Reply 60160 of 60179, by Nicolas 2000
Oooh nice a Fury Maxx was on the shortlist for my W98 PC. But I took the easy and affordable route and went for a TI 4200. Awesome find, have fun with it!
I managed to find some 750MB disks for a Nomai unit.
Those are platters like HDDs.
Coming from Guadeloupe. Shipping + customs were a bloodbath... 70€ total for 3 disks.
It hurt but at least I can test my unit.
I thought it was considered France and then no customs, I was wrong. I was soooo wrong...
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Nicolas 2000 wrote on 2026-11-23, 21:06:Oooh nice a Fury Maxx was on the shortlist for my W98 PC. But I took the easy and affordable route and went for a TI 4200. Awesome find, have fun with it!
Its a nice card but drivers are a huge let down, I have a working MAXX and you need to play driver roulette to get the most from the card.
Sadly ATI never finished the drivers before abandoning the MAXX the final drivers are a mess.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Today I got a Epia-M
https://theretroweb.com/motherboards/s/via-epia-m
Nice little board to play with.
Gonna try to make it a DOS mini machine.
I need to figure out which ATX to 12V works with it. It requires really no power.
i have the same board somplace, I could never get the performance I wanted out of it, even though on paper the stats look decent. If youre ever able to get working bug free 9x and dos drivers working for it please share.
Warlord wrote on 2026-11-24, 21:45:i have the same board somplace, I could never get the performance I wanted out of it, even though on paper the stats look decent. If youre ever able to get working bug free 9x and dos drivers working for it please share.
It definitely likes more ram and tweaked to get max speed.
C3 1.0GHz, it can't be that good either but not that bad as it is showing. Just to load Mini Xp it takes minutes.
A P3 fares much better (comparison is for talking, I know the huge gap...)
I bought a Toshiba Libretto jigsaw puzzle!
The pictures showed a couple of bits broken off and I thought it was no big deal, but it breaks like peanut brittle so the rest of it fell to pieces too - it was shipped in just a jiffy bag. Shame polymatt didn't have the port replicator when he was modelling up housing for the Libretto 50CT
Looks like this one goes on the pile of stuff to do later. Guess I'll have to dismantle one of the good ones to get a 3d scan of it and see about recreating it. Perhaps I'll have a go with cnc kitchen's scanruler tool
Several more Toshibas, since we're on that topic.
- Tecra 8100 - ended up being dead (powers up but no POST, no battery leakage btw.)
- Satellite 4060XCDT - works but god the MMC1 CPU was a pain in the ass, it'd unseat itself like crazy. This one had a fairly nasty VARTA that was INCHES close from going nuclear. P2 333.
- Satellite 4070CDT - Celeron sibling to the 4060 above. This one barely had any green specks on the VARTA (tf Toshiba 🤣)
Up next on the list - 460CDX that I will try to (hopefully) convert into a CDT.
PcBytes wrote on 2026-11-25, 18:45:Several more Toshibas, since we're on that topic. […]
- Satellite 4070CDT - Celeron sibling to the 4060 above. This one barely had any green specks on the VARTA (tf Toshiba 🤣)Up next on the list - 460CDX that I will try to (hopefully) convert into a CDT.
Good luck with the conversion, hopefully the thread where I documented it is useful to you 😀
The Tecra 8100 seem to be pretty failure prone. You sure there was no RTC battery damage? The dead one I have the RTC had destroyed loads of circuitry around the PCMCIA ports and seems to have a half working PCI bus. It's worth using a parallel port POST code reader if it powers up to see what codes it gives
The Libretto dock is now broken down into all of its component parts (screws, screw threads, springs, plastic dust) to rebuild later. At least the port replicator can be used as-is and perhaps I could improve the design with PS/2 keyboard and mouse ports in future. That's not happening for quite a while though.
Thermalwrong wrote on 2026-11-25, 18:31:I bought a Toshiba Libretto jigsaw puzzle!
Crumbly, but Good https://www.youtube.com/watch?v=dMyt4wxI1RU
Thermalwrong wrote on 2026-11-25, 20:37:Good luck with the conversion, hopefully the thread where I documented it is useful to you :) The Tecra 8100 seem to be pretty f […]
The Tecra 8100 seem to be pretty failure prone. You sure there was no RTC battery damage? The dead one I have the RTC had destroyed loads of circuitry around the PCMCIA ports and seems to have a half working PCI bus. It's worth using a parallel port POST code reader if it powers up to see what codes it givesThe Libretto dock is now broken down into all of its component parts (screws, screw threads, springs, plastic dust) to rebuild later. At least the port replicator can be used as-is and perhaps I could improve the design with PS/2 keyboard and mouse ports in future. That's not happening for quite a while though.
Fairly sure. Out of all 3 the 8100 and 4070 had the least amount of VARTA leakage.
Thermalwrong wrote on 2026-11-25, 18:31:I bought a Toshiba Libretto jigsaw puzzle! […]
I have one laptop that has become so brittle it cracks and breaks by just looking at it.
I can relate...
On the bright side, you can print it back to life.
Nexxen wrote on Yesterday, 11:40:I have one laptop that has become so brittle it cracks and breaks by just looking at it.
I can relate...On the bright side, you can print it back to life.
It is amazing how bad some plastics can change. I have one Atari STfm where just looking it wrong gets pieces flying all over the room. It needs to be handled with archeological precision and carefulness if you want to maintain what is left of the case in one piece.
I wondered where all the STs went, I see more A500s and there seemed to be equal numbers around in the big late 90s selloffs.
Baleog wrote on 2026-11-22, 18:15:I just picked up this ATI Rage Fury MAXX from the post office. With a name like that it ought to be good 😀 I’ll be testing it over the next few days, but it feels good to have something special in the collection.
What a beast for Win9x, anybody knows what drivers work best for it? I always wanted one myself, but at least i have had Voodoo5 AGP. 😀
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
BitWrangler wrote on Yesterday, 18:01:I wondered where all the STs went, I see more A500s and there seemed to be equal numbers around in the big late 90s selloffs.
Overhere it seems to be quite equal in terms of ST versus A500 numbers. The A500 is slightly more popular (better 😁) for gamers, but ST will always be the MIDI powerhouse. Speaking of which, where have all the Cubase 2/3 ST dongles gone? I could use one.
Luckily my ST's and A500 do not have overly brittle plastic.
CharlieFoxtrot wrote on Yesterday, 16:19:Nexxen wrote on Yesterday, 11:40:I have one laptop that has become so brittle it cracks and breaks by just looking at it.
This was a good one line LMAO
It's a 486 I have, I went to see if it was stable and by handling it I opened a new crack.
Everything works though but I can't open the screen as it'll break the hinges. External screen and keyboard/mouse.
Cyrix Dx33, not interesting at all.
Let's have a beer over it, cheers!
Nexxen wrote on Yesterday, 23:15:This was a good one line LMAO […]
Cyrix Dx33, not interesting at all.Let's have a beer over it, cheers!
The one I hate is that soft plastic Lenovo and IBM liked to use on a range of their ThinkPad's ...it goes super sticky and oily with age and is a bitch to remove requiring a lot of patience, paper towel and ISO to get it clean. Ive tried a lot of other products in attempting to remove it but ISO always came out on top for cost effectivness.
Trashbytes wrote on Yesterday, 23:25:Nexxen wrote on Yesterday, 23:15:This was a good one line LMAO […]
CharlieFoxtrot wrote on Yesterday, 16:19:It is amazing how bad some plastics can change. I have one Atari STfm where just looking it wrong gets pieces flying all over the room. It needs to be handled with archeological precision and carefulness if you want to maintain what is left of the case in one piece.
I had a P-III IBM and it was glue-like. It also broke in the usual weak spots and I basically stitched it back into shape.
Elbow grease is one of the main ingredients. It's about the chemicals the used for the formula and how far in time they thought one would use it IMO.
If you think about it, how many laptops have nonsensically weak hinges? Even now?
Thermalright was always my No.1
