Trouble with "\"
First post, by Justyna
Hi I have a rather simple sounding problem but I have no idea how to fix it ๐Ÿ™ I downloaded dosbox but when I tried making a C directory i realized I can't insert \ in. Instead it shows up as [ and when I press the button which actually coressponds to [ nothing appears ๐Ÿ™ What should I do ๐Ÿ™ ๐Ÿ™
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
check the readme
specifically the faq item
Q: I can't type \ or : in DOSBox.
Water flows down the stream
Reply 2 of 3, by Justyna
Hi thanks a lot ๐Ÿ˜€ I found the requried section in the faq but i still have a problem as the links that are given there dont work ๐Ÿ™ Maybe they're old i dont know. Does anyone have checked links where I could download they keyboard thigny ๐Ÿ™
Reply 3 of 3, by Justyna
Actually nvm i did something weird and it's working ok now ๐Ÿ˜– Hmm thanks a lot anyways :p
