S3d wrappers
Reply 160 of 176, by pc297
Sorry that didn't work! I forgot to mention a few things, including that you need gho's Destruction Derby DxWnd profile from:
https://sourceforge.net/p/dxwnd/discussion/ge … ion%20Derby.dxw
Also, make sure you rip the game's audio tracks to the Music folder.
You will also need his mcihack.txt:
https://sourceforge.net/p/dxwnd/discussion/ge … ent/mcihack.txt
However, I used the game's original AYAPI.DLL but the patched DD-NODIAMONDCARD.EXE.
Finally, for windowed mode, set the window size in DxWnd's Main settings to 512x384. For fullscreen, set it to your desktop resolution (e.g. 1680x1050 for me).
Importantly, create a file called s3d_resolution.txt in your DD directory and enter only the desired rendering width (e.g. 1280 for 1280x960), or fullscreen (without quotes).
If it still crashes, could you please post the s3d_glide_trace log generated in the game directory, if there is one?
Cheers,
Reply 161 of 176, by pc297
pc297 wrote on 2026-11-27, 13:17:
Sorry that didn't work! I forgot to mention a few things, including that you need gho's Destruction Derby DxWnd profile from: […]
Cheers,
You can also try the attached dxwnd profiles
Cheers,
Reply 162 of 176, by ghotik2002
Quickly tested on my Win11 using the profiles proposed above. The game seems to be working speedy and without crashes, but something is wrong on the rendering. I'll do more researches.
I'll put some screenshots on the DxWnd forum, here: https://sourceforge.net/p/dxwnd/discussion/ge … 5e71/#5ca6/4782
Reply 163 of 176, by pc297
ghotik2002 wrote on 2026-11-27, 15:30:
Ouch - thanks for trying it out - yes clearly rendering, was a log file produced? If so could you upload it? I also need to try it on another machine, I hope it's not graphics API-dependent (running it fine on an RX 580)
Cheers
Reply 164 of 176, by pc297
pc297 wrote on 2026-11-27, 18:33:
Cheers
Got it working on another machine, at the expense of a slight FPS penalty, it was heuristics in the texture identification, but still plays fine.
Let me know if it works for you - if it does there is probably room for improvement in terms of FPS
Reply 165 of 176, by filipetolhuizen
Cheers,
Thanks for your reply. Got the profiles, already had the s3d_resolution on the game's folder. Just don't know how to extract CD audio from an image file.
Here is the s3d_glide_trace log.
Reply 166 of 176, by pc297
Just added OpenGL rendering of ground textures, increased safety barrier LOD to match the PS1 version, and 4x MSAA (from the version that should work on other machines, hopefully)
Reply 167 of 176, by pc297
filipetolhuizen wrote on Yesterday, 01:21:
Cheers,
Hi!
Thanks, looked at the trace, it's not getting to the rendering and yes, it could be because it's failing the CD check. I also had some issues with that until I read gho's post 😀
https://sourceforge.net/p/dxwnd/discussion/ge … ead/7743d349f4/
You can actually extract the audio tracks directly through DxWnd; it's how I did it:
Mount your BIN/CUE image using a virtual CD drive such as Daemon Tools.
Make sure mcithack.txt is not yet in the Destruction Derby\Music (create the folder if needed) - it will refuse to rip otherwise.
Open the Destruction Derby profile in DxWnd (Modify).
Go to the CDAudio tab and select "RIP CD audio".
Launch the game through DxWnd. It should automatically extract the audio tracks as WAV files into the Music folder.
Once the extraction is complete, exit the game and switch the CDAudio setting back to "Use audio files".
Check "Hack track frames".
Then put mcihack in Destruction Derby\Music
You should then have the full soundtrack without needing to mount the CD image again.
If that doesn't work, you can also extract the CD audio using gho's modified bchunk utility, available here:
https://sourceforge.net/p/dxwnd/discussion/ge … ment/bchunk.rar
Download the linked bchunk.rar archive and extract its contents into the folder containing your BIN/CUE image (not sure it works for ISO)
Open a command prompt in that folder and run:
`bchunk.exe -i -o "Destruction Derby.cue"`
Replace the CUE filename with your actual filename.
This should generate the individual OGG audio tracks. Create a folder called Music inside your Destruction Derby installation directory and copy the tracks into it (track02.ogg through track15.ogg for the S3 version).
Make sure that "Use audio files" and "Hack track frames" are enabled in the DxWnd CDAudio settings, and that mcihack.txt is present in the Music folder.
Also, I've just released v0.2.66, which includes several important NVIDIA compatibility fixes as well as GPU ground rendering, extended barrier LOD and MSAA. You can try that version, hopefully it works (tested it on two machines only)!
Reply 168 of 176, by filipetolhuizen
pc297 wrote on Yesterday, 02:00:
Hi! […]
Cheers,
Hi!
Ok, I discovered what happened. When I imported the profiles, dxwnd created them instead of applying them to the one I already had. After pointing the new profile to the proper .exe, the game ran but had the exact same rendering problems as ghotik2002 with the 3 versions of the wrapper.
Reply 169 of 176, by pc297
filipetolhuizen wrote on Yesterday, 03:42:
Hi! […]
Hi!
Can you send me a trace of the very last try (v0.2.66)?
Reply 170 of 176, by filipetolhuizen
pc297 wrote on Yesterday, 12:17:
Hi! […]
Hi!
Here it is. I tried all the F keys to see if it made a difference, but they didn't.
Reply 171 of 176, by pc297
filipetolhuizen wrote on Yesterday, 14:20:
Can you try with this dxw (changing the path and launch)?
Reply 172 of 176, by filipetolhuizen
pc297 wrote on Yesterday, 15:04:
Just imported and tried it, but it looked exactly the same.
Reply 173 of 176, by pc297
filipetolhuizen wrote on Yesterday, 19:38:
Okay I identified and could reproduce the failure on a Win 11 machine. DDERR_INVALIDPIXELFORMAT and surface allocation.
Try this one - am optimising the speed and will post another one after
Reply 174 of 176, by pc297
If it works, try this one - it's faster
Reply 175 of 176, by filipetolhuizen
pc297 wrote on Today, 00:49:
These 2 seem to be working. I just get a glimpse of the rendering issue during the intro logos, but everything else seem to be fine.
EDIT: There's a few rendering issues on the menus after entering the car selection, mostly on the right and bottom buttons.
Reply 176 of 176, by pc297
filipetolhuizen wrote on Today, 01:14:
Thanks, will look into it! How are the fps (F9)? Note that the standard game seems capped at 24 fps (42 ms simulation block so 23.81 fps cap)- I did make a game engine patch (see the github link above - python script to patch the NODIAMOND.EXE) - which speeds it up considerably
