Reply 160 of 168, by KHORG
On 1.1.155
re-tested on 1.1.57 (haven't yet re-tested Starmate AI shooting downwards)
The Clan decal on the right arm (from the view of the Dire Wolf) is sunk into the Dire Wolf's arm. Left arm is fine. It occurs with any clan emblem decal and no other mechs have this problem.The Elemental which has been added as an option in Trials of Grievance can't fire either of its weapons, pressing space just changes weapon selection, but without the usual "clunk" noise which occurs when pressing enter.Enemy mechs are appearing on radar approximately 6 seconds before the "Enemy Powerup Detected" notification is played. This can be seen on Blade Splint, Sable Flame, Burning Chrome and Velvet Hammer. From looking at the DOS version of Blade Splint, the audio notification should be played as soon as the enemy mech begins its powerup sequence and appears on radar, not at the end of its powerup sequence.- On Golden Spade, the Shield-Generator should not be rendered (as a red structure or otherwise) on Satellite View.
On Golden Spade, the Force Shield should not be rendered on Satellite View as a red structure. It instead has a large blue marker which is already present.On Golden Spade, the Hellbringer, Summoner and Mad Dog are being spawned outside of the Force Shield. They need to be spawned at their correct locations inside the Force Shield and the Palace fencing.When your mech is powering up, you're currently able to select a target before your mech comes fully online. This is shown on the radar minimap and the MFD displays the target once active. This isn't the correct behaviour, you should not be able to select a target using E, T or any other key until your mech is fully online.- Starmate mechs don't seem to have the ability to aim down (or presumably up), so they continually shoot over the top of turrets, e.g. on Golden Spade. They can definitely aim downwards in the DOS version.
Jumpjets do not appear to be working correctly, you should have the ability to slew the mech around and have it change direction whilst jumpjetting. But currently once jumpjetting, you're locked into a direction and cannot alter heading.
