Reply 40 of 45, by Shiftyy
King of compatibility, but only for the games you care for?
There is nothing special about this build.
Reply 41 of 45, by DarthSun
Shiftyy wrote on 55 minutes ago:
Nemsokára próbálok olyan címet is, amit nem használok, illetve amit fentebb említettek.
Amúgy nagyon király a gép, szerénytelenül a világ egyik legjobbja retróra és modernre is, nem tudod elvenni a kedvemet te sem 225621_qgmh195rweclckwm_pngimg_com_smiley_png176.png
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 42 of 45, by DarthSun
I did run into some trouble with AIDA under Win3.11. Between the 16-bit/32-bit issues and the fact that the "retro" versions either won't run at all or display incorrect data, it was a struggle.
I saved a screenshot and a log file from the DOS version of HWinfo, then loaded them into Paint and Write within the Win3.11 environment.
The attachment HWInfoDOS.jpg is no longer available
The attachment W311_HWi_Write.jpg is no longer available
Reply 43 of 45, by Shiftyy
DarthSun wrote on 34 minutes ago:
Nemsokára próbálok olyan címet is, amit nem használok, illetve amit fentebb említettek. […]
What's special about it?
Reply 44 of 45, by DarthSun
Shiftyy wrote on 23 minutes ago:
Pretty much everything 😀
Reply 45 of 45, by Shiftyy
DarthSun wrote on 17 minutes ago:
Like?
