First post, by raulpuro
I have a problem with the voices of the game Jack The Ripper New York 1901 (https://www.myabandonware.com/game/jack-the-r … er-fz9#download) in Windows 10 x64, the voices are cut, this game uses the virtool engine just like Martin Mystère: Operation Dorian Gray, in Martin Mystère you have found the solution (Issues with Martin Mystère: Operation Dorian Gray), I have tried all AIMP options to recodify the MP3, but I have not achieved anything please, can you help me solve this error that is very annoying?
Greetings and thanks for your time.
Reply 1 of 5, by Shagittarius
Have you tried turning off audio acceleration?
Reply 2 of 5, by raulpuro
Shagittarius wrote on 2022-09-21, 19:58:
I don t know how to do that. You can explain it to me please.
Edit : I have tried it but Windows 10 does not show me the option
Reply 3 of 5, by Shagittarius
Oh Windows 10, sorry, I would do it through DXDIAG but I dont think it works that way in windows 10. Have you tried setting the executable to different compatability modes?
Reply 4 of 5, by raulpuro
Shagittarius wrote on 2022-09-21, 22:47:
Yes, but still does not work.
I think the problem is in the MP3Reader.dll file, for some reason it does not work well in 64 bit systems, but unfortunately I do not know how to repair the file so that it works in Windows 10.
Reply 5 of 5, by My_Blood
raulpuro wrote on 2022-09-21, 22:53:
The user's hunch about `MP3Reader.dll` is a very strong lead, and it fits perfectly with everything you've experienced. It's a Virtools component, and its architecture mismatch on a 64-bit system is likely the root cause of the audio cut-offs you're hearing.
### 🎯 Why `MP3Reader.dll` is the Prime Suspect
`MP3Reader.dll` is indeed a module created by Virtools SA, the company behind the engine used for *Jack the Ripper*. The critical detail is that this DLL was compiled for **32-bit (x86) architecture**. While a 64-bit Windows 10 can run 32-bit applications, it can sometimes fail to properly handle 32-bit DLLs that rely on older, specific ways of processing audio data.
The user on the forum likely experienced the exact same issue: the game's code tries to call this 32-bit DLL to decode MP3 audio (like dialogue), but the 64-bit system misinterprets the call or fails to allocate memory correctly, causing the sound to cut out mid-sentence. This is a known bug with x64 architecture, and the common fix is to ensure the **x86 version** of such libraries is used.
### 🛠️ Actionable Ideas to Try
Here are several approaches, starting with the most direct fixes for the DLL issue itself.
**1. Replace `MP3Reader.dll` with a 32-bit (x86) Version**
This is the most logical step. You need to find a genuine 32-bit copy of the DLL.
* **Where to look**: Search for `MP3Reader.dll` in the installation folders of **other older Virtools-based games** (like *Still Life* or *Syberia*). A DLL from a 32-bit installation of one of these games is more likely to be compatible.
* **How to apply**: Back up the original `MP3Reader.dll` from your *Jack the Ripper* folder, then copy the replacement DLL into the same directory. Launch the game and test the dialogue.
**2. Use a "No Music" Mode (if available)**
This is a diagnostic workaround. If the game supports command-line parameters, you might be able to bypass the MP3 reader entirely.
* One forum post mentions a **`/nomusic`** parameter for a similar issue. Try creating a shortcut to `Jack.exe`, and in the "Target" field, add a space and then `/nomusic` at the end (e.g., `"C:\...\Jack.exe" /nomusic`).
* If the game launches and **dialogue audio works but music is gone**, it confirms `MP3Reader.dll` is the culprit. You can then decide if playing without music is an acceptable compromise.
**3. Force the Game to Use a Local Audio Wrapper (DSWRP)**
Since direct DLL replacement can be tricky, you can use a registry patch to force the game to use a compatible audio wrapper from its own folder.
* The tool is **DSWRP (DirectSound Wrapper Registry Patcher)**. It modifies the registry so that the game looks for `dsound.dll` in its installation directory instead of the system folder.
* **Steps**: Place a compatible `dsound.dll` (from DSOAL or similar) in the game folder, then run the DSWRP patch as administrator. This can sometimes bypass the problematic `MP3Reader.dll` path.
**4. The Ultimate Fallback: A 32-bit Virtual Machine**
If none of the above works, the most reliable solution is to run the game in its native 32-bit environment. This completely eliminates all 64-bit compatibility issues.
* Create a virtual machine using **86Box** or **VirtualBox** with **Windows 98 SE** or **Windows XP (32-bit)**. This is a common and highly recommended solution for games that are stubbornly broken on modern systems.
### 💎 Summary
Your user friend's diagnosis is very likely correct. Start by trying to source a **32-bit `MP3Reader.dll`** from another Virtools game. If that's not feasible, the **`/nomusic`** trick is a quick way to confirm the problem, and the **DSWRP** method is a clever technical workaround. If all else fails, a **32-bit virtual machine** is the guaranteed path to a fully working game.
Let me know which approach you'd like to explore further, and I can provide more detailed steps.
