hi mwdmeyer I have this entry-level ASUS PCI Express x16 graphics card powered by the NVIDIA GeForce 7200 GS GPU.
Are you into PCIe? my reasons for wanting to use this is that well its probably ideal to run old windows 9x games but not ideal
for modern stuff much like early intel iGPU's and cheap to get.
I did find an unofficial driver package https://theretroweb.com/drivers/96 so I'll eventually try that maybe it can
help you about Nvidia on 9x.
Older versions of Direct3D might not perform very well on Windows versions newer than XP. Perhaps using dgVoodoo or some other wrapper gives better performance.
I did run 3DMark on Windows XP since I already had a SSD set up for my AMD GX-412HC based thin client, this one is weaker than yours.
3DMark2000: 9241 3DMarks (default settings, except for Z-buffer set to 24 bit for it to render properly)
I installed the Velocity9x ATI Radeon 9200SE (RV280) drivers, but they do not work in Windows 95; I am getting Code 24.
It works quite well on Windows 98SE.
Can you get from 95 machine.
A logged boot: press F8 at "Starting Windows 95", choose Logged, then attach C:\BOOTLOG.TXT. The lines mentioning V9XMINI are the ones I need.
1[000A2E5C] Dynamic load device v9xmini.vxd 2[000A2E5D] Dynamic load failed v9xmini.vxd : [000A2E5D] Not a valid device - possibly corrupt
Thank you. I've created a Win95 test build for you, can you test and see if it helps?
This time I was able to install it on Windows 95, and the desktop looks quite good.
I tried testing it with Croc, but the game is showing some artifacts.
Edit: Something I forgot to mention—ever since I managed to install the driver, the PC freezes completely whenever I insert a flash drive; perhaps the Velocity driver has some conflict with WinUSB.
vicowrote on Yesterday, 03:44:This time I was able to install it on Windows 95, and the desktop looks quite good.
I tried testing it with Croc, but the game i […] Show full quote
Thanks for testing.
Croc artifacts
Could you capture a trace? The tool you need, V9XTRACE.EXE, is already installed: it's in the zip you installed from, and the driver copied it to
C:\WINDOWS\SYSTEM.
Restart Windows, so the counters cover only Croc.
Before starting the game, open Start > Run and enter:
1V9XTRACE -grab:100x10
It returns straight away. From then on it saves every 100th frame the game shows, up to 10 frames.
Start Croc and play until the artifacts appear. Play for a minute or two so all ten frames get saved.
Quit Croc. Then open Start > Run again and enter just:
1V9XTRACE
Zip the whole C:\V9XDIAG folder and attach it here. It should contain V9XGRAB0.BMP to V9XGRAB9.BMP, V9XSNAP.INI, V9XBOOT.INI and V9XDD.INI. If there's a V9XTRACE.INI, include that too; the driver writes it when something faults.
Please also let me know:
the desktop resolution and colour depth;
whether Croc is set to Direct3D or software rendering;
a photo or screenshot of the artifacts, if you can.
If the saved frames come out clean while the screen shows artifacts, that also narrows down where the problem is.
Freeze when a flash drive is inserted
I haven't seen this before. Could you check whether it's the display driver?
Switch the display adapter back to Standard VGA (see RECOVER.TXT, or Device Manager > Display adapters > Update Driver), restart, and insert the drive. Does it still freeze?
Which USB support do you have: Windows 95 OSR2.1's USB supplement, or a third-party USB mass-storage driver? And is the stick plugged in at boot, or inserted later?
If it only freezes with Velocity9x, please send C:\BOOTLOG.TXT from a boot where you then inserted the drive. Also include C:\V9XDIAG from the next boot after the freeze.
Hi mwdmeyer, a few questions since I just found this thread and it seems like a very promising project. With velocity 9x would it be eventually possible to run Windows 98 SE with GPUs like 7900 GT too? There are unofficial Nvidia 7xxx drivers that already exist, but they result in bugs with a bunch of games. I'm also trying to get a sense of what's the latest and greatest GPUs that could be potentially supported under Win98 SE as part of this project..
Yes if someone can loan a computer (I have a remote agent) then I can create a driver. At this stage the nvidia driver path also has bugs, so it is difficult to know which option will be better (and both will improve at different rates).
The Intel path is best at the moment, but there are 9500 GT and GT 210 nvidia cards aready supported (although not all features in OpenGL/Direct3D are supported).
I'd be glad to carry out tests on my PC to help with driver development, but I'm not sure about remote agent connection. Though I understand it would be time consuming to test and iterate via attached test builds and logs, etc.
I've attached a new test build for Croc, if you get time please test, send through another trace if any issues.
Croc looks much better now, though there are other graphical glitches: some objects, text, gems, and even the lava appear inside a black box. I also tried 'Gex: Enter the Gecko,' but I couldn't get it to launch—not even with the 3D patch.
I also tested Earthworm Jim Special (a 2D game), and there are some issues that I will report later.
I was aware of xusbsupp, but WinUSB is better since it supports USB 2.0 on Windows 95; also, by disabling the drivers for my network card, the freezing has stopped.
