[N800] Right mouse click
First post, by Smothermunchie
Hey all.
I have a touch screen N800 internet tablet that has an awesome version of Dosbox running on it.
Is there a way to simulate a right mouse click by editing the mapper.txt file and assigning it to a specific key?
I have sdl autolock = false
If not, is there any other tricky little work around to getting a right click through your emulator?
Thanks ahead!
Reply 1 of 5, by Smothermunchie
Well, apparently with no one answering, I'm assuming there is no such solution for this.
I was kind of hoping for something as simple as changing the mapperfile to something like this:
key_rightclick "key 278"
But yeah, doesn't look such a key can be mapped.
Anyway, since touch screen handhelds are really being marketed as of late, any chance that in the next version of Dosbox you could account for a single stylus input simulating both mouse keys some how?
Thanks!
Reply 2 of 5, by wd
Rank DOSBox Author
DOSBox Author
Is not present in the current version, won't be in the next version.
Reply 3 of 5, by Smothermunchie
Okay, fair enough. 😀
But do you think that perhaps down the road you could have it so a single, hardware button on a device could toggle back and forth between left and right mouse clicks when the stylus touches the screen?
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
ask the porter. not really something for dosbox itself
Water flows down the stream
Reply 5 of 5, by Freddo
N800 port thread
