Windows 98 - Sound Drivers installed but no sound
Reply 40 of 60, by Shiftyy
TheMysteriousGray wrote on 2026-11-24, 02:32:
https://www.dfi-itox.com/tib/TIB-G4E620-N-G-01.htm
I found a technical bulletin from DFI showing that there was some kind of hardware change to the transistors that, alongside adding some kind of protection circuit for the USB ports, necessitated a BIOS update that was never documented and is exclusive to this hardware revision. This must be a very late-model copy of this board.
That's a good find. Maybe hold off downgrading the BIOS then. I would still try and dump it since it's undocumented.
Let us know how the Awe64 goes.
Reply 41 of 60, by TheMysteriousGray
I’ll dump the ROM tomorrow, but out of pure curiosity I put the AWE64 back in and got the drivers reinstalled in Win98. This is what I got.
The attachment D97E52B4-0443-48E2-B0A5-BDB1224B17C8.jpeg is no longer available
This is what I got when IRQ5 was set to Legacy ISA. The Audigy 2 ZS is on IRQ3, and IRQs 5 and 7 are Legacy and both are listed as N/A.
The attachment B2860672-BB19-430C-9A07-5C621D773330.jpeg is no longer available
This is what happens when IRQ5 is set to PnP. The Audigy 2 ZS leaps to take IRQ5, and although the AWE64 reconfigures itself in Win98 to take IRQ7 (including switching DMAs and the port to 240), the BIOS still lists it as having no IRQ.
Reply 42 of 60, by Shiftyy
TheMysteriousGray wrote on 2026-11-24, 03:29:
I’ll dump the ROM tomorrow, but out of pure curiosity I put the AWE64 back in and got the drivers reinstalled in Win98. This is […]
The bios not showing the Awe64 is interesting. Not sure why it's doing that. Have you tried Unisound? It's a good utility for initializing PnP cards. Best to try it out in pure DOS rather than 98.
There is a setting in your BIOS, Frequency/Voltage Control > CPU Host/3V66/PCI Clock. Can you let me know what options/presets it presents to you?
I wonder if the newer board revision and bios has something to do with the problem.
Reply 43 of 60, by NeoG_
Shiftyy wrote on 2026-11-24, 03:47:
I believe it's because PnP OS Installed is set to Yes, the entire BIOS ISA PnP section is missing from the list. When set to No it should appear.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 44 of 60, by TheMysteriousGray
I removed the Audigy 2 ZS, set all IRQs back to PnP, and configured the AWE64 to use IRQ7 with the same DMA interrupts, and now suddenly the card is working! I get Sound Blaster audio in Duke3D and Windows sound files play! The card does stutter a bit when starting the system up, but by God, it works!!
Reply 45 of 60, by NeoG_
TheMysteriousGray wrote on 2026-11-24, 03:56:
There must be an issue causing no communication on IRQ5 specifically. Oh well if you had to be stuck at a specific IRQ, 7 is better for compatibility with older DOS titles so you kinda won that battle.
Audio stuttering on the startup sound is common for some combinations of sound card and other devices IMO. E.G. I had it when using an ISA ES1869F but not with an SB Live in the same computer.
Reply 46 of 60, by Shiftyy
NeoG_ wrote on 2026-11-24, 03:55:
Right. You should turn that off and let the BIOS handle PnP.
Reply 47 of 60, by TheMysteriousGray
I tried configuring the AWE64 for IRQ5 when it was the only card in the system, but IRQ5 is one of the ACPI Steering IRQs apparently so it wouldn’t let me force-assign to it even though nothing was sharing that IRQ at all otherwise. This would explain why the Audigy 2 kept trying to take it when IRQ5 was set to PnP.
Reply 48 of 60, by TheMysteriousGray
A brand new wrinkle in the saga: I put the Audigy 2 ZS back in the system and all the problems came right back. The AWE64 is still detected, the resources are all still configured, but I get no sound. I changed IRQ7 to PnP to see what would happen, and now the Audigy 2 and the AWE64 are sharing the same IRQ but reporting no conflicts.
So now, I definitively know that the real culprit here is the Audigy 2 ZS. I remember having a similar issue in my previous Win98 build with a SB Live! card, so it seems that for whatever reason, in both this system and the 440BX-based computer from before, PCI and ISA sound cards don’t play well simultaneously.
Reply 49 of 60, by TheMysteriousGray
Even after removing the Audigy 2, the AWE64 has gone right back to the behavior it was doing before. However I got it to work the first time, I just can’t seem to replicate it at all.
The only constant I notice is that, whether or not PnP OS is On or Off, the AWE64 is listed as having N/A IRQ in the boot list.
Reply 50 of 60, by TheMysteriousGray
Okay, I somehow managed to get the AWE64 to work again. I have IRQ 7 and DMA 1 and 5 assigned to Legacy in the BIOS.
What seemed to make it function again was flipping Use Automatic Settings on in Win98. From there I can then turn it back off, edit autoexec.bat, manually reassign the card’s resources in Device Manager, and the card will still function after a reboot. However, I predict that putting the Audigy 2 back in will screw everything up once again.
I also don’t get MIDI from the SC-55 in DOS games, only the card’s internal wave table MIDI, even though the external MIDI port is set at 330 and Duke3D detects port 330 successfully. I can get MIDI from the SC-55 in Windows, but not a Windows DOS game.
Reply 51 of 60, by NeoG_
If you are using AWEUTIL in DOS, you should use AWEUTIL /S to output to external midi, also for windows you need to turn off MPU-401 emulation in AWE control panel. That is the feature which redirects port 330 midi data to the EMU8000 synthesizer.
It sounds like when the cards are in the system together some weird data might be written to the ECSD area in the bios, flipping the manual setting in windows 98 modifies the ECSD data
Reply 52 of 60, by TheMysteriousGray
Ah crap 🤣, I forgot about the MPU-401 emulation thing with the internal synth. The last time I had to do this much work setting up an old computer was last year. Turning that off makes it work. Only thing I notice is that I get missing instruments in the music test once the song loops, but it’s probably not a problem. Probably.
Reply 53 of 60, by TheMysteriousGray
NeoG_ wrote on Yesterday, 03:01:
Hm. I wonder if resetting the configuration data when/if I put the Audigy 2 back in might help?
The real struggle here is that, unlike the AWE64, I can’t manually assign resources to the A2ZS at all. It takes whatever IRQ and ports it wants, so it kind of “bullies” the other card out of working somehow, and there isn’t anything I can do to tell it to stop.
Reply 54 of 60, by NeoG_
TheMysteriousGray wrote on Yesterday, 03:42:
The behaviour isn't normal as far as native ISA systems operate, the PCI cards happily sit alongside ISA cards, but they can't share IRQs like PCI cards can so ISA cards occupy an entire IRQ. As soon as PCI Steering is assigned to an IRQ, ISA cards can't access it.
I would say it's a quirk of the industrial board but the fact that it also happens on the ISA native 440BX is puzzling.
Reply 55 of 60, by TheMysteriousGray
I’m really not sure what was up with that system. It initially only had the AWE64 since it came with the board, but I got a SB Live for the rig to try and resolve some seriously annoying sound issues in Half-Life. From what some of my previous comments say, everything was fine at first between the two cards, but eventually the AWE64 stopped working for some reason in the dual card setup.
Some part of me wonders if it’s because they’re both Sound Blasters. I know the PicoGUS isn’t strictly a SB card, but it has a SB mode that I’ve tried to configure before, without success. That was with the Audigy 2 in the system, although it was under DOS 6.22 so I figured it wouldn’t matter since the A2ZS shouldn’t be initialized in DOS at all.
Reply 56 of 60, by TheMysteriousGray
On a whim, I tried to see what would happen if I re-enabled the onboard audio for the mobo, and just like the A2ZS, it caused the AWE64 to stop working. Telling it to use Automatic Settings after diabling AC97 audio again didn't fix the problem.
I just don't understand. Everything everyone tells me is that PCI and ISA cards can co-exist as long as they don't share resources, but no matter what, any kind of audio software change completely knocks any ISA card out. The BIOS also never assigns it an IRQ by itself no matter what settings I use. I know the card CAN and IS talking to the system, because I've gotten it to work before, but something about PCI audio cards entering the mix causes it to shut down and I haven't found any reliable way of getting it to turn back on except to fiddle blindly and hope for the best, and this happened even on a 440BX motherboard.
Reply 57 of 60, by TheMysteriousGray
If anyone out there has a DFI G4E620 motherboard, an AWE64, a PCI sound card of any kind and the ability to install Windows 98, Please do a clean W98 install, configure those sound cards, and tell me EXACTLY what you did to get them working, even innocuous settings changes in the BIOS. I need to know that this can be done, and what I might be doing wrong. Most importantly, if I follow your steps and still fail, then the issue is almost certainly hardware-related.
I bought a second one of these boards off Newegg that'll be here sometime next month. If it's a hardware issue, I'll have to switch to that board and try my luck, assuming it even functions.
Reply 58 of 60, by Shiftyy
TheMysteriousGray wrote on Today, 03:50:
If you're looking at a different motherboard, I recommend considering an Advantech AIMB-742 over the DFI G4E620. Way cheaper and readily available on Aliexpress. Same amount of ISA slots. I didn't have any issues with mine other than it can be picky about which PSU you use. The picture of the PCI/ISA IRQ assignment I supplied earlier was from that board. I still have it but don't need or use it anymore.
Reply 59 of 60, by TheMysteriousGray
Shiftyy wrote on Today, 09:14:
Interesting. They all look like they cost roughly the same as this board did, so I guess it’s worth pursuing.
On a different note, I’ve heard good things about using VSBHDA to get DOS sound through PCI cards. I know it’s emulation and thus not perfect, and it ONLY works in pure DOS, but it seems very compatible. Do you have any experience with it?
