First post, by fjasper
Just a short question after reading through the ESS 1978 & Ms-Dos posts on vogons.
If I understand it correctly, Ess 1978 under "Ms-Dos" only works properly if I boot windows 98 and then go to the "dos mode" ("Shut Down" button and then "dos-mode").
So that the Windows 98 driver is somehow available in this Ms-Dos Mode and can be used by Dos-Games.
Now, the question: I was wondering if I could simply create an ordinary Windows 98 boot disk and install the ESS 1978 drivers (AECU.SYS in config.sys and maestro.com in autoexec.bat). Or does it only work in case I normally start W98 and then got to "dos-mode" ?
I am asking because, right now, I run Win XP on the machine. (P 3 -550). It would be nice to have a bootdisk to play some dos-games in "real dos".
Would easier than setting up a multi-boot with XP and W98.
Maybe anybody tried that before?
Best Wishes,
Fabian
Reply 1 of 2, by megatron-uk
No, the Win98 boot disk is pure DOS; it won't do any initialisation of the ESS Maestro.
You can actually have a nice pure DOS system using the Win98SE boot disk to format and install a minimal system, but it won't do anything magic with your hardware.
Consider it the same as DOS 6, but with FAT32 filesystem support. That's all.
https://www.target-earth.net
Reply 2 of 2, by NeoG_
fjasper wrote on Yesterday, 20:13:
Win98 restarting to DOS mode and a win98 boot disk are essentially the same environment. So if the sound card works in Win98 restart in DOS mode you can almost certainly replicate that environment to a boot disk.
The one caveat is that PCI based audio chips often use windows to set the resources for the card then update the DOS environment to match. So you may be starting from scratch in finding out what the correct commands are to get the card to work in config.sys and autoexec.bat. It would be easier if you had a working example to copy from.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
