Reply 1280 of 1283, by rasz_pl
Darmok wrote on 2026-11-02, 06:46:
Many SVGA cards feature an automatic detection mechanism that determines the ISA bus bit-width upon computer startup.
I was hesitant of this claim so grabbed first random VGA bios - Paradise PVGA1 https://theretroweb.com/expansioncards/s/west … paradise-vga-16 and disassembled it as best I could (never did video bioses before so its not great compared to pc bioses) with datasheet in hand https://theretroweb.com/chip/documentation/19 … 53475369434.pdf and indeed
PR1 • MEMORY SIZE REGISTER· READIWRITE PORT =3CF & INDEX REGISTER=OB
bit 2 controls Video ram bus width and is initialized to 0 on reset 😮 Yay Im learning something new here! 😀
Bios does a funny dance and song of copying a routine (changing BIOS chip 8/16b bus width and that bit 2) into its own video memory to call it safely from there. I havent backtracked to the part where it decides if its safe to do this yet.
All in all im not happy about decompiling this bios. I didnt really learn conclusively how it handles turning 16b mem bus yet, but I learned that Paradise had messy coders 😐 and that theretroweb 24KB bios dump is not complete. Option rom header defines size as 30h x 512 = 24KB, and theretroweb dump is indeed 24KB, but code itself refers to addresses way past it! This dump https://theretroweb.com/expansioncards/s/west … ise-vga-plus-16 has whole 32KB rom and is complete. Oh I hate sloppy coding. Like when setting DAC it tests if its in mono to mix colors ... and then calls special method that again tests if its in mono to mix colors. Or how it will pretend to do CGA snow fix on a chipset that doesnt require it ... but only if its connected to BW monitor for some reason. Tons of redundant routines copying half the code of neighboring routines. Someone even made a typo on a special Paradise unlocking IO 0x46E8 port and code references non existent 0x4AE8 instead 😮 - 'A' instead of '6', looks like OCR/reading datasheet without glasses error!
Reading this BIOS actually upset me 🙁
TLDR: I learned at least Paradise PVGA1A chip does indeed start in 8b mode, but not how it decides if its safe to switch into 16b yet.
During the VGA BIOS initialization process, the BIOS code checks for the presence of an MDA or Hercules adapter
I really wanted to debunk this one, alas:
01DB Legacy_adapter_detect_initialize proc near
01DB mov cx, 1
01DE push cx
01DF mov dx, IO_Port_3CCh_VGA_Misc_Output_read
01E2 call IO_read_AL
01E5 and al, not (IO_Port_3CCh_VGA_Misc_b0_CRTC_CGA_3Dx)
01E7 mov dl, 0C2h
01E9 call IO_write_AL
01EC mov dx, IO_Port_3D4h_CRTC_Index_EGAVGA
01EF call CRTC_Cursor_Addr_L_readback_test
01F2 jnz short set_color_CRTC_test_MDA
01F4 call MONOCHROME_flag_set
01F7 call MONOCHROME_flag_toggle
01FA mov ax, BDA_49h_mode_3_80x25_Color_Text
01FD jmp short set_mode
01FF ; ---------------------------------------------------------------------------
01FF
01FF set_color_CRTC_test_MDA:
01FF mov dx, IO_Port_3CCh_VGA_Misc_Output_read
0202 call IO_read_AL
0205 or al, IO_Port_3CCh_VGA_Misc_b0_CRTC_CGA_3Dx
0207 mov dl, 0C2h
0209 call IO_write_AL
020C mov dx, IO_Port_3B4h_CRTC_Index_Mono
020F call CRTC_Cursor_Addr_L_readback_test
0212 jnz short end
0214 call MONOCHROME_flag_set
0217 mov ax, BDA_49h_mode_7_80x25_MDA_Text
021A
021A set_mode:
021A and byte ptr ds:BDA_89h_VGA_flags_1, not (BDA_89h_VGA_flags1_b0_Active)
021F int 42h ; - EGA/VGA/PS - Relocated (original INT 10h)
0221 call MONOCHROME_flag_toggle
0224
0224 end:
0224 pop cx
0225 retn
0225 Legacy_adapter_detect_initialize endp
this (all names my guesses) is executed very early on and does indeed try to check if there is another CGA/MDA card in the system. The way I read it is
- if it detects CGA concurrently plugged in PVGA will switch itself into MDA mode 😮 and initialize CGA mode 3.
- if it detects MDA it will initialize it in mode 7.
Fascinating!
Reply 1281 of 1283, by Darmok
@ViTi95
I finally received a TTL-to-VGA converter and was able to test Fast Doom 1.3.0 in `-hercmap` mode. Unfortunately, I discovered that this mode is broken in version 1.3.0: the VGA screen freezes, while the player's movement continues on the map. That’s a real shame — it worked fine in version 1.0.3, which I was using previously. If you are still interested in this project, could you please look into fixing it? Additionally, I have a suggestion: would it be possible to add an option to reduce the refresh rate of the Hercules screen in `-hercmap` mode — perhaps by a factor of two or three (or by making this factor configurable) relative to the VGA screen's refresh rate — and, consequently, reduce the frequency at which the map itself is calculated? This could potentially improve performance in `-hercmap` mode on 386 systems with an ISA bus.
Reply 1282 of 1283, by Darmok
My apologies, I was mistaken. The -hercmap mode does work in version 1.3.0. It turns out there is now an "Automap Update" option in the menu; it is disabled by default, but when enabled, the image on the VGA display continues to update. I’m not entirely sure why one would want to disable it, though—you can still move around the map, but effectively "blind." The only potential use for this would be rotating in place using the mouse to determine which direction you need to head.
Reply 1283 of 1283, by Darmok
Let me explain my confusion in more detail. I honestly don’t understand why anyone would need to disable "Automap Update." Doing so largely defeats the purpose of using a second monitor. While it’s true that enabling the map causes a significant drop in FPS, you don’t have to keep it in "Automap" mode constantly; you can simply double-tap the TAB key to toggle it on and off as needed. That’s what I do—I can check my position on the map whenever I want without suffering from a performance hit. The situation is effectively the same even when "Automap Update" is disabled. It never occurred to me that someone might want to force it off, which is why I assumed the feature was broken in version 1.3.0.
On fast processors, the performance drop in "Automap" mode is caused by the limited bandwidth of the 8-bit ISA bus. In 8-bit mode, chipsets insert at least four additional wait states; furthermore, older or slower devices can extend the write cycle even further using the IO CHRDY signal. Consequently, no matter how high your base FPS might be, enabling "Automap" (when using an Hercules) will inevitably lead to a significant drop in performance, as the system is bottlenecked by the HGC’s capacity to receive data bytes. This drop can be mitigated by reducing the amount of data sent to the Hercules card per unit of time. I suggest lowering the screen refresh rate for this mode—there’s no need for frequent updates; once every 250 ms, or perhaps even less often, should be sufficient. This could even be made a configurable parameter, allowing users to set it to their own preference. I’m not sure how often the map is currently being calculated, but to reduce the load on a 386 processor, it would make sense to synchronize those calculations with the screen refresh rate.
