First post, by eliot_new
Hello everybody,
this text is made by google translator, plz forgive me any errors:
"How is this possible? Here’s the setup: my "slowest" retro PC features a P166MMX, an ECS P5HX-A motherboard, a Spea Mirage V7 2MB PCI card, and an IDE2SD adapter with a 32GB SD card. It runs Quake 1 v1.08 in software mode at resolutions up to 360x480; anything higher results in a black screen. Just for fun, I pulled my Gigabyte GA-586HX (rev. 1.54) out of the closet to build a pure DOS PC as a test. I took my second Spea Mirage V7 card and installed it, along with the IDE2SD adapter and 32GB SD card from the ECS PC, just to see what it felt like to run DOS exclusively and control the P150 using SETMUL. Then I wondered what would happen if I launched Quake 1. I thought, "Hey, why not try changing the resolution?" since it always starts at 320x200. I "accidentally" selected 640x480, expecting a blank screen like usual—but to my surprise, I actually got an image. I was amazed. I bumped it up to 800x600, and the image remained visible. It wasn't until I hit 1024x768 that the screen went blank. I figured the Spea Mirage V7 from the ECS PC might be faulty, so I swapped the cards. The result was the same: the ECS PC showed a blank screen at resolutions above 360x480, while the Gigabyte PC handled up to 800x600. Then I swapped the monitors—replacing the Asus VS247HR with the "EyeCare" model I had been using to test the Gigabyte PC. It’s the same story again: the ECS + Spea combo gives a blank screen at resolutions above 360x480, whereas the Gigabyte + Spea setup displays an image up to 800x600. How is that possible? Both boards use the Intel i430HX chipset. I’m also running the S3 VBE driver in autoexec.bat—the one I found on theretroweb. By the way, testing with Duke Nukem 3D yields the same result; on the Gigabyte board, I can use VESA modes up to 800x600 with the Spea card."
EDIT: both Spea V7 deliver a picture to 800x600 with both monitors on my Gigabyte Board whereas both remain blank on the ECS Board.
EDIT2: the ECS has a Jan Steunebrink Bios, which supports K6-2, K6-3, 128GB HDD whereas the Gigabyte has the last Peter Sucek 3.0p Bios in order to support K6-2, K6-3 and 128GB HDD.
DOS:P233MMX,64MB,ECS,SpeaMirageV7,3dfxV1,AWE64,ESS1868,PicoGUS,32GB
W98SE:K63/400,256MB,P5A,Verite2200AGP,3dfxV2,M3D,AWE64,ESS1938,PicoGUS,64GB
XP:P3-1G,512MB,CUSL2C,FX5600AGP,Audigy1,80GB
Reply 1 of 12, by Riikcakirds
Are you using an LCD monitor. Run scitech 6.53 or 6.7, it will load a VBE3 bios and enable refresh rate changes in dos. Then run UNICENTR.EXE and it will let you set the refresh rate using + and - keys so the monitor will not blank screen in the resolutions you want.
Reply 2 of 12, by eliot_new
Riikcakirds wrote on 2026-09-29, 19:47:
Thx a lot!
I have tried your solution: same result.
Today I found another solution, but it is more than weird:
Weeks ago, I bought a P233MMX for my Gigabyte GA-586HX v1.54. I thought it’d be cool since the Gigabyte has auto-voltage and only 4 DIP switches.
Today, I tried it out, but the Gigabyte didn't recognize it, showing only a P166MMX. I was angry and disappointed, and thought someone had cheated me by relabeling a P166MMX as a P233MMX.
Then, I plugged the CPU into my ECS P5HX-A and set the multiplier to 3x via jumpers, which is its maximum.
Suddenly, the CPU ran as a P200MMX, showing me that the Gigabyte, not the CPU, has some issues.
I started Quake 1 to test stability, and suddenly I got the idea to check once again whether 640x480 works or still doesn't.
Guess what: with the new CPU, I now have not only 640x480, but also 800x600.
This means that the old ceramic P166MMX has some kind of bug, error, or damage.
Result:
Very happy that I can finally play Quake 1 in software mode at 800x600 on my ECS board.
Unhappy because the Gigabyte seems to have problems with its DIP switches; I will run further tests on why the 3.0x multiplier isn't working either.
I will test the ceramic P166MMX in all my Socket 7 boards to check whether Quake 1 refuses 640x480 on all of them => this would make me sell this CPU ASAP.
I am really astonished by what weird and odd behavior I so often discover on old hardware.
It is like a rollercoaster experience, but hey, somehow it is cool!
EDIT: @Riikcakirds => Now I have put the ceramic P166MMX into the Gigabyte board. I started Quake 1. Up to 360x480, everything is fine. But 640x480 immediately delivers a blank screen. No chance. This is proof that the ceramic P166MMX is the root of the problem. I have no idea how a CPU can cause a display resolution limitation?
Once again, a comparison of the current setups:
PC: ECS P5HX-A (Intel 430HX), P233MMX, 64MB EDO, Spea Mirage V7 Trio64 2MB, 32GB SanDisk SD card => Quake 1 runs up to 800x600 in software mode.
PC: Gigabyte GA-586HX v1.54, P166MMX, 64MB EDO, the same Spea Mirage, same SanDisk card => Quake 1 only runs up to 360x480.
PC: Same as number 2, but with a P150 instead of the P166MMX => Quake 1 allows resolutions up to 800x600.
Reply 3 of 12, by leileilol
DOS Quake requires 16MB+ of system memory and VESA 2.0 to access the higher modes.
Reply 4 of 12, by eliot_new
leileilol wrote on 2026-10-11, 00:25:
Both systems have > 16MB EDO RAM and VESA 2.0 via S3 driver and an identical (!) Spea Mirage V7 Trio64 2MB PCI graphic card.
But only the system with the ceramic P166MMX limits to 360x480: there is no rational explanation
I can make a video of both to show you, but it is easier to sell the P166MMX.
Once again: Q1 1.08 offers me up to 800x600 on:
P150, P233MMX, but not on P166MMX ceramic with the same graphic card
I think there must be some weird exception error based on the combination of P166MMX ceramic, the both i430HX boards and Q1 v1.08.
Besides, I remember the following peculiar exception, sorry for prolonging my answer here:
2 months ago I substituted the Spea with a Tseng ET6000 4MB only to test performance (all fast, expensive and scarce graphics cards are in a shelf, not in gaming PCs)
On the Tseng ET6000 Q1 allowed up to 1024x768, I was astonished and thought, ok, the S3 has some kind of limits or I need Sci Tech Doctor etc.
=> ECS P5HX-A, P166MMX, 64MB, Tseng ET6000 4MB, MSDOS 6.22, Quake1 v.1.08
But after so many tests I can definitely say, that the P166MMX ceramic has some kind of a bug or an internal error.
Reply 5 of 12, by Maraakate
Did you read leileilol's signature that says FUCK AI? I did. You should heed that advice. As soon as I read "this is the answer from Gemini" I was done with your post.
Reply 6 of 12, by eliot_new
Maraakate wrote on 2026-10-11, 12:34:
you re right, I have edited my post.
In case someone is seeking a cheap P166MMX CPU, I will sell mine for about 15€.
Reply 7 of 12, by Thandor
Do you have a photo of the P166MMX? Not that I’m interested in buying it but I’m wondering about the specific details. Perhaps I have the same CPU and I can test it whenever I dig out my Socket 7 stuff 😉.
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 8 of 12, by eliot_new
Now I have the solution, and like always, it is pretty weird ²:
Yesterday I assembled a new system: Asus SP97-XV, K6-233 ANR, Matrox Mystique 220, 128MB SDRAM, dual-booting DOS 6.22 and Win98SE.
I ran Q2 in software mode after installing the Matrox Mystique 220 driver from the original Matrox CD.
Q2 only allowed windowed mode, no fullscreen.
Today I experimented by setting the Asus EyeCare 23" to 800x600x16 @ 56Hz.
Only with this setting did Q2 allow fullscreen software mode at either 640x480 or 800x600.
As soon as I set 60Hz, 70Hz, 72Hz, etc., Quake 2 in fullscreen caused the Asus to display "Out of Range" with a blank screen.
I wondered if this could also solve the Quake 1 resolution issue.
I configured UniVBE 6.7 (UNIVBE67.EXE) and UniRefresh in AUTOEXEC.BAT, but the Mystique 220 still produced a blank screen.
Luckily, I had an older Asus VS247HR lying around.
I tested the DOS 6.22 installation (on SD card) on my ECS P5HX-A, P233MMX, Spea S3 Trio64 setup.
Loaded UniVBE 6.7 and UniRefresh (set between 48Hz and 60Hz; it showed that only 800x600 and 1280x1024 had 8-bit support).
Now I can play Quake 1 software mode in 300x200... 360x480... 800x600... and 1280x1024!
For no obvious reason I cannot set 640x480, but I am happy that 800x600 runs fine.
Apart from Quake 1, I tested Duke Nukem 3D: 800x600 runs fine as well, but as soon as I set 640x480, it says "VESA driver for 640x480 not found/supported".
Bottom line:
If you want a good retro PC monitor, stay away from the Asus EyeCare 23" – its VGA scaler/input is either too picky or simply broken for retro timings. Instead, use an older model like the Asus VS247HR.
I apologize for the erroneous assumption that the P166MMX was the source of all problems: it wasn't!
On the one hand, I'm sad that none of my Asus EyeCare monitors (which I use with my main PC) support proper scaling for these VESA 2.0 modes and cap Quake 1 at 360x480. On the other hand, I'm glad I didn't throw away my old Asus VS247HR 5 years ago, as it handles VESA 2.0 resolutions perfectly!
I have now tested all my DOS graphics cards with UniVBE 6.7, UniRefresh, and the Asus VS247HR, and here are the working resolutions for Quake 1 and Duke Nukem 3D:
Matrox Mystique 220: 512x384, 640x480, 800x600, 1024x768, 1280x1024 (all working fine)
SPEA Mirage V7 (S3 Trio64): 800x600, 1280x1024 (neither 640x480 nor 1024x768)
Daytona 64V (S3 Trio64+): 800x600, 1024x768, 1280x1024 (no 640x480)
Venus (S3 Trio64+): 800x600, 1024x768, 1280x1024 (no 640x480)
Hercules Stingray 64 Video (ARK2000PV): 640x480, 800x600 (all working fine)
Hercules Dynamite (ET4000/W32p): 512x384, 640x480, 800x600, 1024x768 (all working fine)
Hercules (ET6000): 640x480 up to 1280x1024 (works straight away, even without UniVBE 6.7)
Reply 9 of 12, by eliot_new
I did a final test:
1. switched back to AMD K6-233 ANR and tested the Mystique again: no SVGA possible, regardless Univbe loaded or not, regardless what PCI slot with wich manually assigned IRQ I use => Q1 SVGA always shows blanked screen
2. even installing a P150 into the Asus SP97-XV doesn't help: same results
This means: Matrox Mystique 220 + SiS 5582 Chipset = no SVGA mode possible in DOS games
I don´t know, why I wrote in the former post above, that the Mystique worked in SVGA on the Asus SP97-XV, maybe I messed up with the ECS P5HX-A.
Reply 10 of 12, by eliot_new
Update: Mystique 220 works flawlessly on Asus SP98AGP-X (SiS 5591 Chip)
Final result: the Asus SP97-XV is the reason for the not working SVGA on the Mystique 220 and not the Mystique nor the SiS itself.
Reply 11 of 12, by kingcake
eliot_new wrote on 2026-11-28, 19:23:
DId you have all the BIOS settings the same? i.e. assign IRQ, Palette Snoop, VBIOS Cacheable, VBIOS Shaow, PnP OS, PCI Burst Mode, Peer Concurrency, Memory Hole, etc etc.
Reply 12 of 12, by ludicrous_peridot
I am curious how practical is having higher resolution mode in Quake is for older systems? I have very recently got an S3 Trio 64V+ with 2Mb of RAM and am using it in a i440BX system with a Pentium II CPU "downclocked" to 200 MHz.
The moment I switch to 640x480 the game suffers a noticeable slowdown making it hardly playable. Starting with which of your builds can you comfortably play Quake in 640x480?
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 (FD14/W98SE/W10)
P6I440BX/B1S - Pentium II 350MHz - YMF-744 - CM-300 (FD14/DOS6)
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - CrystalBlaster (DOS6)
