First post, by Malik
Are there any actual perceptible difference between these two synthesis?
Or is it sought for it's vintage, classic status alone?
Can I be happy with just listening to my AWE32's FM music? Or will an original Adlib provide me something different?
I have never used an Adlib card before and it's as rare (read unavailable) as LAPC-I in ebay.
Reply 1 of 13, by leileilol
Very yes
Doom E1M1
AWE64 (creative crap fm)
CS4231 (YMF262)
Also the creative FM has missing channel anomalies as evidenced in this:
Doom E2M2
CS4231 (YMF262)
Sure, YMF262 isn't adlib but it's as closer to it than a creative fm card gets.
Reply 2 of 13, by Malik
Thanks for the infos and comparative files!
Very interesting piece of information.
EDIT: Yes, the difference is apparent.
Reply 3 of 13, by swaaye
There are Creative cards with real OPL2/3s.
Reply 4 of 13, by prophase_j
I'm not sure if that is the exact comparison Malik was reffering to..
The AWE64 isn't an actual OPL3, it is synthesized using Creative's proprietary method. But most AWE32's do have a bona-fide OPL3 built in. If I also remember correctly the digital output is sampled through the EMU8000, and available from the S/PDIF header on the board.
So that being said... the only differences would be the output stages.. things like noise and frequency attenuation. Now I haven't had either of these devices.. i'm just spouting information I have picked up from here and other sources. So if i'm wrong someone should step in and set the record straight.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
Reply 5 of 13, by 5u3
That depends on the AWE32 version you got. What's the model number of your card?
Reply 6 of 13, by Silent Loon
leileilol wrote:
CS4231 (YMF262)
You mean a card with Crystal CS4231 codec AND a Yamaha YMF262, don't you? As far as I know CS4231(A; A-KL...) didn't have a build in FM synth, that's why you often find this chip together with a YMF262 on soundcards - but correct me if I'm wrong. I also wonder, if soundcards with the CS4231A and YMF262 are really SBPro compatible, as many manufacturers claim...
Later models, i.e. Crystal CS4237(B) had a build in FM synth, so no YMF262 was needed.
YMF262 is the successor of YM3812, the original FM chip found on the original Adlib card: http://de.wikipedia.org/wiki/Yamaha_YM3812
Both are from Yamaha, so is there any sound difference between those two?
Often cited, allways informative:
http://queststudios.com/smf/index.php/topic,2175.0.html
Reply 7 of 13, by Amigaz
If there's interest I can do a recording from my real Adlib card from 1987 and from other SB cards (1.0, 2.0, Sb Pro etc) for comparison 😀
Reply 8 of 13, by Silent Loon
Yeah, that would be interesting...
Reply 9 of 13, by gerwin
Silent Loon wrote:
You mean a card with Crystal CS4231 codec AND a Yamaha YMF262, don't you? As far as I know CS4231(A; A-KL...) didn't have a buil […]
Several cards utilize a CS4231 (or CS4248) chip, but this 'big' chip is no standalone chip and it does not emulate SBPro. It usually comes with an Opti chip or an Aztech chip to take care of that. The CS4232 is a much smaller chip and it is standalone, SBPRO compatible, but requires an additional FM chip: Usually yamaha or it uses the GM-wavetable functionality for this (SAM 8905). CS4235/36/37 are similar but have a build in OPL3 clone.
I would trust the opl3 to be opl2-compatible enough to give the same genuine sound. but maybe I am being naive 😀 Wikipedia also has a page for the YMF-262 OPL3.
Reply 10 of 13, by Malik
I'm having a CT3980.
Yes, I'm using the digital output via the S/PDIF-Coaxial Cable. It's connected to my digital AV receiver.
Reply 11 of 13, by Great Hierophant
To avoid having to try to understand that six page post I started (its not all my fault, I swear!), I would say that your OPL is 100 percent compatible with the real OPL3 (with the AWE32 CT-3980). Creative had not switched to its own FM emulation methods yet.
Reply 12 of 13, by Moogle!
I will say this, I've noticed that OPLedit doesn't work with an AWE64.
Reply 13 of 13, by Malik
I'm very glad to hear it! Thanks!
