Yamaha XG emulation at last
Reply 360 of 383, by hockinsk
End user would use Halion Sonic which is free, you only need Halion full version to build and edit the library. That's how i remember it anyway.
Reply 361 of 383, by hockinsk
Mapping XG / AWM2 onto SoundFont Extended (SFe 4) — what fits and what doesn't
I went through the SFe 4 spec to see how cleanly the real XG voice set / MUXG2K's AWM2 engine maps onto it. Short version: SFe 4 fixes most of the plumbing problems that made XG awkward in plain SF2, but its synthesis model is still literally SF2.04 (the spec says so outright), so a few things still don't have a home.
What SFe 4 actually changes (vs SF2.04): 64-bit chunks for huge banks, split bank addressing (wBank → byBankMSB + byBankLSB), variable bit depth + OGG/FLAC compression, UTF-8 names, and a redefinable default-modulator list (DMOD). Generators/units/filter model are unchanged.
The clean fits
  • []Voice → Preset → Instrument (1:1)
    []Bank MSB / LSB / program → byBankMSB / byBankLSB / preset#. Splits the bank word, maps 1:1 onto XG's CC0/CC32. Biggest win vs SF2 (no bank-128 drum hack).
    []Drum kits (MSB 126/127) → percussion bank-select flags — addressed by bank-select like XG, not a hardcoded bank.
    []Element (up to 4) → Instrument zones, one per element.
    []Sample → shdr, 16-bit PCM (OGG/FLAC optional).
    []Key / vel split → keyRange / velRange.
    []Pan → pan (0.1% units).
    []Base cutoff → initialFilterFc, in absolute cents: cents = 1200 · log2(Hz / 8.176). This is the per-voice anchor.
    []Resonance → initialFilterQ (cB).
    []Amp envelope (DAHDSR) → volume-envelope generators (convert AWM2 rates to timecents).
    []Same-note choke → exclusiveClass (= drum choke groups).
    []Reverb / chorus → reverbEffectsSend / chorusEffectsSend (send level only).
Where SFe got XG right
It adds the XG sound-controller CCs as default modulators, overridable per-bank via DMOD:
  • []CC74 → cutoff: SFe default is 6000 absolute cents (~94 cents/step). On real MU hardware I measured 75 cents/step, so override to ~4800 cents to match.
    []CC71 → resonance, CC73 → attack, CC72 → release all have defaults; CC75 → decay you add yourself.
  • Heads up: SFe removes SF2's default velocity→cutoff modulator (it flags itself with isng = "SFE 4"), so you add velocity-brightness explicitly.
What still doesn't map (SF2.04 model ceiling)
  1. []Filter key-tracking — no generator for "cutoff follows key." AWM2 does this. Workaround: bake it into multiple key-split zones with stepped initialFilterFc. Most tedious part.
    []Separate pitch + filter envelopes — SF2 has one mod-env feeding both. The MU runs independent PEG and FEG. You get one faithfully, or a compromise.
    []Variation / insertion effects — no equivalent. You get a reverb/chorus send level and nothing else; the MU's actual FX algorithms live outside the format.
    []Velocity→cutoff curve — MU uses a piecewise multi-point curve; SF only has fixed linear/concave/convex/switch shapes. Approximate or bake into velocity zones.
So the bank addressing and the XG-shaped default modulators are genuinely well-suited to an XG dump — feels like they had this use case in mind. The limits are SF2.04's synth model, not SFe's container.
Happy to share measured per-voice cutoff anchors (in Hz) for specific voices if anyone's actually building one of these.
Reply 363 of 383, by gmaverick2k
Just listened to descent midis. I prefer the MU90 real mode 😜
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 364 of 383, by zaphod77
well, yes, a mu90 will be better than a fake mu50. 😀
That's not exactly fair. but it's pretty darn close.
that said, a bug was introduced again. hopefully it will be fixed soon.
Reply 365 of 383, by zaphod77
A note for people on the fence about getting muxg2k.
The linux version supports both x86-64 and aarch64. i have no idea if any arm SBCs can handle it, btu that owdl certainly be an interestign test. a pi-xg2000 would be quite interesting...
Since the osx version is similar in size, i assume it also supports intel macs and apple silicon.
The windows version seems to be x86-64 only.
Reply 366 of 383, by hockinsk
MUXG2K releases on Monday and include X86 and ARM64 Windows. More info on PI later when I have tested some more.
Thank you to everyone who has contributed, tested, and provided feedback along the way.
A little demo here of one of the better MU2000 MIDI songs made called GolGoal which was part of XG Sound World competition back in the day.
MUXG2K is not an emulator. It's a native DSP engine, built from the ground up to faithfully recreate the voices, synthesis behaviour, and effects of the Yamaha MU2000
https://www.youtube.com/watch?v=TM3Gyx7jtdE
Reply 367 of 383, by zapbuzz
i gots my XG synthesizer keyboard, XG Softsynths for win 9x and XP and a vst on win 11 😀
Reply 368 of 383, by hockinsk
I've rendered all 47 finalists' MIDI compositions from Yamaha's XG Sound World competitions (1997–2002) through the demix.me MUXG2K synthesizer.
These tracks represent some of the finest examples of XG MIDI programming ever produced and were used extensively throughout MUXG2K's three-year development to help faithfully recreate the sound of the original Yamaha MU2000EX.
MUXG2K Synthesizer:
https://www.demix.me/muxg2k/
Yamaha's retrospective:
https://uk.yamaha.com/en/musical-instruments/ … cdotes/014.html
Listen to all 47 MIDI renderings:
https://www.youtube.com/watch?v=mbbkBHJlsIs&l … t=PLNboOeeMzlqQ
Reply 369 of 383, by Lord Myn
I've just bought a licence for the MUXG2K and it's fantastic (I'm big fan of the retro XG/GS compatible wavetable synths). But I'm awared an issue for the variation delay effect, the delay time sometimes seems to be the half of the given amount and for that some XG MIDI sounds weird. Is it a question of settings or a bug? I'm using the 1.0.0-b12 Beta version.
Reply 370 of 383, by zaphod77
send him the midi file that showcases the bug. Did you compare with s-mu2000, or real hardware?
Reply 371 of 383, by zaphod77
oh.... seems 1.0.0 is out now.
Reply 372 of 383, by tcaud
Any progress on replacing the sounds in the SYXG-50 TBL files?
Reply 373 of 383, by Falcosoft
tcaud wrote on 2026-11-19, 05:17:
Yes:
https://github.com/NightFright2k19/SXG-Create-NF
Website, Youtube
VST Midi Driver Midi Mapper
Reply 374 of 383, by Lord Myn
zaphod77 wrote on 2026-11-18, 17:11:
Ok, thank you I'll send him, as well as try out the final version.
No, I have neither the real hardware, nor the s-mu2000, but I did compare with S-YXG50 and it played fine (and that's the original, because I had a Guillemot Maxi Sound Fortissimo PCI card before).
Reply 375 of 383, by zaphod77
It's likely fixed in final.
Another big pass was ran using a big contest of XG midi for accuracy.
There is a 14 day free trial, but the forever free version is now apparently GM only. (ouch. no ff7 midi testing without the 14 day trial)
Reply 376 of 383, by tcaud
zaphod77 wrote on 2026-11-19, 19:12:
$114 USD and some cents... strange number, though I guess it does it's job: priced high enough to scare away non-mu2000 owners and stay off Yamaha's competitive radar.
Didn't sound any different from the SYXG-50 to me though, and as far as general MIDI Yahama PCM goes, we already got Martinic TG100. I guess DOSBox users will be happy though.
Reply 377 of 383, by zaphod77
the number is less strange before conversion from pounds.
I think most actual owners would prefer s-mu2000.
Reply 378 of 383, by hockinsk
MUXG2K 1.1 is out now. It fixes the last voice, effects and calibration issues reported in 1.0. It also includes the reworked voice engine.
Before, each voice was processed on its own, one sample at a time. Now voices are processed in groups of eight, which is how modern processors like to work.
Each voice's controls (envelopes, LFOs, filter movement) now update on a steady 32-sample clock. That's about 14 times finer than the MU2000's hardware and firmware, which update in fairly coarse steps. Getting past that stepping was the main aim for DAW use and audio rate control, simply impossible in MIDI 1.0.
Why this matters for gaming
The engine is now well set up for the lighter processing a gaming build needs. Once the processing that only matters in a DAW is taken out, it will be lighter still.
The gaming version working title: XGFIFTY because it will offer similar to an MU50 unit.
It will be built for 32-bit and 64-bit systems, including Raspberry Pi.
It shows up as a MIDI device that games and emulators can play straight into, with no virtual cable:
Linux: an ALSA sequencer port
macOS: a CoreMIDI virtual destination
Windows: a WinMM MIDI driver for x86, x64 and ARM64. It will also work with the new Windows MIDI Services, due in February.
It's written in plain native C++, without MAME, JUCE or the Steinberg SDKs. It comes as a standalone app, plus a CLAP plug-in for hosts that load plug-ins.
There's no release date yet. I'll post again when there's something to test.
Here's a pretty graph for where the performance is looking at the moment for MUXG2K playing all 16 voice ports in a song, with FX etc. I'd expect a 30-40% lighter single core CPU again for XGFIFTY.
Reply 379 of 383, by hockinsk
tcaud wrote on 2026-11-20, 02:21:
SYXG50 made several 'optimisations' such as switching to a simple generic filter so there are audible differences, but obviously it's very close, it's the same samples underneath so the sound itself is close, not so much for drums though obviously.
Key difference are SYXG50 used 8-bit PCM, 2-tap linear interpolation, whereas MUXG2K is 16-bit upto 32-tap, so much higher control rate through the engine.
SYXG50 has one simple Chamberlin SVF for everything with fixed Q and cutoff is ramped per block; a no-filter voice path is chosen at note-on, MUXG2K employs Filter, envelope and control models matched to the hardware across each voice, not just one filter across everything.
SYXG50 frees notes below -48dB, MUXG2K voice stops below −96 dB, and only when it's safe: release stage, not quiet only because of CC7/CC11, no amp LFO, not feeding a distortion-type effect. This is very audible.
SYXG50 floats are mixed straight into 8 effect buses; no per-part buffers. MUXG2K uses per-part buses with smoothed CC7/CC11, pan and send changes, up to 64 parts.
To summarise : S-YXG50 saves CPU by being less accurate (coarse control steps, early voice cut-off, cheap effects and sample economic single filter)
Stripe converts to your local currency. £129 (35% off for launch and black friday).
Yamaha know about MUXG2K synth, there's no radar to duck.
XGFIFTY I hope to be more like £40-60
