Reply 2780 of 2783, by Falcosoft
- l33t
Roland User wrote on 2026-11-20, 13:56:But where I can recive banks for this ? )
VOGONS is not the right place to discuss this.
Here is a new VST 2.4 instrument plugin based on FluidSynth. As far it is possible it works exactly the same way as Bassmidi VSTi so it can be useful to compare the 2 Soundfont engines. Of course some options available in Bassmidi are not available in Fluidsynth and vice versa. So there are some differences in the setup dialog but the main working logic of the plugin is not affected that much by these differences.
Features:
1. Native x86 and x64 plugins, with both 32-bit and 64-bit audio processing.
2. Up to five stacked SF2 SoundFonts with bank offsets. Later enabled SoundFonts have priority when presets overlap.
3. Selectable interpolation: Off, Linear, Cubic, Sinc 11-point and Sinc 17-point.
4. Selectable reverb engines, including Dattorro, FDN, Freeverb and Lexverb. The list reflects the engines available in the loaded FluidSynth library.
5. Built-in chorus, with separate global reverb and chorus level controls.
6. Configurable polyphony, gain, CPU core count, sample preloading and portamento mode.
7. GS, GM, GM2 and XG MIDI modes, with optional use of bank 127 for XG drum kits.
8. GM Master Volume and Tone/Brightness (CC#74) support.
9. Thirteen VST parameters for options that are not, or not easily, controlled by MIDI.
10. Instrument and bank names supplied to hosts that support MIDI program names.
11. Virtual keyboard, MIDI controller controls, active/peak voice display, bypass and host preset/state saving.
Falcosoft wrote on 2026-11-24, 09:27:Here is a new VST 2.4 instrument plugin based on FluidSynth.
Nice, i don't need request the cc#7 to initial attenuation to ian luck anymore.
BTW, in bassmidi ¿Is possible add lindecvol only to specific additional soundfont? Chippy_Bank.gm (ported to SF2) in original synth some instruments uses Linear Decay/Release, but switching flag changes in the soundfont entirely.
Zenxia wrote on 44 minutes ago:Falcosoft wrote on 2026-11-24, 09:27:Here is a new VST 2.4 instrument plugin based on FluidSynth.
I do not think so. But if you use a DAW you can have as many instances of BassMidi VSTi as you want and you can set different soundfont flags on each plugin instances. But I'm not sure if lindecvol is exposed in Bassmidi VSTi or not. (AFAIR it is not but I'm not sure).
