First post, by jude1977
i have a old 80s Macintosh im trying to wright a img image file to floppy disk using my grease weezle on my windows 10 pc
so i can use it on my old 80s Macintosh but every time i try to use flux my floppy program to wright the image it gives a error message saying
T0.0: Writing Track (Verify Failure: Retry #1)
T0.0: Writing Track (Verify Failure: Retry #2)
T0.0: Writing Track (Verify Failure: Retry #3)
** FATAL ERROR:
Failed to verify Track 0.0
im using a high density disk but i have taped over the security hole with tape as i have heard that tricks the computer to think is a
double density disk
would any one have some suggestions on what i could do to fix this problem
Reply 1 of 2, by NeilKnows
DD ("1MB") and HD ("2MB") disks have slightly different magnetic properties. Also HD drives have narrower read/write heads compared to SD drives so it's always best to use the correct media for the target. Faking a 1MB disk from a 2MB disk does not always work as you have discovered . Can you get hold of any DD disks?
Reply 2 of 2, by jude1977
hi thanks for your reply i have ordered some dd floppy disks on ebay im just waiting for them should be a couple
of days before i get them in mail the only thing is there pc dd floppys there is hd mac disks on ebay but i dont know if i should try them as well
