First post, by Dolenc
Real-time framerate counter and benchmarking tool for the 3dfx Glide API. Compatible with Glide2x and Glide3x games.
Ive only tested it on Win98 and Voodoo 5. Hope it works.
LINK: https://github.com/NejcDolicanin/GlideFPS
The attachment glide_20261126_182942.jpg is no longer available
Simple UI
The attachment GlideFps1.jpg is no longer available
And it allows you to benchmark and at the end write a log file. It writes this file at the end, doesnt log every line. So it should have minimal impact on performance.
The attachment GlideFps2.jpg is no longer available
Reply 1 of 4, by havli
Very nice! Thank you, this will be very valuable utility for benchmarking Voodoo cards 😀
Tested briefly on two machines. One is V5 5500 + W98. Tried several glide games and even OGL games - everything worked smoothly.
Second is V2 SLI (Obsidian2 X24 in fact) with rather old Q3D drivers. Also working perfectly.
One tip for possible future improvement (if you ever feel like you have too much free time on our hands 😁). Since you measure frame times, would it be possible to add option to write time of each frame to text file? For example like this (fraps format):
Frame, Time (ms)
1, 0.000
2, 6.252
3, 13.368
4, 21.667
5, 28.820
6, 36.968
7, 44.168
8, 51.692
9, 59.767
10, 66.656
11, 74.459
12, 82.047
13, 89.447
Reply 2 of 4, by Dolenc
Sure, attach one short fraps log file here, so I have the exact format.
Reply 3 of 4, by havli
No problem, file attached.
Perhaps even the file name could be like in this example. I'll make processing the data even easier.
executable-name_datetime_frametimes.csv
Reply 4 of 4, by Dolenc
There you go, get the v1.1 from releases.
