American McGee Alice(2000) A3D 2 Not working
Reply 20 of 22, by ZanQuance
DAFFYDAFFY wrote:
Someone posted a fix for some soundcards on Moddb .(check the Alice downloads section)
Just posting this case some one ends up here while looking for fixes.
You mean the download where he just includes the games Miles files which should install normally anyways?
That's not really a fix for the audio systems bug not enabling A3D2, but thanks though!
Reply 21 of 22, by Unrealdevon
ZanQuance wrote:
Sorry I didn't see this earlier, I actually patched my version of Alice to work with A3D 2.0. Search for this in a Hex editor, […]
Search for this in a Hex editor, provided long hex to nab correct offset area:
B000520053E87095070083C40885C0751A @0006F1F5 (byte 75)
Change to
B000520053E87095070083C40885C0741A @0006F1F5 (to byte 74)
This will bypass the card detection bug and let A3D 2.0 be enabled.
Thank you soo much for providing this hex edit.
The same exact problem is in Heavy metal f.a.k.k 2
I tried to find that line of code in FAKK2.exe hoping it was there but no 🙁
The game uses miles and is running on the Quake 3 engine aswell.
Any chance you could assist me in finding the bug i FAKK2?
Reply 22 of 22, by ZanQuance
This is a major necro post but the actual fix has been found (I've been working on the new XP drivers and testing against all A3D 2.0 games):
Both Alice's and Heavy Metal FAKK 2's exe use the default Aureal 1.0 provider string of:
"Aureal A3D Interactive" and it matches the miles audio output from this provider string.
In order to support both, there should also be present a string that says:
"Aureal A3D 2.0" however this is missing from both exes.
So what you can do is hex replace the Aureal A3D Interactive with Aureal A3D 2.0 and it fixes the detection in both games.
null padding required for this 24-byte patch
In both games exe's replace "Aureal A3D Interactive":
41 75 72 65 61 6C 20 41 33 44 20 49 6E 74 65 72 61 63 74 69 76 65 00 00
with Aureal A3D 2.0:
41 75 72 65 61 6C 20 41 33 44 20 32 2E 30 00 00 00 00 00 00 00 00 00 00
Save this out as it's own new exe copy AliceA3D2.exe and fakk2A3D2.exe so you can load either or if you wish.
The single byte forceful route I provided earlier worked as a kludge fix, but this was the real reason it fails and a more proper fix.
You're welcome.
