First post, by ratfink
I'm hoping someone can help here. I have tried searching the web but I don't really know what to search for.
My system: Abit AN7, Athlon XP3000, 1GB ram, 2x160GB hard drives, Ti4800SE, Santa Cruz, RTL8139.
Runs Windows 2000 fine. Also had Windows 98 on it, from a previous motherboard, but a lot of unidentified devices as 98 does not support nforce2.
So... I got a puykka copy of 98SE and managed to convince that to install [it was full version and didn't want to be used as an upgrade]. And I got the Abit drivers and all devices got recognised.
Then today I decided to rationalise all the detritus and downloads that have built up over the past 3-4 years. And eventually - partly because the user files became such a mess (five of us use this machine), I decided to wipe the Win 98 partitions, reformat and then install 98se from scratch. Ho ho ho, that has been a complete failure so far.
Basically, it will seem to install. Then when I boot, it can't find the mouse [though the mouse worked during install], and it reports graphics problem. I have tried installing the Unofficial 98SE Service Pack, does not seem to help. I have used msconfig to limit RAM to 512MB. And I have disabled all startup options. Basically when starting I get the Win98 screen then it goes black and the monitor turns off.
Trying to do selective driver loading doesn't help.
It seems as though loading an extra driver causes this sometimes - it seemed to work at first, byt the USB2.0 device had a questionmark, so I installed the driver... and got these problems. But I have wiped and reinstalled a few times, and still get the problems.
Any ideas?
