First post, by VárTam
My program use serial device.
I use the dos 6.22 copy commands like this :
MODE COM1:96,N,8,1
COPY TEXTFILE.TXT COM1
and this is working.
The MODE command settings: the baud rate (9600),No parity,...
How can I set this parameters in the dosbox. In dos box there isn't MODE command.
Reply 1 of 3, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
I think all those settings are done in the dosbox.conf file.
_________________
Reply 3 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Use the mode command that comes with Freedos.
1+1=10
