Reply 20 of 23, by Amigaz
- Oldbie
wrote:Are you sure the COAST module is fake too? Do the traces go anywhere?The module in the picture looks kind of detailed. That would cost more money than it was worth to do that. You also may not have the right module.
wrote:hi
i'm trying to nail out the serial port issue
it 'works', but the mouse jumps all over the place and i've tried 3 different mice and two different serial ports. 😒There is a fix for this that involves cutting a trace for a resistor that's supposed to be effective.
Yep, the lines seem to go to the UMC chipset but all cachecheck utilities I've tested so far report no L2 cache...the performance speaks for itself also
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
