DFendX - the legend is reborn (again)
Reply 140 of 147, by AlfreX
To make it easier to understand and identify the error, I'm attaching a short video showing you the sequence.
The attachment Videocaptura de pantalla_20261119_182830.zip is no longer available
I'm also attaching a new, recent log (generated right during the video demonstration).
The attachment DFendX-Log.txt is no longer available
As you’ll see, after the error, when you click the OK button, the icon view doesn’t load—the screen stays black—but the program doesn’t close. When you switch back to cover art view, it reloads them.
Reply 141 of 147, by AlfreX
I found a major regression in the latest Linux builds!
It turns out that when I try to add a new profile, in the “Drives” section, it won't let me mount any folder or disk image—whether as the C: drive or an optical drive—and when I click the “OK” button, nothing happens. The same thing happens if I click ‘Cancel’ or “Help.”
Unfortunately, I didn’t realize this until it was too late because I had already added all my games to the collection and was just testing other features and bugs, but today, when I tried to add a new one, I noticed the problem. Unfortunately, I deleted the previous Linux build where this worked and which I had used to organize my entire collection.
I hope there’s an easy fix because now I’m left without DefendX on Linux
Reply 142 of 147, by kolderman
AlfreX wrote on 2026-11-20, 01:50:
I found a major regression in the latest Linux builds! It turns out that when I try to add a new profile, in the “Drives” sectio […]
Hi, that sounds strange, I have not touched any code relating to saving new Drive mounts. I will investigate that and fix it along with the index(0) issue. In the meantime, here's a previous build I confirmed does not have that issue. It undoes a few of the other fixes though:
https://send.bitwarden.com/#AJRITyY1m0SPGLUIA … SBUyDaJg2UQiL7Q
Reply 143 of 147, by AlfreX
Thanks, this version fixes the error.
Reply 144 of 147, by kolderman
I have another build that I hope fixes some of these issues.
- the OK not saving on the Drive screen has been fixed. It was a side effect of the theme update change.
- I have put in a lot more guards around loading icons that hopefully will fix that index(0) issue. However I could not reproduce that, so I still need you to test that for me.
- changes from 2.6.9 windows builds have been included.
Cheers
https://send.bitwarden.com/#PHyXg6i7vUij8LUIA … CUt1o4AysVLwL7A
Reply 145 of 147, by AlfreX
Hey! Great job! Everything's working fine now!
The views are fixed!
And the part about adding drives, too.
And it's great that it's updated to the latest version of Windows!
Thank you so much!!
Reply 146 of 147, by kolderman
AlfreX wrote on 2026-11-21, 01:41:
Hey! Great job! Everything's working fine now! The views are fixed! And the part about adding drives, too. And it's great that i […]
Thank you so much!!
Great, thanks for confirming!
Reply 147 of 147, by kolderman
Thank you so much!!
Hi, have a new build you might want to try out. Main addition is it restores Cover Image downloading from TheGamesDB. The UI cleanup of the program settings forms has also been completed.
https://send.bitwarden.com/#PQ-8h7u_YUagebUQA … vFzN6jPwR0p83Fw
