Battle of the platforms: socket 939!
Reply 620 of 635, by nd22
There is barely 13% difference between X2 3800 and X2 4800! The performance rating of these early dual cores is seriously overestimated by AMD!
56 & 57 & 58. We reached the last year of the Windows XP era: 2006. The first game is PREY also based on IDTECH4 engine. Unlike earlier games the maximum anti-aliasing available is 4X which make the job very easy on the GTX 285. The processors used again limit performance however taking into account that even the X2 3800 can run the game at over 100 FPS that is more than enough for a comfortable gameplay experience!
A. Athlon 64 X2 3800
B. Athlon 64 X2 4200
C. Athlon 64 X2 4400
D. Athlon 64 X2 4800
Reply 621 of 635, by nd22
59. I specifically selected the last 2 games to make a point: no matter what CPU you got, 2006 is really the last year for socket 939! Company of heroes was released back in September 2006. It was from the outset a killer program - even with an Athlon 64 X2 4800 in a 8 players game it will slow down tremendously after large number of units are produced. On DIRECTX10 systems additional options are available - such as textures, and in particular "gruesome"levels of AA!
1024*768
Reply 622 of 635, by nd22
For once AMD rating system is validated as each successive model more than make up for its rating!
60. 1280*1024
Reply 623 of 635, by AlexZ
nd22 wrote on 2026-11-23, 01:43:
Do not underestimate the system resources that MSI afterbuner 4.50 and FRAPS 3.5.99 consume! Here is a test in FEAR with Athlon 64 X2 4400 that is currently installed in the system with both of them disabled at startup. 8% better and I am still running 4 memory modules with the penalty that CR 2T imposes!
Thanks for demonstrating this, the performance drop caused by MSI afterbuner 4.50 and FRAPS 3.5.99 is indeed huge. Those running without them and at CR 1T should get a really nice performance boost.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 624 of 635, by nd22
Thank you sir. With CR1T - so with just 2 RAM modules - the scores further improve by another ~8% so if you do not really need 4GB of RAM stick to just 2GB and frame-rates are much better!
61. Company of heroes - 1600*1200
Reply 625 of 635, by nd22
Company of heroes loves cache! The 2 models with 2*1MB of L2 cache are in a different league altogether!
62. And we reached the last game: Microsoft flight simulator X. Exceptionally demanding, it is not possible to play this game on any socket 939 X2, not even on FX-60. The game is dual core aware and will use both of them at 100%. I have chosen the free flight with the Air Creation Trike Ultralight on Friday harbor for testing. I let the game load; waited 1 minute before pressing F11 to test with FRAPS; I did not touched the controls, the plane flew in a straight line, no right or left, no up or down. Please note that I used MAXIMUM settings that are far beyond the ultra settings that you can set using global presets!
1024*768
Frames, Time (ms), Min, Max, Avg
699, 60000, 9, 14, 11.655
735, 60000, 11, 16, 12.249
761, 60000, 11, 16, 12.675
801, 60000, 11, 15, 13.358
Reply 626 of 635, by nd22
63. FSX - 1280*1024
661, 60000, 10, 13, 11.013
708, 60000, 10, 14, 12.000
750, 60000, 10, 16, 12.495
780, 60000, 11, 14, 13.008
Reply 627 of 635, by nd22
64. FSX -1600*1200. Note that changing resolutions leads to a minuscule performance drop - the fact that average FPS drops from 13.358 to 13.008 is simply academic, no one is going to notice that!
638, 60000, 9, 12, 10.640
698, 60000, , 9, 14, 11.637
725, 60000, 9, 14, 12.084
742, 60000, 10, 14, 12.378
Reply 628 of 635, by nd22
Horrific performance by the first generation of dual cores from AMD. I wonder if Pentium D would manage better or if a higher clocked Athlon 64 X2 on socket AM2 would stand a chance in Flight simulator X!
Reply 629 of 635, by nd22
Athlon's 64 X2 have been put through 64 tests! You have seen on these pages 4 out of the 5 models: 3800, 4200, 4400, 4800. 4600 is missing in action but I think we can get a pretty good idea about its performance based on what we have seen with the other 4.
Time to see how they stand! Athlon 64 X2 3800, the base model, constitutes the reference and is awarded a 100% base score.
A. Athlon 64 X2 4800 - 117.52%
B. Athlon 64 X2 4400 - 111.71%
C. Athlon 64 X2 4200 - 106.50%
D. Athlon 64 X2 3800 - 100%
Reply 630 of 635, by nd22
So the difference between 3800 and 4200 that have the same amount of L2 cache is far less than the PR indicates: 10.52%. Things stand the same with the 2 models with 2*1Mb of L2 Cache: the difference in performance is less than the difference in PR! Only about 250 PR points separate the 3800 from 4200 and 4800 from 4400. The difference between 4400 and 4200 is EXACTLY as the performance rating indicates: those 5.21% difference translates into 200 PR points.
So AMD overestimated its dual cores CPU's!
Reply 631 of 635, by AlexZ
nd22 wrote on 2026-11-24, 10:37:
I already tested it on Phenom II X4 955 (3.2Ghz) and I would say it still isn't enough.
Re: Battle of the platforms: socket 939!
Athlon 64 X2 6400+ (3.2Ghz, AM2) is great for Windows XP era but not great for Windows Vista era. I originally hoped this CPU, or Phenom X4 9950 BE (2.6ghz) or Phenom II X4 940 BE (3.0 Ghz) would cover Windows Vista era, but they all turned out to be too underpowered, Phenom II X4 940 BE just slightly though. Phenom II X4 955/965 did a great job and also works great in Windows 7 era. Some very tough games were released in 2006-2009.
Athlon 64 X2 6400+ and Phenom X4 9950 BE are for Windows XP era just like s939, just another flavor of AMD technology.
Reply 632 of 635, by nd22
That would seem to be the general idea! Athlon 64 is only fit for the Windows XP era: 2001 - 2006.
Now based on the results you have seen I have devised a new PR rating for dual cores Athlon 64 X2; just like with the single cores 200 MHz = 200 PR points and 512kb of L2 cache = 200 PR points.
Athlon 64 X2 3800 represents the baseline and all other models ratings are based on it.
AMD rating – NEW PR rating
1. Athlon 64 X2 4800 - Athlon 64 X2 4400
3. Athlon 64 X2 4400 = Athlon 64 X2 4600 - Athlon 64 X2 4200
4. Athlon 64 X2 4200 - Athlon 64 X2 4000
5. Athlon 64 X2 3800 - Athlon 64 X2 3800
If someone has the Athlon 64 X2 4600 it could do all the tests I have done and we could compare it to the Athlon 64 X2 4400. My opinion is that they provide the EXACT same performance.
Reply 633 of 635, by nd22
All testing is done! Athlon 64 and its bigger brother - X2 - went one more time through dozens of tests to determine one more time - hopefully the last - the relationship between cache, frequency and performance rating.
On both socket 754 and 939 the PR are equal - a model on socket 754 has the exact same performance as the corresponding model on socket 939; some models have their PR artificially inflated to better compete with existing and planned Intel processors most probably.
Of course we all know that Athlon 64 ratings are compared against its nemesis - Pentium 4! That remains a topic for the far future.
Athlon 64 X2 have a vastly overestimated PR and is not in any shape and form comparable with the PR of single cores Athlon's. AMD most likely slapped some PR numbers to differentiate the X2 from the single cores and to entice prospective buyers to buy the more expensive dual cores.
In the following pages I will make 2 examples of builds based on socket 939 and evaluate them from the performance, price and ease of finding point of view.
Reply 634 of 635, by nd22
There are 2 ways to build a socket 939 system; unlike with socket 754 the required parts are far more expensive and difficult to find! Because it is considered a premium platform you will have to spend considerable more than with the socket 754 build that I detailed on the first topic with Athlon 64.
The first option is: best price to performance ratio where you build a socket 939 system with cheap enough parts that are powerful enough to play all the games from the 2001 - 2005 era.
The second options is: top of the line system without limits on the price of the components where you build the ultimate socket 939 system that will allow you to play all games from the Windows XP era.
For both options the video card is more powerful than anything available in the years when Athlon's and X2 were first available!
Reply 635 of 635, by Warlord
i got a M2N32-SLI Deluxe Wireless Edition that needs a full recap, but I gotta feeling it will never be faster than a core 2 quad extreme on an X48. In my opinion even a core 2 quad on x48 isnt fast enough. XP really shines on something like sandy or ivy bridge. XP life cycle was really long 20 years for an OS still receiving patches. I was still daily driving XP POS up until a few years ago.
The real test is witcher 2 even on my Titan Maxwell with ivy bridge at max settings XP chokes. It runs fine on Win 7 though with the same hardware.
