SBEMU: Sound Blaster emulation on AC97
Reply 2021 of 2041, by Angel Of Nemesis
Many thanks to the author! Works on the MSI H87-G41 PC Mate motherboard. I am using the VDPMI experimental build and tested on all games by ID and games on the build engine. I also have an Audigy 2 zs sound card, but unfortunately, motherboard won’t start with it.
Reply 2022 of 2041, by crazii
DoZator wrote on 2026-11-20, 16:42:
crazii wrote on 2026-11-20, 16:06:
That seems a critical bug and what's your sound card?
Yamaha YMF754
What feature's do you use? OPL and SB, any MPUs or PC speakers? I'm check the commits and there are MPU changes and PC speaker added in it.
EDIT: there's a FPU state issue in PC speaker and I've fixed in the VDPMI build, I will add it to the HDPMI32i build and you can test it.
Angel Of Nemesis wrote on 2026-11-21, 09:40:
You're welcome. Please wait and there could be a all-drivers-in build, but might may take long.
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
Reply 2023 of 2041, by crazii
@DoZator, I've added tiny changes on PC speakers, it's currently always active and it's code has FPU maths so that might be the cause if it messes up the game's FPU state.
It's now conditionally active so its sample generator won't get called if unnecessary, also saves FPU states for IO and sample gen.
It's a quick change and different from the VDPMI build but I think it behaves the same.
The attachment sbemu-HDPMI32i-1.0.0-beta.7rc2-fix.zip is no longer available
If it woks fine, then I will commit it to the main branch.
Reply 2024 of 2041, by crazii
@RayeR,
I've been thinking about your broken BIOS VDS problem today, and here're some ideas.
Because VDPMI uses 1:1 identity maps (mostly), with only rare exceptions likesome tiny portion of VDPMI core memory, or DPMI client request for physical memory mapping usually for drivers/SVGA LFB writes, which won't be involved in disk IO, and VDPMI also always handles the IO for UMB/EMS in int13h hook for BIOS buggy USBs, which also handles the IDE UDMA case, I thought it would work with your SATA3 HDD with out XHDD.SYS
I've queried google AI about the IDE UDMA transfer requirement, alignment, size etc. the only possibility that VDPMI won't work for your SATA3 HDD is that
  1. the BIOS does not handle buffer alignment / 64K boundaries AT ALL for low memory
  2. or it writes the incorrect PCI memory addresses.
in the first case, I can add an "Transfer Buffer Always On" flag in the CFG file so that the int13h hook fixes every BIOS int13h request.
for the second case, I think DOS won't work at all instantly after an EMM installed, which is not likely your case.
The internal transfer buffer used by VDPMI is at low memory and aligned to 16B, usually at ~10k location (if loaded from CONFIG.SYS) with a 4K size so I think it will be safe enough for IDE DMA.
This is a hard coded "Transfer Buffer Always On" build for you to test, if it works, I will add it to the CFG.
EDIT: this build also includes the fix for RAMDSK64; you can set "VIntFlag=0" in VDPMI.CFG to test.
EDIT2: don't test the HDD yet, I've never enabled it fully and I will test it first, otherwise it will waste your time.
EDIT3: it's ready to test now. I've updated the attachment.
The attachment vdpmi_tb_always_on.zip is no longer available
Reply 2025 of 2041, by DoZator
crazii wrote on 2026-11-21, 10:28:
In this case, only SBPRO is used, since the game only features digital sounds and music. I also thought about the new features (PC speaker), but I couldn’t find a way to disable them during the check to more accurately pinpoint the issue.
crazii wrote on 2026-11-21, 10:52:
@DoZator, I've added tiny changes on PC speakers, it's currently always active and it's code has FPU maths so that might be the […]
Thank you, I’ll try this and let you know.
UPD: It seems you’ve hit the nail on the head with the accurate diagnosis! The test results for the new, corrected version of SBEMU turned out to be very positive - the problem no longer occurred. I also connected GLIDULATOR, and even all of this together works well.
Reply 2026 of 2041, by crazii
DoZator wrote on 2026-11-21, 13:41:
Ha, that's because I've done that when I was merge it to VDPMI branch. thought it was no big deal, but turns out it matters.
The PC speaker should have and option to enable/disable it, some legacy PC like my legacy HP T5700 thin client has PC speaker.
I've added option to the VDPMI build with default enabled, but not added to the HDPMI32i build yet. will add that option and commit.
Reply 2027 of 2041, by crazii
New plans: add QEMM port trap API.
Because VDPMI works most like Win9x, it has a unified IO bitmap for both v86 and DPMI. so like w9x, a real mode driver can install port traps only via v86 interface and it will work for Protected mode games.
That may help some drivers like OPL2LPT so that it does not need patch PM games.
Reply 2028 of 2041, by RayeR
Thanks for new testing version, I hope I grabbed the right one (file date 22.11. 13:24) and quickly test it.
1) Himemex+ramdsk64 now works fine with Sysenter method (booted to windows, having swap file on ramdisk)
2) Without loading XHDD.SYS I still have problems. It's interesting that it not hangs at every read but maybe once there are more read request or in faster sequence. E.g. when I let it boot normal way executing startup files it even doesn't finish and hangs at loading some TSR from autoexec. But when I use F8 and step the startup files it finish the boot. Then I can even run simple commands like dir but when try e.g. fdisk (version from freedos - a simple realmode program) it hangs. But it not hangs completly. When I wait enough I can see HDD LED flashes for a moment after 30s. Then again after next 10-20s. After 2 minutes the fdisk shown welcome message. When I had other program hang and waited cca 1min. it ended with Read disk error: abort/retry/fail and after abort it went back to DOS prompt.
So I guess some INT13h routine for read sectror is timeouting and after cca 30s it returns with error. But it seems not happen on some isolated single read sector but some bursts or more sectors count - no idea...
Reply 2029 of 2041, by crazii
Plombo wrote on 2026-11-19, 20:02:
[*]The SB16 driver installer (sbbasic.exe from here) detects "sbemu /T6" as a Sound Blaster 16 (good), but crashes with a VDPMI error during installation. The installer does work with SBEMU+QEMM+HDPMI, so this is a VDPMI issue.
[*]Going back to VDPMI and running Windows after this, it's unable to load the SB16 driver, so I still don't get any sound. Windows says to make sure the file exists, but I'm guessing it's actually the driver failing somehow?
I tested the sbbasic driver it installs fine for me. the diagnose.exe reports some error probably because sb16 emulation is not complete. the mixer utility works fine.
why you need the Sb16 driver? sbemu works without it. is it that you try to make it work in windows?
RayeR wrote on Yesterday, 04:25:
Thanks for new testing version, I hope I grabbed the right one (file date 22.11. 13:24) and quickly test it. 1) Himemex+ramdsk6 […]
That's very weird.
so the IO works in real mode.
it should probably works wit DOS=HIGH and put DOS in HMA.
have you tested any EMM with UMB/EMS disabled, e.g. remove most regions using X=aaaa-bbbb?
To me it seems the BIOS code / iomap for the IDE controller is in UMA and it has no proper signature so it is memory mapped/shadowed by EMM page mapping..
I cannot think of any other reason that cause the problem.
EDIT: it can be that the BIOS have a v86 code path, in that case, the v86 code can have any bugs compared to real mode.
Reply 2030 of 2041, by RayeR
In realmode and pmode without V86 it always works (real mode DOS programs, HIMEM+DPMI and DJGPP/Watcom programs).
In V86 mode a realmode program can trigger the problem, probably when more intensive INT13h usage. I could try to write some simple test program that will try to trigger it with some debug prints. I could try vary different sectors counts per call and various read functions, CHS/LBA...
I have set DOS=HIGH,UMB by default in my config but didn't play with this.
The NT13h handler resides in BIOS segment code F000, I know the entry point and already have disassembled part of it. I don't know what exactly look for when you mean "it can be that the BIOS have a v86 code path" - yes it can and it was probably meant by Jack that this part is broken some way. BIOS INT13h routine is written that it use DMA some way because the speed on SATA3 SSD is quite impressive ~90MB/s in DOS without XHDD and ~300MB/s with XHDD - I think no way with PIO mode. So the way how BIOS routine use DMA may interfere with something in V86 mode because they probably didn't tested it in V86 mode.
Reply 2031 of 2041, by DoZator
Hello everyone. I apologize in advance if this question has been discussed before, but I just couldn’t find an answer right away. In some games, the left and right channels are swapped, and some games don’t have settings that allow you to change them as they should be. I thought this might have been available for a long time in SBEMU itself, so I opened the Readme, but I didn’t see any mention of the possibility to swap the left and right channels. Am I missing something, or is this feature really still not available? I’m currently testing the latest (experimental) HDPMI version. Thanks.
Reply 2032 of 2041, by myne
Pretty sure the OG SB had swapped channels.
I built:
Reply 2033 of 2041, by LSS10999
IIRC I have to enable "Reverse Stereo" in Duke Nukem 3D on my real CT2950 for the sound test to output to the correct speaker.
Some games offer the option to swap output channels in case they are swapped on the hardware side, and I think that depends on the PCB design.
I'm not sure if there are games by default assumed the channels being swapped as seen with some Creative SB PCBs that they would output incorrectly on cards/emulations where channels aren't swapped, as this is not always easily noticeable.
Reply 2034 of 2041, by crazii
RayeR wrote on Yesterday, 15:12:
because in real mode it works fine and in v86, vdpmi uses identity maps so it ought to work if it uses the same code for v86 mode. my guess it that the bios checks v86 mode and uses special code for it, like
if (v86mode) {
do something special; //this could be the bug here, because real mode works fine.
the bug is most possibly related to calling VDS, but we don't know what exactly it is. I can disable VDS so that the BIOS may skip the buggy code for VDS. and you can check if it works.
If it doesn't work then the best way is to hide the in13h hook inside v86 monitor so that windows/dos doesn't know it.
This is a build that always uses transfer buffer (not needed but just incase) and disables VDS. currently there's no option for disabling VDS. can be added if it works
I tested it in VMWare Player which uses IDE UDMA and it does not break.
The attachment vdpmi_noVDS.zip is no longer available
Reply 2035 of 2041, by RayeR
I quickly tested it and it behaves differently! Now it seems don't hang except when loading NDIS2 eth. driver in autoexec. I skipped it and didn't trigger hang so it helped some way. But it had (as expected) imapact on performance, R/W speed dropped to cca 50MB/s.
I also then tried boot to Win98 and skipped loading WINDISK.VXD and it booted - pmode WINDISK.PDR take over. Under Win98 I got 315MB/s as expected (SATA3 SSD).
So we can say it's some VDS problem. I don't know nothing about VDS do you have some good reference?
Reply 2036 of 2041, by crazii
RayeR wrote on Today, 06:12:
the 50MB/s speed may be caused by the 4K tb buffer from vdpmi. I can disable it too. it should be the same speed as in realmode.
so at least there is one possible solution to make windows use 32bit disk driver besides to hide the XHDD.SYS int13h hook in v86 monitor by trapping IVT page writes.
the VDS spec was an ms article which is gone for good but kept multiple backups on the net, e.g:
https://jeffpar.github.io/kbarchive/kb/093/Q93469/
FYI: VDS are used on page-mapped systems for HW accessing memory via DMA, where physical memory (address/size/contiguity/alignment boundary requirement) is used.
for VDPMI VDS is almost optional, because of the 1:1 identity mapping. except that 1:1 mapping cannot be used for UMB/EMS. but vdpmi also handles int13h read into UMB/EMS when fix the buggy USB emulation for some BIOS.
Reply 2037 of 2041, by crazii
DoZator wrote on 2026-11-19, 16:11:
The only additional action that needed to be performed to get back to Windows after this was to run "setupds /s" so that the PCI registers of the sound card would be cleared and returned to their normal state (This is also quite an expected behavior, as this was also required to be done earlier when I was still actively testing the preliminary alpha version of VDPMI+SBEMU, and it was the same in this regard). If this is not done, Windows will not boot.
SETUPDS may change non-std PCI configuration space registers that are for the YMF card. So it might be no universally work for other cards if I try to backup/restore configuration space registers.
Have you tried other PCI tools in DOSSTART.BAT to restore the registers for your non-YMF cards?
Reply 2038 of 2041, by DoZator
crazii wrote on Today, 08:16:
There was no need for this, as I didn’t install drivers for the HDA in Windows. Accordingly, the specified problem didn’t manifest itself, and the return to Windows worked correctly, so to speak, "out of the box".
Although, I have one observation about the "non-standard registers" of sound cards, which I forgot to mention earlier when I wrote about it. These registers are not always returned the first time. When you first rewrite registers, only some part of them actually changes, while the other part remains unchanged. When overwriting again, all registers are already completely changed. Thus, a file with the correct registers needs to be applied twice in a row for this to work.
For example, to restore the USB controller registers so that they continue to work in MS-DOS mode after Windows, a single application is sufficient (once for each of the two controllers included in Windows, with the driver installed on both):
С:
CD C:\TOOLS\RUEXE
COPY C:\TOOLS\RUEXE\USB1D.SET C:\RU.SET /y
RU /L USB1DOS.TXT
COPY C:\TOOLS\RUEXE\USB2D.SET C:\RU.SET /y
RU /L USB2DOS.TXT
However, for YMF, it is necessary to fix the registers twice in a row (otherwise, not all registers will be restored, and this will not give us the desired result):
C:
CD C:\TOOLS\RUEXE
COPY C:\TOOLS\RUEXE\YMFD.SET C:\RU.SET /y
RU /L YMFDOS.TXT
RU /L YMFDOS.TXT
It is obvious that "SETUPDS /s" works before returning to Windows and changes all the necessary registers in one pass. Perhaps this is the peculiarity. We’ll need to try doing this using "RU" instead of "SETUPDS". But I already anticipate that in this case, we might also need to apply the registers twice in a row. We’ll need to take a register dump after "SETUPDS /s", and then try applying it using RU to verify this.
It might be the same with other sound cards. I would check this first.
LSS10999 wrote on Today, 01:52:
Yes, there are no difficulties where you can change the channels within the game itself. I tested SBEMU (sbemu-HDPMI32i-1.0.0-beta.7rc2-fix) yesterday using Quake 1.06, and by default, the channels were mixed up - both in SBPRO mode and in SB16 mode. I haven’t checked earlier versions of SBEMU yet, but as far as I remember, everything used to work correctly. That’s why I started wondering whether it’s even possible to change channels in SBEMU, but I didn’t find anything about it in the Readme.
Reply 2039 of 2041, by crazii
DoZator wrote on Today, 09:57:
There was no need for this, as I didn’t install drivers for the HDA in Windows. Accordingly, the specified problem didn’t manife […]
С:
CD C:\TOOLS\RUEXE
RU /L USB1DOS.TXT
RU /L USB2DOS.TXT
C:
CD C:\TOOLS\RUEXE
RU /L YMFDOS.TXT
RU /L YMFDOS.TXT
Thanks! I think I may try some thing at least for the sound card.
DoZator wrote on Yesterday, 21:45:
SBEMU added channel swap on recent versions, but it's fixed, statically built.
I think what you need is a runtime option that can change via SBEMU cmdline option like others. I will add one soon.
It has to be done this way because it's a legacy issue of the SB card. you can create a .BAT to switch channel swap option for the game.
It's possible that the driver uses VDS too, some driver may not perform the VDS existence check and calls INT 4Bh directly, assuming VDS present on v86 mode.
Also, have you tried the previous build of vdpmi or any other EMM without this driver? It reminds me about driver compatibility issues (like USBDDOS with SHSUCDX), maybe your NIC driver has that issue with your BIOS?
I can also trick the BIOS with the BDA VDS signature off on int13h so that it may skip VDS but VDS still exist, that may fix the driver problem. but I don't know, without knowing the real reasons its just a guess.
