First post, by Garrett W
After years of searching, I'm finally a happy owner of a Socket 4 setup. Namely, a 430LX based Soyo SY-029 with 512KB cache and a Pentium 66. Thing is, this board, lovely as it may be, does not have an on-board IDE or floppy controller like the Intel Batman boards from the same era. This leaves me in a bit of a weird spot as I've come to realize that PCI controllers of the sort were not really that common at the time were they? It was mostly SCSI if you wanted to go that route (and I really don't) and then it all got integrated anyway.
So I'm kind of left wondering what to do here and I've come up with the following:
a) Just use one of the Prime 2 ISA controllers. How much of a hit can I expect on performance?
b) Hunt down an early PCI IDE controller. Any way to make the search more specific?
c) Use a Silicon Image ATA133 PCI controller that I have at hand. Will this even work? If so, I suppose I'll have to load drivers in order to install DOS and/or Win95?
On an unrelated note, anyone know if I can safely run EDO memory on 430LX? AFAIK it only does FPM, but I stuck what appeared to be EDO chips to do some initial testing and it seemed to go alright. Can I expect incompatibility with random hangs and instability?
Thank you all in advance.
Reply 1 of 4, by wierd_w
There are quite a few noteworthy pci controllers in that era.
They were generally sold as ATA-133 controllers, rather than 'PCI IDE controllers'.
Promise technologies made several, and I believe Adaptec did as well.
https://theretroweb.com/expansioncards/s/prom … se-ultra133-tx2
https://theretroweb.com/expansioncards/s/adaptec-ash-1233
It's been awhile, I dont remember if winbond made discrete cards or not.
Reply 2 of 4, by akimmet
Considering many period late 486 early Pentium era PCI IDE controllers had severe data corruption bugs, the lack of onboard IDE isn’t that tragic.
The infamous CMD640 and RZ1000 come to mind.
An ISA super IO card would be slow, but would do the job.
Reply 3 of 4, by Babasha
Believe me and just install SCSI card with SCSI HDD or use ISA multicard with some performance hit (PIO mode only)
Need help? Begin with photo and model of your hardware 😉
Reply 4 of 4, by Garrett W
wierd_w wrote on Today, 02:11:
Sure, but ATA-133 controllers are not really from that era, they're more an early to mid 00s thing. I don't even think ATA-133 was finalized until 2003 or so. That's 10 years removed from this Pentium, which is why I'm worried if it will work, especially since 430LX is just PCI 2.0 and a Promise ATA-133 manual I found online clearly states it requires 2.1 or 2.2. I think my Silicon Image SIL680 might just be PCI 2.2 only.
After perusing the local markets, I found a Promise ATA-100 non TX2 that merely requires a 32bit PCI slot as per the manual, so I'm thinking this might stretch compatibility all the way back to just plain PCI 2.0. So I'll be grabbing that to try.
Babasha wrote on Today, 07:16:
I really want to avoid SCSI as I do not have an appropriate controller nor HDD. They also usually attract a premium because SCSI == retro/rare/nostalgia. Maybe if there is a CF or SD adapter it might be viable.
