drives is misaligned. If you have floppies such as install disks that were written at a factory, you can which of these drives struggles. The one that does should be the misaligned one...
Years ago I threw out a bunch of floppies because of a misaligned drive, before I even knew this was a thing...
Reply 2 of 12, by ott
Mondodimotori wrote on 2026-11-21, 17:55:
Interesting, but how did you verify this?
As far as I recall, Windows can cache files in RAM during the copying.
I would suggest restarting computer and attempting to copy files from the floppy again, just to rule out any caching.
Reply 3 of 12, by DaveDDS
Most common causes of floppy failure are:
- Dirt/crud on the heads
- Misalignment
If the first, it won't be able to format, write or read it's own disks.
If the second, it will most likely be able to format/write/read it's own disks(*) but not read those written by other known good drives.
(*) Alignment problems means the heads don't line up correctly with the track positions on the media.
Tracks are "soft" which means they exist where the writing drive put them - hence you can usually read your own tracks.
!BUT! if the drive it really badly aligned, heads positions can actually get outside of the media, or "hit" other drive parts - very rare, but I have seen it occur.
As always I recommend using my ImageDisk tool to diagnose and fix drives.
It has a very good "clean heads" function which unlike the short immobile "spin" you get from trying to access a cleaning disk by listing it's directory, will actually keep the disk spinning and "scrub" the heads back and forth over the cleaning media.
Aligning a drive is quite tricky even if you have an alignment disk and an oscilloscope - and generally considered "impossible" without those tools...
ImageDisk has a "Test/Align" function which among other things I've had good results aligning with known good media (like a software distribution disk from one of the well-known companies)
It will also let you do individual operations (like seek, read/write/format track, home to track0) and reports a lot more than just "disk fail".
(It communicates directly with the FDC hardware and is not limited to what the OS developer decided you might want to do/know with diskettes).
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 4 of 12, by wbahnassi
Yeah classic symptoms of head misalignment. Grab a factory disk and run it (write-protected) against both drives. The drive that fails is out of alignment.
If these are 3.5" drives, then alignment is quite easy on them usually. The head stepper motor is usually fixed by two screws on the back of the drive. Loosening those screws allows the motor to be twisted left or right by a certain amount. You can twist it while ImageDisk's alignment tool is active to hopefully get a better alignment. Just seek to something like track 60 and twist the motor until IMD says it is reading 18 sectors succesfully on track 60. Then tighten the screws again and you're done.
This is a crude alignment process.. a more accurate one will require an oscilloscope and some deeper knowledge of the control board of the disk.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 5 of 12, by DaveDDS
wbahnassi wrote on 2026-11-21, 20:53:
.... Just seek to something like track 60 and twist the motor until IMD says it is reading 18 sectors succesfully on track 60. Then tighten the screws again and you're done.
Just to add a couple notes.
Successful read is a "range" - find the positions where reads start to fail, then lock it 1/2 way between.
I usually do initial alignment at the 1/2 way point (track 40 for 80t drives, 20 for 40t drives)
Also check it a few tracks in from each end - I've seen drives where the alignment "drifts" from one end to the other.
Sometimes it's a bit of a process testing at various points and finding the best compromise between them.
Reply 6 of 12, by Mondodimotori
Tiido wrote on 2026-11-21, 18:01:
DaveDDS wrote on 2026-11-21, 20:44:
Most common causes of floppy failure are: […]
- Misalignment
Yeah, I suspected that could've been the case. Unfortunately I don't have any factory discs around to test this, maybe I should buy some cheap software on "floppy" online? Because without a third drive to test them against I can't pinpoint wich unit is the misalligned one. Now, it probably is the TEAC unit I just got, since I did opened it when it started giving me problems initially.
Also, if "Dirt/crud on the heads" results in not being able format, write or read the disks, I could use this ImageDisk tool to try and clean the heads on the two actually broken floppy drives I got, and if able to fix them use them to test! It should work on Windows Me, right?
Anyway, If I'm succesfull in restoring those dead drives, I may actually try to allign the defective unit. I just hope it's not both of them with different misallignments. The floppy drive in my old PC never left it's case since I got it new in 2001, but it was moved several times, last time two years ago for well over 800km... So who's to say that the floppy drive didn't misallign itself during transit?
ott wrote on 2026-11-21, 19:07:
I did the "shift+del" combo to destroy the file, but I've also tried copying them in other folders on the PC, not the same location from which I had deleted them.
DaveDDS wrote on 2026-11-21, 21:16:
Just to add a couple notes. […]
Yeah, By my testings with small files it appears that the drift happens in the later sectors of the disk, since I'm able to copy the first few files copied on the disk, but it fails once it get past half the storage capacity.
Reply 7 of 12, by DaveDDS
Mondodimotori wrote on Yesterday, 12:48:
... Unfortunately I don't have any factory discs around to test this, maybe I should buy some cheap software on "floppy" online? Because without a third drive to test them against I can't pinpoint wich unit is the misalligned one. ...
I guess what it comes down to is "what do you want to read?" - If you have disks written in the past by working drives, that's a reasonable place to start.
If you don't have any existing disks ... In todays world where floppies are not really used for software distribution, you really only need to be aligned with yourself.
As long as the two drives can read/write each others disks you're probably "good enough" - only if you want to read disks from other sources or send disks you've written to others will "correct" alignment position be a factor.
Btw, I caution you on relying on the alignment of disks from "cheap software vendors" ... often these are just written on "average" systems where the drives only get replaces if they exhibit problems (and this is pretty much how ALL software on floppy is made now). Back in the day when major software was routinely distributed on floppy, well the "big" companies either used a mass replication service, or maintained production quality systems of them own to write the disks - these would have been maintained and tested with proper alignment media and procedures.
If you can read a good portion of the disk, contamination of the heads if likely NOT a major problem.
Dirt on heads is typically "effective" over all tracks (it's the same head no matter where it is positioned)
Reply 8 of 12, by Mondodimotori
DaveDDS wrote on Yesterday, 13:29:
I guess what it comes down to is "what do you want to read?" - If you have disks written in the past by working drives, that's a […]
Oh yeah yeah, of course. I was actually looking to buy original "DOS" installation discs, or other vintage Microsoft producs. I was able to find some of them cheap enough, even tested. They should be a good starting point for "good factory discs". Unfortunately I don't have floppy I wrote in the past around. At least not here. Maybe at my parent's house, but who knows how they were stored in the past 25 years. I recall stopping the use of floppy pretty early and switching to a USB thumb drive.
That's for sure, I'm not worried about dirt on the two misalligned units. The dirt problem is, probably, in two other floppy drives I have, one bought now and one from another old PC I recovered in my family. If those are just dirty and can be fixed, I could use them to test the allignment on the two problematic units.
I read that your software doesn't run on Windows NT, including 2000. What about 9x? I don't have a full DOS installation, but I have a couple of PCs running Windows Me. Would that be enogh?
Reply 9 of 12, by DaveDDS
I'll answer you in kinda reverse order.
ImageDisk accesses the PC floppy controller hardware directly, and pretty much all versions of Winblows have protection systems in place to prevent such direct access. Some IMD functions are also fairly real-time sensitive and "background" operations in multitasking operating systems can throw them off.
Therefore ImageDisk runs under DOS - no protection or background activity problems (If your system loads TSRs and other "stuff" at boot, I recommend using the ImageDisk bootable DOS floppy image I created and offer on my site).
Unfortunately , if you don't have a working floppy drive, you can't use any boot floppy.
The good news (if you have Win95 or 98) is that you can "Restart in DOS mode" - this will reboot your system into DOS - In this case I suggest putting the ImageDisk files in a root level subdirectory without "long" filenames, as deeply nested stuff can be tricky to get to.
The important thing is to get one (or more) drives working reliably - even if not aligned.
Assuming you can get ImageDisk working, it has a Align/Test function which can seek to any arbitrary track, will report the state of the track-0 sensor , and can format/write/read tracks.
Basically you want to get the drive "aligned" enough that you can seek over it's range without the head assembly hitting either end, and having the track-0 sensor activating only when positioned to track-0.
If you can get a drive into this state, and it has no other problems, you should be able to format/write/read whole disks without problems (just like you could on any fully working drive) - note: do "full format", not a "reformat" - "full" formats every track and creates a new blank file system, "reformat" just makes the existing file-system look empty.
You could later "align" the drive to any known good distribution disks you might buy.
- I'd still clean the heads (manually if needed) so no "unseen" crud on the heads risks damaging these actual "vintage" disks. In fact, if you know anyone with a good working floppy, best to have them make you some less-valuable disks to work with at first.
- Also be aware that "old" media can get damaged a lot easier - it can "flake" off the "disc" material, really a good idea to limit accessing it as much as possible.
I tend to at least copy old discs I want to keep to newer media to work with, and even better: make images of it so that you can recreate it at any time.
Reply 10 of 12, by Mondodimotori
DaveDDS wrote on Today, 02:07:
I'll answer you in kinda reverse order. […]
Well, guess I'm stuck. I don't have a Win95 or 98 install to boot into DOS, just Me. I also don't know anyone else locally with working floppy drives. And without working floppy drives I can't install 95 or 98.
Now, the situation is: I have four floppy drives, two that aren't compatible between thems (meaning either one or both are misalligned), and two that are (probably) so dirty they'll refuse to read/format any disk.
I'll try with some canned compressed air first on these, to see if they can be made to work again. If succesfull, I'll use them to test the allignment of the other two drives. After that I'll finally perform the Windows95 install on that Slot 1 system I mentioned, thus I'll have a working DOS environmet to use your software.
Does this plan compute?
Reply 11 of 12, by DaveDDS
I wouldn't "bother" installing Win95 or 98 (unless you want one of them), If you can get to the point where you could do that, then you could just boot DOS directly - DOS does not need to be "installed" to use ImageDisk - it all fits nicely on single boot floppy!
Do you have a CD/DVD drive? If yes, do you have (or know anyone who has) the ability to write a .ISO to optical media?
The distribution of the ImageDisk boot floppy that I've made available on "Daves Old Computers" has a few tools to make bootable media:
- XDISK - write Image to an actual floppy from DOS
- DSKWRITE - "" from WinNT based (tested with XP, 7 etc.)
- ISO.BIN - append (copy/b ISO.BIN+...) image to this to make a bootable ISO
IIRC you mentioned that you have a drive that works for some tracks at the start but not over the whole disk. Do you know how many tracks on it work?
We might be able to get enough of a system to boot - DOS only needs tracks at the start of a disk, and ImageDisk is reasonable small (17k)
Can you tell me exactly what you have available in:
- Systems incl how much RAM (ImageDisk boot floppy set itself up to run from a RamDisk - so you can change floppies)
- Types of drives (floppies and optical)
- Communication ability (network, serial etc. - there are more ways to get things onto a DOS boot)
I've not looked at WinME in years - but IIRC MS disabled "reboot to DOS" but there was a patch tool available called "WinMeDos" that would enable "reboot to DOS".
Reply 12 of 12, by Mondodimotori
DaveDDS wrote on Today, 12:12:
I wouldn't "bother" installing Win95 or 98 (unless you want one of them), If you can get to the point where you could do that, t […]
If I can boot it off a CD, and run the software off of it, I can do that. I have blank CDs and a CD burner. Would using something like "Rufus" work to create a bootable CD?
About ram, if I can boot of a CD, both PCs I would likely use to do the test have 512mb.
About floppy drives, the issue is: On two of them I can't copy large files between them, but if I format a disk with one of them, it will work in that drive all the way to the end of the disk. They will work with one another only for about half the storage on the floppy disc. If I go past around half (or two thirds) of the disc, if it was formatted/created with the other floppy drive, it'll fail.
Two other floppy drives I have won't read/format any disks. I'll try cleaning them with canned compressed air before.
If the bootable CD route is viable, I can do everything off of it whit every floppy drive connected, since I should be able to use at least two PCs to do so.
