Hello, me again.
I have read your post minimax and dosfreak again and again and tried to follow exactly as you said but there's something I quite dont understand. You see, I tried to save the command ('MOUNT C C:\OLDGAMES\WAR 2\' ect....)
in a note pad. I wrote exactly this:
[autoexec]
mount C C:\OLDGAMES\WAR2
MOUNT D E:\ -t cdrom
C:
Then I tried to save it with the name said in the guide you brought minimax, wich is : %ProgramFiles%\DOSBox-0.72\dosbox.conf
But it didn't worked, it said it couldn't found the folder. I guessed maybe it was because instead of mounting the folder 'MyGame' I created in my documents, (Just like you said in your guide) I have mount the folder 'OLDGAMES' I have created (Found this idea in the wikkipedia tutorial).
If you,re asking me why I havent followed this step by the letter like you told me to do was because I tried many times and everytime it couldn't find the way to it, saying the folder I want does not exist (And I had no mistake in the way I wrote it).
So eneway, I tried to save the notepad with the following name: '\DOSBox-0.72\dosbox.conf' instead of : '%ProgramFiles%\DOSBox-0.72\dosbox.conf'
And it worked, it was save. Tough everytime I restart DOSBox, nothing new happen, I have to manually mount everything and also reinstall the game 😒.
I also tried to manually remount the game exaclty the same way (with C and D) as I installed it and still, I have to reinstall each time because it can't read the cd. 😢
I wonder what I'm doing wrong...
Thanks for you help.
P.S. Please understand that it might be easy for you but it's not for me, thanks 😀
