First post, by retro games 100
- l33t
The board looks in great shape, except for 2 small cut/knock marks on the item highlighted in the photo. I'm not sure what this "coil thing" is, but it's close to the power socket, and could be the cause of the problem.
When I power-on the mobo, I don't see any lights flash on the keyboard. (I also just get a blank screen on the monitor.)
All of the components on this mobo work, I've tested them on a 2nd identical board. The only curious thing is that the BIOS sticker seems different to the other P6SBA boards I've tried.
Also, what is the bare minimum components you need to test a mobo, just to see *any* POST message on the screen? Can I get away with no ram, and no keyboard? In other words, just a cpu and graphics card? If I remove the graphics card, but plug the keyboard in, should I still be able to see the keyboard's lights flash?
PS - I haven't bought a better camera yet. 😉
Edit: I've just noticed that 2 caps on this board look ever so slightly "domed". Why do caps go "domed"?
