First post, by Kelly Stiver
Hello, all! I've got my laptop back from my nephew, I've copied my "oldgames" directory that I had backed up on a blank DVD+R back into my laptop's C:\ drive, and installed Dosbox 0.72 back into my laptop.
Next, I went into my DOSbox's conf file and mounted my oldgames directory as DOSbox's C:\ drive, changed the fullscreen=false to fullscreen=true, and scaler=normal to scaler=super2xsai forced. i then commented out the original scaler value.
after this, i tried to run rex nebular. but i got an "illegal command." here are screenshots of my oldgames directory, my original rex directory, and my mps\rex directory below:
part of my oldgames directory
rex nebular no longer runs; i get a illegal command. how can i get the game to run?
thanks in advance!
p.s. I changed the scaler=normal to scaler=super2xsai forced because I was hoping to get sharper, photo-realistic graphics when I play Rex Nebular.
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
Re-install the game, obviously you either forgot to copy some files, or you mounted the drives different.
Reply 2 of 2, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
