Throttle CD-ROM drive speed in DOS?
Reply 80 of 86, by TeleTubby666
ChrisR3tro wrote on 2026-11-02, 10:48:
TeleTubby666 wrote on 2026-11-02, 09:45:
For now I simply call it twice in AUTOEXEC.BAT, which works. But maybe CDBeQuiet could just retry once automatically when this error comes up?
CDBQ is designed to be called after MSCDEX is loaded, did you try that?
EDIT: I think, I never tested much with SHSUCDX. Can you tell me first, if your drive behaves normally with MSCDEX?
Sorry, I forgot to reply here. Yes, with MSCDEX, both drives spin down as intended.
Reply 81 of 86, by ChrisR3tro
TeleTubby666 wrote on 2026-11-06, 07:39:
Ok, I tried it with SHSUCDX v1.09 now and can confirm, that CDBQ doesn't work with that, but I got another error (device not ready) and it does not resolve if I execute CDBQ a second time. It may or may not have to do with that unit attention condition, but it's possible. It would obviously make sense to not have CDBQ rely on MSCDEX or at least work with SHSUCDX, but I will have to make some time to check further into this. Thanks for pointing it out, though. For now, I put it on my todo list.
Regards
Chris
for more retro-related tidbits follow me on X under @ChrisR3tro.
Reply 82 of 86, by ChrisR3tro
This haunted me, so I took some time today and with a little help of Claude, I actually fixed this + some other improvements.
This should work now with SHSUCDX. In my tests, the speed setting now even survived when CDBQ is loaded prior to MSCDEX or SHSUCDX. (but please don't do that)
Here's a new version: https://www.a20gate.net/dos-tools/cdbq/CDBQ140B.ZIP
If this also works for you, I'll make it a proper release. Anyone who wants to test this, please go ahead - much appreciated.
- Chris
Reply 83 of 86, by ChrisR3tro
Just noticed, the link didn't work 🙄. Sorry, fixed it.
Reply 84 of 86, by TeleTubby666
sorry, I somehow missed both your PM and your post in the thread, so I'm only getting back to you now.
I just installed the latest version, but unfortunately I'm still getting the following error messages:
text
CDBeQuiet! v1.4.0-rc2 | built on Nov 7 2026 15:56:22
Developed by ChrisR3tro
Website: http://www.a2ogate.net/dos-tools/
Reading drive information from secondary master device... ok.
Model name : CD-540E
Firmware rev.: 3.0A
Setting CD-ROM read rate of 600 kb/s on secondary master device... not ok.
ERROR: ATA command aborted unexpectedly.
IDE error register value was: 0x641h
Reading drive information from secondary slave device... ok.
Firmware rev.: 1.0K
Setting CD-ROM read rate of 600 kb/s on secondary slave device... not ok.
ERROR: Unknown IDE/ATAPI error occurred.
IDE error register value was: 0x60h
If you need any additional information, or if you have a debug version available that I could test, I'd be more than happy to help!
Thanks a lot for your time and support!
Best regards!
Reason: Remove email
Reply 85 of 86, by ChrisR3tro
Thanks for testing this more. It's really strange you got the ATA error. I was wondering:
Did you try this with SHSUCDX or MSCDEX? If SHSUCDX, does it still work with MSCDEX and 1.4.0-rc2?
Does it work first try if you don't load UIDE?
If you'd like to debug this quicker than through back and forth on this forum, don't hesitate to contact me via Discord (same username as here). I'm genuinely interested in why my tool fails on your setup.
Chris
Reply 86 of 86, by TeleTubby666
Unfortunately, I can't reply to PMs here yet, so I've sent you a friend request on Discord. We can continue our conversation there.
I'll give the steps you suggested another try and report back.
