First post, by retro games 100
- l33t
I have just started testing my GUS PnP Pro 8mb revision 1 card.
I went in to "idiot mode" (which isn't too difficult for me), and thoughtlessly installed a pile of drivers & software DL'd from the net, thinking that I'd get so far with it, learn a few things from making some mistakes, and then have to start over again and do it properly.
Well, I was amazed at how far I got. Everthing appears to work except for:
I can't hear any music in DOS games. Eg, if I play the old DOS game "Heretic", and choose "ultrasound" for the music, I get no tunes! This is the case inside windows 98 "dos box" mode, or in "real" dos 7. In "real" dos 7, I can successfully get the play.exe application to play a midi file. Also in Heretic, I hear sound effects OK. Also, inside windows 98 I hear both midi and sound effects OK.
The manual says:
Before you run any DOS game from windows 95, you must run a special setup program to set the DOS environment variables for sound. You can do this in one of two ways -
Double-click the GUS prompt icon in your ultrasound plug & play program group. (Unforunately I can't find this icon.)
Or, in a dos box or in ms-dos mode, type SETGUS at the prompt. (Unforunately there doesn't appear to be any "setgus" application or batch file to run.)
(Please note that my autoexec.bat file does appear to contain highly relevant looking GUS initialization lines of code.)
Thanks a lot for any help! Best regards, Robert.
