First post, by Fancy_Cat
OK, I'm considering buying an MT-32, or CM-32L, or similiar, but I can't seem to find decent information on the web about how to HOOK UP one. I have an IBM 300GL I've converted over to a pure DOS system (which is nice, because it's fast enough to run the most demanding DOS game I can throw at it, and yet still has a pair of ISA slots), with what I'm pretty sure is an ESS soundcard in it... To connect the MT-32, am I going to have to purchase a seperate MPU-401 interface, or can I just connect it to the ESS's gameport with a Midi-to-gameport cable?
Also, any info you could offer on if I need to add things to my CONFIG.SYS or AUTOEXEC.BAT would be helpful too. I just need to know how much effort I'm gonna need to put into this before I start buying things.
Reply 1 of 16, by 5u3
Possibly the cable will be enough. We can tell you for sure if you post the exact manufacturer/model of your ESS sound card.
Reply 2 of 16, by Fancy_Cat
Well much to my surprise, after running HWINFO, it would seem to be an actual Creative Labs Sound Blaster Pro (CT1335). Unless of course HWINFO is wrong and there's other detection software you could recommend. So.. yeah, hopefully that's a good thing for my project here.
Reply 3 of 16, by 5u3
Probably HWinfo is fooled by the SB Pro emulation of your ESS card (which is, basically, a good thing).
I'm afraid the only way to find out the model is to open the case and have a look at the card. A photo could help as well.
Reply 4 of 16, by Fancy_Cat
OK, after pulling the machine apart and taking a good look at the card it would appear to be a... Crystal Semiconductor S-16WP1/L. Well, I had assumed it was an ESS because that's what the spec sheet for a IBM 300GL I looked at said, and it's a mostly stock system...
Reply 5 of 16, by keropi
first it is an ESS card, then a SB and finally a Crystal based one... don't get me wrong but if you really want some answers you must give the proper info. A photo would be great!
and get a CM-32L if you can. Offers the same as MT-32 but with added sfx that are only availabe in the LAPC-I (some games use them, like Ultima Underworld 1, it uses the footsteps sfx)
as for config.sys/autoexec.bat you only need what your card uses to initilize it's MPU-401 port... nothing exrta
Reply 6 of 16, by Fancy_Cat
Sorry about the confusing... but yes, it's definately a Crystal one. Unless the labeling all over the card is wrong (and I looked up a photo of one online, it's the same card.)
One of these:
Reply 7 of 16, by 5u3
What's the writing on the main chip of the card? Is it "Crystal 4327B"?
Reply 8 of 16, by Fancy_Cat
Sorry, here's a picture of my actual card this time... Looks to me like it says Crystal CS4237B.
Reply 9 of 16, by 5u3
Hehe... this stays gripping 'till the end. 🤣
It's an IBM OEM card (P/N 33L1555). The onboard Crystal chip should have a MPU401 compatible interface, but I can't say if it works on your card (the empty socket and the missing waveblaster connector are not a good sign). Also you'll most probably need a driver to activate the interface under DOS.
Maybe it's not worth bothering with that card.
Reply 10 of 16, by Fancy_Cat
Ahh.. well, that's not exactly encouraging news. 😒
On the positive side, I found a good price on a MT-32 on eBay, so... I'll let you know if it works. If I HAVE to I'll just get a USB-To-Midi cable and use DOSBOX on my desktop system. Oh well.
Any better compatible cards you might recommend for my DOS system? Would a Sound Blaster 16, for example, be a good choice?
Reply 11 of 16, by keropi
AFAIK the SB16 mpu401 interface will work OK with the MT32... a good choise is always the non-pnp CT-1740 SB16 model...
I am sure someone have tested the mpu-401 port and will reply here 😀
And you can always look for real Roland MPU401 cards: the MPU-401AT, MPU IPC-T , Roland SuperMPU ... even the RAP-10 or SCC-1 cards by them have a fully functional mpu onboard (I do not cound LAPC-I because if you get one there is no need for the MT-32)
look for their pics here: http://www.dearhoney.idv.tw/Museum/midi-4.php and here: http://www.dearhoney.idv.tw/Museum/midi-2.php
Reply 12 of 16, by Great Hierophant
Unless the DSP version of that CT-1740, CT-1750 or CT-1770 is 4.05, he will suffer from the hanging notes midi bug. Also, this midi interface does not support the intelligent mode of the MPU-401 port. Neither does the RAP-10AT and the Super MPU is known to lose notes in MPU-401 mode because of the lag time it takes to switch to the mode.
Reply 13 of 16, by keropi
really? RAP-10 and Super MPU are problematic eh? I had no idea! thanks for the update!
I do have a RAP10 and never actually bothered to install it... just got it because it was a Roland card 😅
So the best way to connect an external module IMHO would stlill be the SCC-1 card... you get an MPU401 and a 4MB HD wavetable synth 😁
Reply 14 of 16, by Fancy_Cat
Oh well. Guess I'll just get a USB-to-MIDI interface cable and use the MT32 in DOSBOX for now. I'll save the pure DOS project for another day. Thanks for all the info, guys.
Reply 15 of 16, by Amigaz
This might explain why some games sound wrong on my PC where I have the Roland Super MPU card in (issue is described on Quest Studios forum)
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 16 of 16, by dnewhous
Was there a command to adjust the polyphony in MS-DOS? The Soundblaster 16 manual online indicates that there are some MIDI settings but none are a polyphony setting.
Daniel L Newhouse
